Chiudi Centro assistenza ONLYOFFICE Mobile web editors for Android Presentation Editor Document Editor complete documentation User guides ONLYOFFICE Workspace ONLYOFFICE Groups ONLYOFFICE Docs Mail Server Talk Module ONLYOFFICE Groups Documents Module People Module Commmunity Module CRM Module Projects Module Mail Module Calendar Module ONLYOFFICE Docs Document Editor Spreadsheet Editor Presenetation editor ONLYOFFICE Mobile Apps ONLYOFFICE Documents for iOS ONLYOFFICE Documents for Android ONLYOFFICE Projects for iOS ONLYOFFICE Web Editors ONLYOFFICE Mobile web editors for iOS ONLYOFFICE Mobile web editors for Android Overview Manage files Open or create new files and folders Share files and folders Document Editor Operazioni principali Navigate through your document Select, cut, copy, paste text Undo/redo your actions Formattazione della pagina Set page parameters Insert page breaks Insert column breaks Insert section breaks Insert page numbers Insert footnotes Formattazione del paragrafo Align your text in a paragraph Apply formatting presets Select background color for a paragraph Change paragraph indents Set paragraph line spacing Create lists Formattazione del testo Set font type, size, and color Apply font decoration styles Add hyperlinks Operazioni sugli oggetti Insert tables Insert autoshapes Insert images Adjust chart settings Change text wrapping Manipulate objects Strumenti e impostazioni Collaborative document editing Spell-checking Use the Find and Replace function Change application settings Macros settings Download and print your document View document information Spreadsheet Editor Operazioni principali Navigate through your spreadsheet Select, cut, copy, paste data Undo/redo your actions Freeze panes Operazioni con fogli Create or delete sheets Manage existing sheets Formattazione del testo di cella Set font type, size, and color Add hyperlinks Modifica delle proprietà di cella Select cell background color Add cell borders Apply cell style Align data in cells Change text orientation Wrap text in a cell Merge cells Change number format Modifica delle righe/colonne Remove rows/columns Hide or show rows/columns Resize rows/columns Sort and filter data Operazioni sugli oggetti Insert charts Insert images Insert formulas Insert autoshapes Manipulate objects Strumenti e impostazioni Collaborative spreadsheet editing Use the Find and Replace function Change spreadsheet settings Change app settings Macros settings Download and print your spreadsheet View spreadsheet information Presentation Editor Operazioni principali Mobile presentation viewer Navigate through your presentation Select, cut, copy, paste text and objects Undo/redo your actions Lavoro con diapositive Manage slides Set slide parameters Change presentation theme Change slide layout Apply transitions Change slide background Preview your presentation Formattazione del testo Insert text Set font type, size, and color Apply font decoration styles Align your text in a text box Change text indents Set paragraph line spacing Create lists Add hyperlinks Operazioni sugli oggetti Insert tables Insert autoshapes Insert images Adjust chart settings Manipulate objects Strumenti e impostazioni Collaborative presentation editing Spell-checking Use the Find and Replace function Change presentation settings Change application settings Macros settings Download your presentation Print your presentation View presentation information Glossario Video FAQ Generale Tecnologia Prezzi Workspace Enterprise Edition Docs Enterprise Edition Docs Developer Edition ONLYOFFICE Groups Connectors Undo/redo your actions operazioni di modifica di base Annullare/ripristinare azioni Controllo ortografia Copiare/incollare testo, annullare/ripristinare azioni Copiare/incollare testo, annullare/ripristinare azioni Tagliare/copiare/incollare dati Tasti di scelta rapida Tasti di scelta rapida Tasti di scelta rapida Spell-checking More articles Spell checking Manage files Open or create new files and folders Share files and folders Navigate through your document Select, cut, copy, paste text Undo/redo your actions Navigate through your spreadsheet Select, cut, copy, paste data Undo/redo your actions Navigate through your presentation Select, cut, copy, paste text and objects Undo/redo your actions Manage files Open or create new files and folders Share files and folders Navigate through your document Select, cut, copy, paste text Undo/redo your actions Navigate through your spreadsheet Select, cut, copy, paste data Undo/redo your actions Navigate through your presentation Select, cut, copy, paste text and objects Undo/redo your actions Manage files Open or create new files and folders Share files and folders Navigate through your document Select, cut, copy, paste text Undo/redo your actions Navigate through your spreadsheet Select, cut, copy, paste data Undo/redo your actions Freeze panes Navigate through your presentation Select, cut, copy, paste text and objects Undo/redo your actions Navigate through your presentation Select, cut, copy, paste text and objects Undo/redo your actions Manage files Open or create new files and folders Share files and folders Navigate through your document Select, cut, copy, paste text Undo/redo your actions Navigate through your spreadsheet Select, cut, copy, paste data Undo/redo your actions Freeze panes Navigate through your presentation Select, cut, copy, paste text and objects Undo/redo your actions annulla e ripristina Copiare/incollare testo, annullare/ripristinare azioni Copiare/incollare testo, annullare/ripristinare azioni Annullare/ripristinare azioni Undo/redo your actions Undo/redo your actions Undo/redo your actions Undo/redo your actions Undo/redo your actions More articles Undo/redo your actions Undo/redo your actions Undo/redo your actions Undo/redo your actions Undo/redo your actions Undo/redo your actions Undo/redo your actions To perform the undo/redo operations, use the corresponding icons at the top toolbar: tap the Undo icon at the top toolbar to undo the last operation you performed. tap the Redo icon at the top toolbar to redo the last undone operation. Download Teach your robot to read View and edit documents, spreadsheets and presentations of all popular formats Ti potrebbe essere d'aiuto anche... Chiudi
