To protect your documents in the Document Editor:
- Tap the
Settings icon in the right corner of the top toolbar.
- Tap the
Protection menu option.
- Enable the Set password switcher. Enter the required password and verify it.
![Set password](/images/Help/Mobile/Documents/Android/fileencryption.png)
Please note that the password cannot be restored. Please keep it in a safe place so as not to forget it.
- Apply the changes by tapping the checkmark in the upper right corner, close the settings panel and save the document.
Next time you open this document you will need to enter the password.
![Open protected file](/images/Help/Mobile/Documents/Android/fileencryption_open.png)
To change or delete the password in the Document Editor:
- Tap the
- Tap the
- Erase the password and disable the Set password switcher to delete the password.
- Enter and verify the new password to change it.
