Articles with the tag:
Close
Close
Try in the cloud
Download and print your document
Download the document
To download the current document, opened in the Clouds section, to your device,
  2. tap the Download Download menu item,
  3. tap one of the available file formats: DOCX, PDF, PDF/A, TXT, RTF, ODT, HTML, DOTX, OTT.
The file will be downloaded and stored on your device.
Export the document
To export a document to your device, you should locally open the file by tapping on it in the On Device section and follow these steps:
  2. tap the Print Export menu item,
  3. tap one of the available file formats: DOCX, PDF, RTF, ODT,
  4. specify the path where the file will be saved. It can be either the same device or a cloud storage.
Print the document
To print the current document opened in the Clouds section,
  2. tap the Print Print menu item.
A PDF file will be generated on the basis of this document. It can be printed out.
To print the current local document, opened in the On Device section,
  2. tap the Print Print menu item to enter the priview mode,
  3. at the top of the screen choose either an available Printer or tap on the Save as PDF option to generate a PDF file on the basis of this document,
  4. in the drop-down menu Arrow specify the following parametrs:
    • number of copies - enter the required number of copies of the document;
    • number of pages - choose either a range of pages, filling the textfield in the following way: (e.g. 1-5, 8, 11-13), or tap on each checkbox below to mark the pages you want to print;
    • page size - select one of the suggested paper formats;
    • color - choose either black and white print or color print (only for supporting printers);
    • two-sided printing - this option allows to print on both sides of a sheet of paper (only for supporting printers);
    • page orientation - choose from landscape and portrait options,
  5. tap the Print button to initialize printing.
You Might Also Like This:
Close
