Chiudi Centro assistenza User guides ONLYOFFICE Workspace General questions ONLYOFFICE Groups ONLYOFFICE Docs ONLYOFFICE Mail ONLYOFFICE Talk ONLYOFFICE Personal ONLYOFFICE Groups Documents Module People Module Community Module CRM Module Projects Module Mail Module Calendar Module Feed Tool ONLYOFFICE Docs All Editors Document Editor Spreadsheet Editor Presentation Editor ONLYOFFICE Mobile Apps ONLYOFFICE Documents for iOS ONLYOFFICE Documents for Android ONLYOFFICE Projects for iOS ONLYOFFICE Projects for Android ONLYOFFICE Web Editors ONLYOFFICE DocSpace Glossario Video FAQ Generale Tecnologia Prezzi Workspace Enterprise Edition Docs Enterprise Edition Docs Developer Edition ONLYOFFICE Groups Connectors User Guides Watch video Fillable forms in ONLYOFFICE Docs ONLYOFFICE 7.0: fillable forms, password protection and version history in spreadsheets Reference management in ONLYOFFICE documents with Mendeley, Zotero and EasyBib Count words, characters, and paragraphs in ONLYOFFICE Docs The Telegram messenger for conversations in ONLYOFFICE Docs Grammalecte in ONLYOFFICE Docs: spellchecker for French texts Translate texts in ONLYOFFICE Docs with Google, DeepL, and Apertium HTML plugin for ONLYOFFICE Docs Correct grammar with LanguageTool in ONLYOFFICE Docs ONLYOFFICE Docs Mostra sommario Nascondi sommario ONLYOFFICE Docs comprises web-based collaborative editors for text documents, spreadsheets, and presentations that support all major document, spreadsheet and presentation formats. All Editors All Editors Adding new fonts to ONLYOFFICE Desktop Editors How to enable dark theme in ONLYOFFICE Docs? Accessibility of ONLYOFFICE Editors Plugin manager Document Editor Program interface Presentazione dell'interfaccia utente dell'Editor di Documenti Scheda File Scheda Home Scheda Inserisci Scheda Layout di Pagina Scheda Riferimenti Scheda Forme Scheda Collaborazione View tab Scheda Plugin Operazioni principali Creare nuovo documento o aprire documento esistente Copiare/incollare testo, annullare/ripristinare azioni Change color scheme Formattazione della pagina Impostare parametri di pagina Visualizzare/nascondere caratteri non stampabili Inserire interruzioni di sezione Inserire intestazioni e piè di pagina Inserire data e ora Inserire numeri di pagina Inserire i numeri di riga Inserire note a piè di pagina Inserire note di chiusura Convertire note di chiusura e note a piè di pagina Aggiungere segnalibri Aggiungere filigrana Formattazione del paragrafo Allineare testo nella riga o paragrafo Impostare il livello di struttura del paragrafo Selezionare colore sfondo per un paragrafo Modificare rientri di paragrafo Impostare interlinea di paragrafo Inserire interruzione di pagina Aggiungere bordi Impostare le tabulazioni Creare elenchi Formattazione del testo Applicare stili di formattazione Impostare il tipo, la dimensione e il colore del carattere Applicare stili di decorazione dei caratteri Copiare/cancellare la formattazione del testo Aggiungere collegamenti ipertestuali Inserire riferimenti incrociati Inserire un capolettera Operazioni sugli oggetti Inserire tabelle Usare formule nelle tabelle Inserire immagini Inserire forme Inserire grafici Insert text objects Support of SmartArt Aggiungere una didascalia Inserire simboli e caratteri Align and arrange objects on a page Change text wrapping Insert content controls Create a Table of Contents Add and Format a Table of Figures Fillable forms Creare moduli compilab Compilazione di un modulo Unione di stampa Usare la stampa unione Equazioni matematiche Inserire equazioni Modifica congiunta Modifica collaborativa dei documenti Document Review Compare documents Plugins Modifica un'immagine Modificare HTML Correggere la tipografia Contare le parole Includi un video Inserire il codice evidenziato Inserire riferimenti Tradurre il test Estrarre il testo da un'immagine Leggere il testo ad alta voce Sostituire una parola con un sinonimo Caricare un documento su Wordpress Comunicare durante la modifica Strumenti e impostazioni Visualizzare informazioni sul documento Salvare, scaricare, stampare documento Impostazioni avanzate di Document Editor Visualizzazione e navigazione ONLYOFFICE Document Viewer Ricerca e sostituzione Controllo ortografia Funzioni