Articles with the tag:
Close
Close
Try in the cloud
Navigate through your spreadsheet
To navigate between sheets, use the sheet navigation panel below the current worksheet. Tap the necessary sheet tab to switch to the sheet.
Sheet navigation panel
To navigate between sheets, you can also tap the Add sheet icon in the bottom left part of the sheet navigation panel and choose the necessary sheet.
Navigate sheets
To scroll a sheet, swipe up or down, left or right.
To zoom in a sheet, use the stretch gesture: place two fingers on the screen and move them apart.
To zoom out a sheet, use the pinch gesture: place two fingers on the screen and move them together.
You Might Also Like This:
Close
