To customize your presentation, you can change the slide layout for each separate slide. To change a slide layout:
- in the slide list on the left, tap the slide you want to apply a new layout to,
- open the slide settings panel by
- tapping the
icon at the top toolbar, or
- tapping the Edit option in the pop-up menu,
- tap the Layout menu item,
- select the necessary layout (swipe up to see more layouts),
Note: currently, the following layouts are available: Title Slide, Title and Content, Section Header, Two Content, Comparison, Title Only, Blank, Content with Caption, Picture with Caption, Title and Vertical Text, Vertical Title and Text.
- close the slide settings panel by tapping the
arrow on the right.
