Chiudi Centro assistenza User guides ONLYOFFICE Workspace General questions ONLYOFFICE Groups ONLYOFFICE Docs ONLYOFFICE Mail ONLYOFFICE Talk ONLYOFFICE Personal ONLYOFFICE Groups Documents Module People Module Community Module CRM Module Projects Module Mail Module Calendar Module Feed Tool ONLYOFFICE Docs All Editors Document Editor Spreadsheet Editor Presentation Editor ONLYOFFICE Mobile Apps ONLYOFFICE Documents for iOS ONLYOFFICE Documents for Android ONLYOFFICE Projects for iOS ONLYOFFICE Projects for Android ONLYOFFICE Web Editors ONLYOFFICE DocSpace Glossario Video FAQ Generale Tecnologia Prezzi Workspace Enterprise Edition Docs Enterprise Edition Docs Developer Edition ONLYOFFICE Groups Connectors User Guides Watch video ONLYOFFICE Documents for Android Document Editor overview ONLYOFFICE Documents for Android Spreadsheet Editor overview ONLYOFFICE Documents for Android Presentation Editor overview ONLYOFFICE Web Editors Mostra sommario Nascondi sommario Mobile web editors provide a complete toolset of editing features and have an interface which is adapted for working with documents in the mobile device web browser. ONLYOFFICE Mobile web editors for iOS Getting Started Overview Common operations for iOS Manage files Open or create new files and folders Share files and folders Operazioni principali Navigate through your document Select, cut, copy, paste text Undo/redo your actions Formattazione della pagina Impostare parametri di pagina Inserire interruzione di pagina Insert column breaks Inserire interruzioni di sezione Inserire numeri di pagina Insert footnotes Formattazione del paragrafo Align your text in a paragraph Apply formatting presets Select background color for a paragraph Change paragraph indents Impostare interlinea di paragrafo Create lists Formattazione del testo Impostare il tipo, la dimensione e il colore del carattere Applicare stili di decorazione dei caratteri Aggiungere collegamenti ipertestuali Fillable forms Filling out a form Operazioni sugli oggetti Insert tables Insert autoshapes Insert images Adjust chart settings Change text wrapping Manipulate objects Create a Table of Contents Strumenti e impostazioni Modifica collaborativa dei documenti Spell-checking Use the Find and Replace function Change application settings Macros settings Download and print your document Visualizzare informazioni sul documento Operazioni principali Navigate through your spreadsheet Select, cut, copy, paste data Undo/redo your actions Freeze panes Operazioni con fogli Create/delete sheets Manage existing sheets Formattazione del testo di cella Impostare il tipo, la dimensione e il colore del carattere Aggiungere collegamenti ipertestuali Modifica delle proprietà di cella Select cell background color Add cell borders Apply cell style Align data in cells Change text orientation Wrap text in a cell Merge cells Change number format Modifica delle righe/colonne Add or remove rows/columns Hide or show rows/columns Resize rows/columns Ordinare e filtrare dati Operazioni sugli oggetti Insert charts Insert images Insert formulas Insert autoshapes Manipulate objects Strumenti e impostazioni Modifica collaborativa dei fogli di calcolo Use the Find and Replace function Change spreadsheet settings Change application settings Macros settings Download and print your spreadsheet Visualizzare informazioni sul file Operazioni principali Mobile presentation viewer Navigate through your presentation Select, cut, copy, paste text and objects Undo/redo your actions Lavoro con diapositive Manage slides Set slide parameters Change presentation theme Change slide layout Apply transitions Change slide background Preview your presentation Formattazione del testo Insert text Impostare il tipo, la dimensione e il colore del carattere Applicare stili di decorazione dei caratteri Align your text in a text box Change text indents Impostare interlinea di paragrafo Create lists Aggiungere collegamenti ipertestuali Operazioni sugli oggetti Insert tables Insert autoshapes Insert images Adjust chart settings Manipulate objects Strumenti e impostazioni Modifica collaborativa delle presentazioni Spell-checking Use the Find and Replace function Change presentation settings Change application settings Macros settings Download your presentation Print your presentation Visualizzare informazioni sulla presentazione ONLYOFFICE Mobile web editors for Android Getting Started Overview Common operations for Android Manage files Open or create new files and folders Share files and folders Operazioni principali Navigate through your document Select, cut, copy, paste text Undo/redo your actions Formattazione della pagina Impostare parametri di pagina Inserire interruzione di pagina Insert column breaks Inserire interruzioni di sezione Inserire numeri di pagina Insert footnotes Formattazione del paragrafo Align your text in a paragraph Apply formatting presets Select background color for a paragraph Change paragraph indents Impostare interlinea di paragrafo Create lists Formattazione del testo Impostare il tipo, la dimensione e il colore del carattere Applicare stili di decorazione dei caratteri Aggiungere collegamenti ipertestuali Fillable forms Fill out OFORM fillable forms Operazioni sugli oggetti Insert tables Insert autoshapes Insert images Adjust chart settings Change text wrapping Manipulate objects Create a Table of Contents Strumenti e impostazioni Modifica collaborativa dei documenti Spell-checking Use the Find and Replace function Change application settings Macros settings Download and print your document Visualizzare informazioni sul documento Operazioni principali Navigate through your spreadsheet Select, cut, copy, paste data Undo/redo your actions Freeze panes Operazioni con fogli Create/delete sheets Manage existing sheets Formattazione del testo di cella Impostare il tipo, la dimensione e il colore del carattere Aggiungere collegamenti ipertestuali Modifica delle proprietà di cella Select cell background color Add cell borders Apply cell style Align data in cells Change text orientation Wrap text in a cell Merge cells Change number format Modifica delle righe/colonne Remove rows/columns Hide or show rows/columns Resize rows/columns Ordinare e filtrare dati Operazioni sugli oggetti Insert charts Insert images Insert formulas Insert autoshapes Manipulate objects Strumenti e impostazioni Modifica collaborativa dei fogli di calcolo Use the Find and Replace function Change spreadsheet settings Change application settings Macros settings Download and print your spreadsheet Visualizzare informazioni sul file Operazioni principali Mobile presentation viewer Navigate through your presentation Select, cut, copy, paste text and objects Undo/redo your actions Lavoro con diapositive Manage slides Set slide parameters Change presentation theme Change slide layout Apply transitions Change slide background Preview your presentation Formattazione del testo Insert text Impostare il tipo, la dimensione e il colore del carattere Applicare stili di decorazione dei caratteri Align your text in a text box Change text indents Impostare interlinea di paragrafo Create lists Aggiungere collegamenti ipertestuali Operazioni sugli oggetti Insert tables Insert autoshapes Insert images Adjust chart settings Manipulate objects Strumenti e impostazioni Modifica collaborativa delle presentazioni Spell-checking Use the Find and Replace function Change presentation settings Change application settings Macros settings Download your presentation Print your presentation Visualizzare informazioni sulla presentazione ONLYOFFICE Mobile web editors for iOS ONLYOFFICE Mobile web editors for Android
