You can add endnotes to provide explanations or comments for certain sentences or terms used in your text, make references to the sources etc. that are displayed at end of the document
To insert an endnote into your document,
- position the insertion point at the end of the text passage that you want to add an endnote to,
- tap the
- switch to the
Other tab,
- select the
Endnote option.
The endnote mark (i.e. the superscript character that indicates an endnote) appears in the document text in the following format: i, ii, iii,..., and the insertion point moves to the bottom of the current page.
- type in the endnote text.
Repeat the above mentioned operations to add subsequent endnotes for other text passages in the document. The endnotes are marked automatically.
![Endnote](/it/images/Help/Mobile/Documents/Android/endnotesadded.png)
To edit a endnote in your document,
- tap the
Settings icon in the right corner of the top toolbar,
- select the
Endnote option and set the following options:
- Set the Location of endnotes on the page selecting one of the available options:
- Section end - to position endnotes at the end of the sections,
- Below text - to position endnotes at the end of the document (this option is selected by default),
- Adjust the endnotes Format:
- Number Format - select the necessary number format from the available ones: 1, 2, 3,..., a, b, c,..., A, B, C,..., i, ii, iii,..., I, II, III,...,
- Start at - use the arrows to set the number or letter you want to start numbering with,
- Numbering - select a way to number your endnotes:
- Continuous - to number endnotes sequentially throughout the document,
- Each section - to start endnotes numbering with 1 (or another specified character) at the beginning of each section,
- Each page - to start endnotes numbering with 1 (or another specified character) at the beginning of each page,
- Convert endnote if necessary:
- Covert to footnte - to change all endnotes into footnotes,
- Swap footnotes - to change all endnotes to footnotes, and all footnotes to endnotes (i.e. ordinary footnotes become endnotes, and endnotes become ordinary).
To remove a single endnote, position the insertion point directly before the endnote mark in the document text and press
Delete. Other endnotes will be remarked automatically.
To delete all the endnotes in the document,
- tap the
- select the
Endnote option,
- tap the Clear endnote button.
