Chiudi Centro assistenza ONLYOFFICE Documents for Android Presentation Editor Document Editor complete documentation User guides ONLYOFFICE Workspace ONLYOFFICE Groups ONLYOFFICE Docs Mail Server Talk Module ONLYOFFICE Groups Documents Module People Module Commmunity Module CRM Module Projects Module Mail Module Calendar Module ONLYOFFICE Docs Document Editor Spreadsheet Editor Presenetation editor ONLYOFFICE Mobile Apps ONLYOFFICE Documents for iOS ONLYOFFICE Documents app for Android Overview Changelog Manage files Open or create new files and folders Share files and folders Document Editor Operazioni principali Navigate through your document Switch between editing modes Select, cut, copy, paste text Undo/redo your actions Formattazione della pagina Set page parameters Insert section breaks Insert page numbers Insert footnotes Insert endnotes Formattazione del paragrafo Align your text in a paragraph Apply formatting presets Select background color for a paragraph Change paragraph indents Set paragraph line spacing Create lists Formattazione del testo Set font type, size, and color Apply font decoration styles Add hyperlinks Fillable forms Fill out OFORM fillable forms Operazioni sugli oggetti Insert tables Insert autoshapes Insert images Insert charts Change text wrapping Manipulate objects Strumenti e impostazioni Collaborative document editing Protect documents with a password Spell-checking Use the Find and Replace function Download and print your document View document information Spreadsheet Editor Operazioni principali Navigate through your spreadsheet Select, cut, copy, paste data Undo/redo your actions Operazioni con fogli Create or delete sheets Manage existing sheets Formattazione del testo di cella Set font type, size, and color Add hyperlinks Modifica delle proprietà di cella Select cell background color Add cell borders Apply cell style Align data in cells Wrap text in a cell Merge cells Change number format Selective cell clear Modifica delle righe/colonne Remove rows/columns Hide or show rows/columns Resize rows/columns Sort and filter data Operazioni sugli oggetti Insert charts Insert images Insert formulas Insert autoshapes Manipulate objects Strumenti e impostazioni Collaborative spreadsheet editing Protect spreadsheets with a password Use the Find and Replace function Change spreadsheet settings Change regional settings Download and print your spreadsheet View spreadsheet information Presentation Editor Operazioni principali Mobile presentation viewer Navigate through your presentation Select, cut, copy, paste text and objects Undo/redo your actions Lavoro con diapositive Manage slides Set slide parameters Change presentation theme Change slide layout Apply transitions Change slide background Preview your presentation Formattazione del testo Insert text Set font type, size, and color Apply font decoration styles Align your text in a text box Set paragraph line spacing Create lists Add hyperlinks Operazioni sugli oggetti Insert tables Insert autoshapes Insert images Insert charts Manipulate objects Strumenti e impostazioni Collaborative presentation editing Protect presentations with a password Spell-checking Use the Find and Replace function Change presentation settings Change application settings Download your presentation Print your presentation View presentation information ONLYOFFICE Projects for iOS ONLYOFFICE Projects for Android ONLYOFFICE Web Editors Glossario Video FAQ Generale Tecnologia Prezzi Workspace Enterprise Edition Docs Enterprise Edition Docs Developer Edition ONLYOFFICE Groups Connectors View presentation information operazioni con file Creare nuovo documento o aprire documento esistente Creare nuova presentazione o aprire presentazione esistente Creare nuovo foglio di calcolo o aprire un foglio di calcolo esistente Salvare, scaricare, stampare documento Salvare, stampare, scaricare presentazione Salvare, stampare, scaricare foglio di calcolo Visualizzare informazioni sul documento Visualizzare informazioni sul file More articles Visualizzare informazioni sulla presentazione Manage files Open or create new files and folders Share files and folders Visualizzare informazioni sul documento Change application settings Use the Find and Replace function Save, export, print your document Visualizzare informazioni sul file Change application settings Use the Find and Replace function Save, export, print your spreadsheet Visualizzare informazioni sulla presentazione Use the Find function Save and export your presentation Change application settings Print your presentation Protect documents with a password Protect spreadsheets with a password Protect presentations with a password Manage files Open or create new files and folders Share files and folders Visualizzare informazioni sul documento Use the Find and Replace function Download and print your document Visualizzare informazioni sul file Use the Find and Replace function Download and print your spreadsheet Visualizzare informazioni sulla presentazione Use the Find and Replace function Download your presentation Print your presentation Manage files Open or create new files and folders Share files and folders Use the Find and Replace function Change application settings Download and print your document Visualizzare informazioni sul documento Macros settings Change spreadsheet settings Change application settings Download and print your spreadsheet Visualizzare informazioni sul file Macros settings Use the Find and Replace function Change presentation settings Change application settings Download your presentation Print your presentation Visualizzare informazioni sulla presentazione Macros settings Manage files Open or create new files and folders Share files and folders Use the Find and Replace function Change application settings Download and print your document Visualizzare informazioni sul documento Macros settings Use the Find and Replace function Change spreadsheet settings Change application settings Download and print your spreadsheet Visualizzare informazioni sul file Macros settings Use the Find and Replace function Change presentation settings Change application settings Download your presentation Print your presentation Visualizzare informazioni sulla presentazione Macros settings Project documents informazioni sul file Visualizzare informazioni sul documento Visualizzare informazioni sul file Visualizzare informazioni sulla presentazione Visualizzare informazioni sul documento Visualizzare informazioni sul file Visualizzare informazioni sulla presentazione Visualizzare informazioni sul documento Visualizzare informazioni sul file More articles Visualizzare informazioni sulla presentazione Visualizzare informazioni sul documento Visualizzare informazioni sul file Visualizzare informazioni sulla presentazione Visualizzare informazioni sul documento Visualizzare informazioni sul file Visualizzare informazioni sulla presentazione To access the detailed information about the currently edited presentation in the On Device section, tap the Tools icon in the right corner of the top toolbar, select the Presentation info menu item. The presentation information includes the presentation title, file size, the date and time when the file was last modified. The About section also contains the following icons: - to open our helpcenter's web page dedicated to the application, - to contact our support team, - to view the information about the program. Download Teach your robot to read View and edit documents, spreadsheets and presentations of all popular formats Ti potrebbe essere d'aiuto anche... Chiudi
