Chiudi Centro assistenza ONLYOFFICE Mobile web editors for Android Presentation Editor Document Editor complete documentation User guides ONLYOFFICE Workspace ONLYOFFICE Groups ONLYOFFICE Docs Mail Server Talk Module ONLYOFFICE Groups Documents Module People Module Commmunity Module CRM Module Projects Module Mail Module Calendar Module ONLYOFFICE Docs Document Editor Spreadsheet Editor Presenetation editor ONLYOFFICE Mobile Apps ONLYOFFICE Documents for iOS ONLYOFFICE Documents for Android ONLYOFFICE Projects for iOS ONLYOFFICE Web Editors ONLYOFFICE Mobile web editors for iOS ONLYOFFICE Mobile web editors for Android Overview Manage files Open or create new files and folders Share files and folders Document Editor Operazioni principali Navigate through your document Select, cut, copy, paste text Undo/redo your actions Formattazione della pagina Set page parameters Insert page breaks Insert column breaks Insert section breaks Insert page numbers Insert footnotes Formattazione del paragrafo Align your text in a paragraph Apply formatting presets Select background color for a paragraph Change paragraph indents Set paragraph line spacing Create lists Formattazione del testo Set font type, size, and color Apply font decoration styles Add hyperlinks Operazioni sugli oggetti Insert tables Insert autoshapes Insert images Adjust chart settings Change text wrapping Manipulate objects Strumenti e impostazioni Collaborative document editing Spell-checking Use the Find and Replace function Change application settings Macros settings Download and print your document View document information Spreadsheet Editor Operazioni principali Navigate through your spreadsheet Select, cut, copy, paste data Undo/redo your actions Freeze panes Operazioni con fogli Create or delete sheets Manage existing sheets Formattazione del testo di cella Set font type, size, and color Add hyperlinks Modifica delle proprietà di cella Select cell background color Add cell borders Apply cell style Align data in cells Change text orientation Wrap text in a cell Merge cells Change number format Modifica delle righe/colonne Remove rows/columns Hide or show rows/columns Resize rows/columns Sort and filter data Operazioni sugli oggetti Insert charts Insert images Insert formulas Insert autoshapes Manipulate objects Strumenti e impostazioni Collaborative spreadsheet editing Use the Find and Replace function Change spreadsheet settings Change app settings Macros settings Download and print your spreadsheet View spreadsheet information Presentation Editor Operazioni principali Mobile presentation viewer Navigate through your presentation Select, cut, copy, paste text and objects Undo/redo your actions Lavoro con diapositive Manage slides Set slide parameters Change presentation theme Change slide layout Apply transitions Change slide background Preview your presentation Formattazione del testo Insert text Set font type, size, and color Apply font decoration styles Align your text in a text box Change text indents Set paragraph line spacing Create lists Add hyperlinks Operazioni sugli oggetti Insert tables Insert autoshapes Insert images Adjust chart settings Manipulate objects Strumenti e impostazioni Collaborative presentation editing Spell-checking Use the Find and Replace function Change presentation settings Change application settings Macros settings Download your presentation Print your presentation View presentation information Glossario Video FAQ Generale Tecnologia Prezzi Workspace Enterprise Edition Docs Enterprise Edition Docs Developer Edition ONLYOFFICE Groups Connectors Add hyperlinks formattare caratteri Applicare stili di decorazione dei caratteri Applicare stili di formattazione Formattazione dei messaggi Come creare la base di conoscenza? Inserire un capolettera Insert text objects Insert text objects Inserire e formattare testo More articles Posta Impostare il tipo, la dimensione e il colore del carattere Impostare tipo di carattere, dimensione, stile e colore Set font type, size, and color Apply font decoration styles Add hyperlinks Set font type, size, and color Add hyperlinks Set font type, size, color Apply font decoration styles Add hyperlinks Set font type, size, and color Apply font decoration styles Add hyperlinks Set font type, size, and color Add hyperlinks Set font type, size, and color Apply font decoration styles Add hyperlinks Set font type, size, and color Apply font decoration styles Add hyperlinks Set font type, size, and color Add hyperlinks Set font type, size, color Apply font decoration styles Set font type, size, and color Apply font decoration styles Add hyperlinks Set font type, size, and color Add hyperlinks Set font type, size, color Apply font decoration styles Add hyperlinks inserire collegamenti Aggiungere collegamenti ipertestuali Aggiungere collegamento ipertestuale Aggiungere collegamento ipertestuale Formattazione dei messaggi Come creare la base di conoscenza? Add hyperlinks Add hyperlinks Add hyperlinks More articles Add hyperlinks Add hyperlinks Add hyperlinks Add hyperlinks Add hyperlinks Add hyperlinks Add hyperlinks Add hyperlinks Add hyperlinks collegamenti esterni Aggiungere collegamenti ipertestuali Aggiungere collegamento ipertestuale Aggiungere collegamento ipertestuale Add hyperlinks Add hyperlinks Add hyperlinks Add hyperlinks Add hyperlinks More articles Add hyperlinks Add hyperlinks Add hyperlinks Add hyperlinks Add hyperlinks Add hyperlinks collegamenti interni Aggiungere collegamento ipertestuale Aggiungere collegamento ipertestuale Add hyperlinks Add hyperlinks Add hyperlinks Add hyperlinks Add hyperlinks Add hyperlinks More articles Add hyperlinks Add hyperlinks Add a hyperlink select the text passage that will get clickable and do the following: tap the icon at the top toolbar to open the new object insertion panel, switch to the Other tab and choose the Link option, alternatively, you can choose the More option in the pop-up menu and tap the Add Link menu item, specify the hyperlink parameters: Tap the Link Type menu item to change a link type you wish to insert: External Link - this option is selected by default. Use it to add a hyperlink leading to an external website. Enter a URL in the format http://www.example.com in the Link field below. Slide in this Presentation - use this option to add a hyperlink leading to a certain slide in the same presentation. Tap this option to select it, then return to the previous screen using the arrow on the left. Tap the Link to menu item and select the necessary slide: Next Slide, Previous Slide, First Slide, Last Slide, Slide with the specified Number. Return to the previous screen using the arrow on the left. Display - enter a text that will get clickable and lead to the address specified in the upper field. Note: if you've selected a text passage before tapping the icon, the Display field will be filled with the selected text fragment. Screen Tip - enter a text that will become visible in a small pop-up window that provides a brief note or label pertaining to the hyperlink being pointed to. tap the INSERT button. Note: to follow the added link, double-tap it, choose the More option in the pop-up menu and tap the Open Link menu item. Edit or remove the added hyperlink double-tap the link and open the settings panel in one of the following ways: tap the icon at the top toolbar, or tap the Edit option in the pop-up menu. switch to the HYPERLINK tab and perform the actions you need: edit your data and tap the EDIT LINK button to save the changes. use the REMOVE LINK button to delete the added hyperlink. Download Teach your robot to read View and edit documents, spreadsheets and presentations of all popular formats Ti potrebbe essere d'aiuto anche... Chiudi
