Download the presentation
To download the current presentation, opened in the Clouds section, to your device,
- tap the
Tools icon in the right corner of the top toolbar,
- tap the
Download menu item,
- tap one of the available file formats: PPTX, PDF, PDF/A, ODP, POTX, OTP.
The file will be downloaded and stored on your device.
Export the presentation
To export a presentation to your device, you should locally open the file by tapping on it in the On Device section and follow these steps:
- tap the
- tap the
Export menu item,
- tap one of the available file formats: PPTX, PDF, ODP, POTX, PDF/A, OTP,
- specify the path where the file will be saved. It can be either the same device or a cloud storage.
