Chiudi Centro assistenza ONLYOFFICE Documents for Android Spreadsheet Editor Document Editor complete documentation User guides ONLYOFFICE Workspace ONLYOFFICE Groups ONLYOFFICE Docs Mail Server Talk Module ONLYOFFICE Groups Documents Module People Module Commmunity Module CRM Module Projects Module Mail Module Calendar Module ONLYOFFICE Docs Document Editor Spreadsheet Editor Presenetation editor ONLYOFFICE Mobile Apps ONLYOFFICE Documents for iOS ONLYOFFICE Documents app for Android Overview Changelog Manage files Open or create new files and folders Share files and folders Document Editor Operazioni principali Navigate through your document Select, cut, copy, paste text Undo/redo your actions Formattazione della pagina Set page parameters Insert section breaks Insert page numbers Insert footnotes Insert endnotes Formattazione del paragrafo Align your text in a paragraph Apply formatting presets Select background color for a paragraph Change paragraph indents Set paragraph line spacing Create lists Formattazione del testo Set font type, size, and color Apply font decoration styles Add hyperlinks Fillable forms Fill out OFORM fillable forms Operazioni sugli oggetti Insert tables Insert autoshapes Insert images Insert charts Change text wrapping Manipulate objects Strumenti e impostazioni Collaborative document editing Protect documents with a password Spell-checking Use the Find and Replace function Download and print your document View document information Spreadsheet Editor Operazioni principali Navigate through your spreadsheet Select, cut, copy, paste data Undo/redo your actions Operazioni con fogli Create or delete sheets Manage existing sheets Formattazione del testo di cella Set font type, size, and color Add hyperlinks Modifica delle proprietà di cella Select cell background color Add cell borders Apply cell style Align data in cells Wrap text in a cell Merge cells Change number format Selective cell clear Modifica delle righe/colonne Remove rows/columns Hide or show rows/columns Resize rows/columns Sort and filter data Operazioni sugli oggetti Insert charts Insert images Insert formulas Insert autoshapes Manipulate objects Strumenti e impostazioni Collaborative spreadsheet editing Protect spreadsheets with a password Use the Find and Replace function Change spreadsheet settings Change regional settings Download and print your spreadsheet View spreadsheet information Presentation Editor Operazioni principali Mobile presentation viewer Navigate through your presentation Select, cut, copy, paste text and objects Undo/redo your actions Lavoro con diapositive Manage slides Set slide parameters Change presentation theme Change slide layout Apply transitions Change slide background Preview your presentation Formattazione del testo Insert text Set font type, size, and color Apply font decoration styles Align your text in a text box Set paragraph line spacing Create lists Add hyperlinks Operazioni sugli oggetti Insert tables Insert autoshapes Insert images Insert charts Manipulate objects Strumenti e impostazioni Collaborative presentation editing Protect presentations with a password Spell-checking Use the Find and Replace function Change presentation settings Change application settings Download your presentation Print your presentation View presentation information ONLYOFFICE Projects for iOS ONLYOFFICE Projects for Android ONLYOFFICE Web Editors Glossario Video FAQ Generale Tecnologia Prezzi Workspace Enterprise Edition Docs Enterprise Edition Docs Developer Edition ONLYOFFICE Groups Connectors Apply cell style formattazione cella Aggiungere bordi Allineare dati in celle Eliminare testo, cancellare formattazione in una cella Unire celle Select cell background color Add cell borders Apply cell style Align data in cells More articles How to split cells How to add cells How to calculate percentages How to insert time Wrap text in a cell Merge cells Change number format Apply table styles Select cell background color Add cell borders Apply cell style Align data in cells Selective cell clear Change text orientation Wrap text in a cell Merge cells Change number format Select cell background color Add cell borders Apply cell style Align data in cells Change text orientation Wrap text in a cell Merge cells Change number format Select cell background color Add cell borders Apply cell style Align data in cells Change text orientation Wrap text in a cell Merge cells Change number format Wrapping text stili predefiniti Applicare stili di formattazione Inserire e formattare tabelle Inserire tabelle Impostare parametri di diapositiva Ordinare e filtrare dati Create a Table of Contents Create and edit pivot tables Use formatted tables Create slicers for tables More articles Add and Format a Table of Figures Apply formatting presets Apply cell style Apply table styles Change presentation theme Apply formatting presets Apply cell style Change presentation theme Apply formatting presets Apply cell style Change presentation theme Apply formatting presets Apply cell style Change presentation theme You can apply one of the formatting presets selecting the cell you wish to format and choosing the desired preset: select a cell, a range of cells or the whole worksheet, open the Cell settings panel by tapping the icon at the top toolbar, or tapping the option in the pop-up menu and choosing the Cell menu item, swipe up to see the Cell style palette and tap the style you want to apply. return to the previous screen by tapping the arrow on the left and сlose the cell settings panel by tapping the icon on the right. Download Teach your robot to read View and edit documents, spreadsheets and presentations of all popular formats Ti potrebbe essere d'aiuto anche... Chiudi
