Close Help Center ONLYOFFICE Documents for Android Presentation Editor Document Editor complete documentation User guides ONLYOFFICE Workspace ONLYOFFICE Groups ONLYOFFICE Docs Mail Server Talk Module ONLYOFFICE Groups Documents Module People Module Commmunity Module CRM Module Projects Module Mail Module Calendar Module ONLYOFFICE Docs Document Editor Spreadsheet Editor Presenetation editor ONLYOFFICE Mobile Apps ONLYOFFICE Documents for iOS ONLYOFFICE Documents app for Android Overview Changelog Manage files Open or create new files and folders Share files and folders Document Editor Basic operations Navigate through your document Select, cut, copy, paste text Undo/redo your actions Page formatting Set page parameters Insert section breaks Insert page numbers Insert footnotes Insert endnotes Paragraph formatting Align your text in a paragraph Apply formatting presets Select background color for a paragraph Change paragraph indents Set paragraph line spacing Create lists Text formatting Set font type, size, and color Apply font decoration styles Add hyperlinks Fillable forms Fill out OFORM fillable forms Operations on objects Insert tables Insert autoshapes Insert images Insert charts Change text wrapping Manipulate objects Tools and settings Collaborative document editing Protect documents with a password Spell-checking Use the Find and Replace function Download and print your document View document information Spreadsheet Editor Basic operations Navigate through your spreadsheet Select, cut, copy, paste data Undo/redo your actions Operations with sheets Create or delete sheets Manage existing sheets Cell text formatting Set font type, size, and color Add hyperlinks Editing cell properties Select cell background color Add cell borders Apply cell style Align data in cells Wrap text in a cell Merge cells Change number format Selective cell clear Editing rows/columns Remove rows/columns Hide or show rows/columns Resize rows/columns Sort and filter data Operations on objects Insert charts Insert images Insert formulas Insert autoshapes Manipulate objects Tools and settings Collaborative spreadsheet editing Protect spreadsheets with a password Use the Find and Replace function Change spreadsheet settings Change regional settings Download and print your spreadsheet View spreadsheet information Presentation Editor Basic operations Mobile presentation viewer Navigate through your presentation Select, cut, copy, paste text and objects Undo/redo your actions Working with slides Manage slides Set slide parameters Change presentation theme Change slide layout Apply transitions Change slide background Preview your presentation Text formatting Insert text Set font type, size, and color Apply font decoration styles Align your text in a text box Set paragraph line spacing Create lists Add hyperlinks Operations on objects Insert tables Insert autoshapes Insert images Insert charts Manipulate objects Tools and settings Collaborative presentation editing Protect presentations with a password Spell-checking Use the Find and Replace function Change presentation settings Change application settings Download your presentation Print your presentation View presentation information ONLYOFFICE Projects for iOS ONLYOFFICE Projects for Android ONLYOFFICE Web Editors Glossary Video FAQ General Technology Pricing Workspace Enterprise Edition Docs Enterprise Edition Docs Developer Edition ONLYOFFICE Groups Connectors Trial period Collaborative editing collaborative editing Advanced settings of Document Editor Advanced settings of Presentation Editor Advanced Settings of Spreadsheet Editor Collaborative document editing Communicating in real time Collaborative spreadsheet editing Co-editing documents online Sending for electronic signature More articles Open or create new files and folders Open or create new files and folders Collaborative document editing Collaborative spreadsheet editing Communicating in real time Open or create new files and folders Collaborative document editing Collaborative spreadsheet editing Communicating in real time Open or create new files and folders Collaborative document editing Collaborative spreadsheet editing Communicating in real time Sharing files and folders Integrating ONLYOFFICE with Nextcloud Integrating ONLYOFFICE with ownCloud Integrating ONLYOFFICE with Confluence Integrating ONLYOFFICE with Humhub Integrating ONLYOFFICE with Alfresco Integrating ONLYOFFICE with Liferay Integrating ONLYOFFICE with SharePoint Integrating ONLYOFFICE with Plone Integrating ONLYOFFICE with Chamilo Integrating ONLYOFFICE with Jira Integrating ONLYOFFICE with Nuxeo Integrating ONLYOFFICE with Redmine How to integrate ONLYOFFICE with Nextcloud using the app from the official store How to integrate ONLYOFFICE with Nextcloud How to integrate ONLYOFFICE Docs with ownCloud How to integrate ONLYOFFICE with Nuxeo How to integrate ONLYOFFICE with Nuxeo with the official plugin How to integrate ONLYOFFICE Docs with SharePoint How to deploy ONLYOFFICE on DigitalOcean using One-Click App How to integrate ONLYOFFICE with Alfresco Share How to integrate ONLYOFFICE with Chamilo Configuring ONLYOFFICE connector for Nextcloud Configuring ONLYOFFICE connector for ownCloud How to integrate ONLYOFFICE with Redmine How to integrate ONLYOFFICE with Jira ONLYOFFICE 7.0: fillable forms, password protection and version history in spreadsheets Sharing documents View Comments To view all comments that have been added to the presentation: tap the Collaboration icon in the right corner of the top toolbar, select the Comments menu item. Here you can manage comments and replies in the following way: edit replies and comments by tapping the icon and selecting the Edit comemnt / Edit reply option, delete replies and comments by tapping the icon and selecting the Delete comment / Delete reply option, close the discussion by tapping the icon to the right of the comment. You can also tap the icon and select the Close option. After that the discussion you opened with your comment gets the resolved status. To open it again, tap the icon to the right of the comment or tap the icon and select the Reopen option. Download Teach your robot to read View and edit documents, spreadsheets and presentations of all popular formats You Might Also Like This: Close