di correzione automatica Protezione dei documenti con una password Suggerimenti utili Informazioni su Document Editor Formati di documenti elettronici supportati Tasti di scelta rapida Spreadsheet Editor Program interface Introducing the Spreadsheet Editor user interface Scheda File Scheda Home Scheda Inserisci Scheda Layout di Pagina Scheda Formula Scheda Dati Scheda Tabella pivot Scheda Collaborazione Scheda Protezione Scheda Visualizza Scheda Plugin Operazioni principali Creare nuovo foglio di calcolo o aprire un foglio di calcolo esistente Tagliare/copiare/incollare dati Annullare/ripristinare azioni Operazioni con fogli Gestire fogli di lavoro Inserire intestazioni e piè di pagina Formattazione del testo di cella Impostare tipo di carattere, dimensione, stile e colore Aggiungere collegamento ipertestuale Eliminare testo, cancellare formattazione in una cella Modifica delle proprietà di cella Aggiungere bordi Allineare dati in celle Unire celle Cambiare formato numerico Modifica delle righe/colonne Aggiungere celle Inserire o eliminare celle, righe, e colonne Ordinare e filtrare dati Usa tabelle formattate Crea affettatrici per tabelle formattate Modifica tabelle pivot Dati di gruppo Rimuovi i duplicati Formattazione condizionale Convalida dei dati Lavoro con funzioni Inserire funzione Inserire formule di matrice Usare intervalli denominati Calcolare percentuali Inserire l'ora Passare da una lingua all'altra in una tabella Operazioni sugli oggetti Inserire immagini Inserire grafico Inserisci sparkline Inserire e formattare forme Inserire oggetti di testo Support of SmartArt Inserisci simboli e caratteri Manipolare oggetti Equazioni matematiche Insert equations Modifica congiunta Modifica collaborativa dei fogli di calcolo Protecting a spreadsheet Proteggere un foglio di calcolo Consentire modifica intervalli Proteggere i tuoi fogli di calcolo con una passwor Proteggere un foglio Proteggere una cartella di lavor Plugins Modifica un'immagine Includi un video Inserire il codice evidenziato Tradurre il testo Sostituire una parola con un sinonimo Comunicare durante la modifica Strumenti e impostazioni Visualizzare informazioni sul file Salvare/stampare/scaricare foglio di calcolo Scale a worksheet Impostazioni avanzate di Spreadsheet Editor Visualizzazione e navigazione Ricerca e sostituzione Controllo ortografia Suggerimenti utili Informazioni su Spreadsheet Editor Formati di fogli elettronici supportati Tasti di scelta rapida Presentation Editor Program interface Introducing the Presentation Editor user interface Scheda File Scheda Home Scheda Inserisci Scheda Transizioni Animation Tab Scheda Collaborazione View Tab Scheda Plugin Operazioni principali Creare nuova presentazione o aprire presentazione esistente Copiare/incollare testo, annullare/ripristinare azioni Lavoro con diapositive Gestire diapositive Impostare parametri di diapositiva Applicare transizioni Inserire piè di pagina Visualizzare presentazione Formattazione del testo Inserire e formattare testo Aggiungere collegamento ipertestuale Creare elenchi Copiare/cancellare formattazione Operazioni sugli oggetti Inserire e formattare forme Inserire e regolare immagini Inserire e modificare grafici Inserire e formattare tabelle Support of SmartArt Adding animations Inserire simboli e caratteri Riempire oggetti e selezionare colori Manipolare oggetti Allineare e disporre oggetti nella diapositiva Equazioni matematiche Inserire equazioni Modifica congiunta Modifica collaborativa delle presentazioni Plugins Modifica un'immagine Includi un video Inserire il codice evidenziato Tradurre il test Sostituire una parola con un sinonimo Comunicare durante la modifica Strumenti e impostazioni Visualizzare informazioni sulla presentazione Salvare/stampare/scaricare presentazione Impostazioni avanzate di Presentation Editor Visualizzazione e navigazione Funzione di ricerca Controllo ortografia Funzioni di correzione automatica Protezione delle presentazioni con una password Abilita il supporto per la riproduzione video in ONLYOFFICE Desktop Editorsi> Suggerimenti utili Informazioni su Presentation Editor Formati di presentazioni elettroniche supportati Tasti di scelta rapida All Editors Document Editor Spreadsheet Editor Presentation Editor
