Insert an autoshape
- select the worksheet you want to put the shape onto,
- tap the
- switch to the
Shape tab,
- select one of the available autoshapes.
The selected autoshape will be added. Now you can change its properties and position.
Adjust the shape settings
- select the shape by tapping its border (the rectangular box around the shape should be displayed as a solid line),
- open the Shape settings panel by
- tapping the
icon at the top toolbar, or
- tapping the
option in the pop-up,
- tap the necessary menu item: Style, Replace or Reorder. Use the
icon on the left to return to the previous settings section.
- Fill - to fill the inner space of the autoshape with a solid color, gradient, image, or pattern.
- Border style - to set the border Size by dragging the slider and select the border Color on the palette,
- Effects - to set the Opacity level by dragging the slider. The default value is 100%. It corresponds to the full opacity. The 0% value corresponds to the full transparency. You can also use the Shadow switcher to enable the shadow.
The Replace section allows to replace the current autoshape with another one selected from the menu.
The Reorder section allows to to set the selected autoshape position as related to other objects when several objects overlap each other. To learn more, please refer to the Manipulate objects section of this guide.
- close the shape settings panel by tapping the
arrow on the right.
Add text within the autoshape
- place the insertion point by by tapping inside the autoshape (the rectangular box around the shape should be displayed as a dashed line),
- start typing your text using the on-screen keyboard.
The text you add in this way becomes a part of the autoshape (when you move or rotate the shape, the text moves or rotates with it).
Remove the shape
Select the shape by tapping on it and proceed in one of the following ways:
- tap the
option in the pop-up menu, or
- open the shape settings panel by tapping the
icon at the top toolbar, swipe up and tap the Remove shape button.
