Articles with the tag:
Close
Close
Try in the cloud
Try in the cloud
Fill out OFORM fillable forms
You can open and fill out OFORM files stored on your device. You can only fill in the fields in the the OFORM file and then download the form as a DOCX or PDF file.
  1. tap the necessary field or use the arrow buttons at the bottom of the screen to navigate between the fields. Tap Previous to go to the previous field or Next to go to the next field.
  2. fill in all the necessary fields.
    • when you select a text field, the keyboard appears. If the Characters limit setting is enabled for the field, the limit is displayed on the screen.
      Text
    • when you select a combo box, the screen appears where you can choose the necessary option or enter your own data by tapping Enter your option.
      Combobox
      Enter the necessary data in a new window and tap OK.
    • when you select a dropdown list, the screen appears where you can choose the necessary option.
      Dropdown list
    • when you select a check box, the screen appears where you can check/uncheck this check box.
      Check box
    • when you select a radio button, the screen appears where you can check/uncheck this radio button.
      Radio button
    • when you select an image field, the screen appears where you can choose the necessary option: Picture from library or Picture from link.
  3. undo Undo icon or redo Undo icon your actions using icons on the top.
  4. to clear all fields, tap the Settings icon Settings icon in the right corner of the top toolbar and choose the Clear all fields option.
  5. once the form is filled in, you can download it and save it on your device as a DOCX or PDF file. Tap the Settings icon Settings icon in the right corner of the top toolbar, choose the Export option, select the necessary format, then choose the location and tap Save.
  6. to quickly export the form to the PDF format and save it on your device, tap the Exports icon icon on the top, then choose the location and tap Save.
  7. to print the form, tap the Settings icon Settings icon in the right corner of the top toolbar and choose the Print option.
You Might Also Like This:
Close
