To apply a background color to a certain cell/cell range or change the current one,
- select a cell, a range of cells or the whole worksheet,
- open the Cell settings panel by
- tapping the
icon at the top toolbar, or
- tapping the More option in the pop-up menu and choosing the Cell menu item,
- tap the Fill color option to open the color palette panel,
- select the necessary color on the Theme Colors or Standard Colors palette or create your own Custom Color (swipe it up to see more colors),
- go to the Add Custom Color menu,
- using the color palette, choose the necessary color and select its hue level,
- tap the
button to apply the color to the selected cell.
- close the cell settings panel by tapping the
arrow on the right.
To clear the background color of a certain cell, use the
No Fill icon on the Standard Colors palette.
