Close Help Center ONLYOFFICE Documents for Android Spreadsheet Editor Document Editor complete documentation User guides ONLYOFFICE Workspace ONLYOFFICE Groups ONLYOFFICE Docs Mail Server Talk Module ONLYOFFICE Groups Documents Module People Module Commmunity Module CRM Module Projects Module Mail Module Calendar Module ONLYOFFICE Docs Document Editor Spreadsheet Editor Presenetation editor ONLYOFFICE Mobile Apps ONLYOFFICE Documents for iOS ONLYOFFICE Documents app for Android Overview Changelog Manage files Open or create new files and folders Share files and folders Document Editor Basic operations Navigate through your document Select, cut, copy, paste text Undo/redo your actions Page formatting Set page parameters Insert section breaks Insert page numbers Insert footnotes Paragraph formatting Align your text in a paragraph Apply formatting presets Select background color for a paragraph Change paragraph indents Set paragraph line spacing Create lists Text formatting Set font type, size, and color Apply font decoration styles Add hyperlinks Fillable forms Fill out OFORM fillable forms Operations on objects Insert tables Insert autoshapes Insert images Insert charts Change text wrapping Manipulate objects Tools and settings Collaborative document editing Spell-checking Use the Find and Replace function Download and print your document View document information Spreadsheet Editor Basic operations Navigate through your spreadsheet Select, cut, copy, paste data Undo/redo your actions Operations with sheets Create or delete sheets Manage existing sheets Cell text formatting Set font type, size, and color Add hyperlinks Editing cell properties Select cell background color Add cell borders Apply cell style Align data in cells Wrap text in a cell Merge cells Change number format Editing rows/columns Remove rows/columns Hide or show rows/columns Resize rows/columns Sort and filter data Operations on objects Insert charts Insert images Insert formulas Insert autoshapes Manipulate objects Tools and settings Collaborative spreadsheet editing Use the Find and Replace function Change spreadsheet settings Download and print your spreadsheet View spreadsheet information Presentation Editor Basic operations Mobile presentation viewer Navigate through your presentation Select, cut, copy, paste text and objects Undo/redo your actions Working with slides Manage slides Set slide parameters Change presentation theme Change slide layout Apply transitions Change slide background Preview your presentation Text formatting Insert text Set font type, size, and color Apply font decoration styles Align your text in a text box Set paragraph line spacing Create lists Add hyperlinks Operations on objects Insert tables Insert autoshapes Insert images Insert charts Manipulate objects Tools and settings Collaborative presentation editing Spell-checking Use the Find and Replace function Change presentation settings Change application settings Download your presentation Print your presentation View presentation information ONLYOFFICE Projects for iOS ONLYOFFICE Projects for Android ONLYOFFICE Web Editors Glossary Video FAQ General Technology Pricing Workspace Enterprise Edition Docs Enterprise Edition Docs Developer Edition ONLYOFFICE Groups Connectors Undo/redo your actions basic editing operations Keyboard shortcuts Keyboard shortcuts Keyboard shortcuts Copy/paste data, undo/redo your actions Copy/paste text passages, undo/redo your actions Cut/copy/paste data Undo/redo your actions Spell-checking Spell-checking More articles Spell checking Manage files Open or create new files and folders Share files and folders Navigate through your document Select, cut, copy, paste text Undo/redo your actions Navigate through your spreadsheet Select, cut, copy, paste data Undo/redo your actions Navigate through your presentation Select, cut, copy, paste text and objects Undo/redo your actions Manage files Open or create new files and folders Share files and folders Navigate through your document Select, cut, copy, paste text Undo/redo your actions Navigate through your spreadsheet Select, cut, copy, paste data Undo/redo your actions Navigate through your presentation Select, cut, copy, paste text and objects Undo/redo your actions Manage files Open or create new files and folders Share files and folders Navigate through your document Select, cut, copy, paste text Undo/redo your actions Navigate through your spreadsheet Select, cut, copy, paste data Undo/redo your actions Freeze panes Navigate through your presentation Select, cut, copy, paste text and objects Undo/redo your actions Navigate through your presentation Select, cut, copy, paste text and objects Undo/redo your actions Manage files Open or create new files and folders Share files and folders Navigate through your document Select, cut, copy, paste text Undo/redo your actions Navigate through your spreadsheet Select, cut, copy, paste data Undo/redo your actions Freeze panes Navigate through your presentation Select, cut, copy, paste text and objects Undo/redo your actions undo and redo operations Copy/paste data, undo/redo your actions Copy/paste text passages, undo/redo your actions Undo/redo your actions Undo/redo your actions Undo/redo your actions Undo/redo your actions Undo/redo your actions Undo/redo your actions More articles Undo/redo your actions Undo/redo your actions Undo/redo your actions Undo/redo your actions Undo/redo your actions Undo/redo your actions Undo/redo your actions To perform the undo/redo operations, use the corresponding icons at the top toolbar: tap the Undo icon at the top toolbar to undo the last operation you performed. tap the Redo icon at the top toolbar to redo the last undone operation. Download Teach your robot to read View and edit documents, spreadsheets and presentations of all popular formats You Might Also Like This: Close
