Insert a page break at the current cursor position
- tap the
- switch to the
Other tab,
- select the
Break option,
- choose the
Page Break option.
Insert a page break before the selected paragraph
- put the cursor within the paragraph you need,
- open the text and paragraph settings panel by
- tapping the
icon at the top toolbar, or
- tapping the Edit option in the pop-up menu,
- switch to the PARAGRAPH tab,
- tap the Advanced settings menu item,
- swipe up to see all the settings and turn the Page Break Before option on,
- close the paragraph settings panel by tapping the
arrow on the right.
![Paragraph Advanced settings](/it/images/Help/Mobile/Documents/Android/paragraph_advanced.png)
The Advanced settings section of the PARAGRAPH settings panel contains three more pagination options. Swipe up to see them:
- Orphan Control - is turned on by default and used to prevent a single line of the paragraph (the first or last) from appearing at the top or bottom of the page,
- Keep Lines Together - is used to keep lines together so that only whole paragraphs will be moved to the new page (i.e. there will be no page break between the lines within a single paragraph).
- Keep with Next - is used to prevent a page break between the selected paragraph and the next one.
