To set page orientation, size or margins,
- tap the
Settings icon in the right corner of the top toolbar,
- select the
Document Settings menu item, then tap one of the following options:
- Orientation - to change the current orientation type. The default orientation type is Portrait that can be switched to Landscape.
- Format - to change the default A4 format tapping the arrow next to this menu item and selecting the preset size you need: US Letter, US Legal, A4, A5, B5, Envelope #10, Envelope DL, Tabloid, AЗ, Tabloid Oversize, ROC 16K, Envelope Choukei 3, Super B/A3, A0, A1, A2, A6.
- Margins - to change default margins, i.e. the blank space between the left, right, top and bottom page edges and the paragraph text. Use the
or
arrows to decrease or increase the current value for the Top, Bottom, Left and Right page margins.
- Color Schemes - to select the necessary color scheme from the available ones.
- use the arrow on the left to return to the previous screen and close the settings panel by tapping the Done caption on the right.
Note: all these parameters are applied to the entire document. If you need to set different
orientation, page margins, or size for the separate parts of your document, please refer to the Insert section breaks section of this guide.
