Insert text within placeholders
You can add your own text in place of the default text within the corresponding text placeholder provided on the slide layout. To do that:
- tap inside the placeholder and type in your text using the on-screen keyboard, or
- tap the placeholder border and paste the previously copied text using the Paste option from the pop-up menu.
Insert text within shapes
You can add a text passage within an autoshape. Tap inside a shape and start typing your text using the on-screen keyboard.
It's also possible to insert a text box (a rectangular frame that allows to enter text within it) anywhere on a slide. To do that:
- tap the
- switch to the
Shape tab,
- tap the
autoshape - the text box will be added to the slide,
- tap one of the resize handles
on the borders of the added text box and drag the handle to change the text box size,
- tap inside the added text box and start typing your text using the on-screen keyboard.
When a text box is not selected, it has invisible borders.
Tap outside of the text object to return to the slide.
As a text object represents a rectangular frame with text in it and this frame is a common autoshape, you can change both the shape and text properties.
The text within the text object is a part of the latter (when you move or rotate the text object, the text moves or rotates with it).
To delete a text object, tap its border, then tap the
Delete option.
