Control Panel
v3.5
ONLYOFFICE Control Panel changelog
Version 3.5
Release date: 03/14/2023
- Changed API methods for migration, implemented progressQueue.
- Changed settings for connecting third-party storages. Added tooltips for fields. Added the 'Server Side Encryption Method' block for Amazon AWS S3.
- Added logos for dark theme in the Branding section. Logos for the About page are now separate fields in the Advanced tab.
- Added the ability to set the portal memory quota.
Version 3.1
Release date: 05/25/2022
- Fixed bugs.
Version 3.0
Release date: 06/07/2021
Version 2.9.1
Release date: 12/10/2020
Version 2.9
Release date: 10/14/2020
- Updated
node.js
, updated packages (transition to samlify
for SSO);
- Added the
upgrade
page with a proposal to upgrade to Enterprise Edition;
- Added the
activate
page with a possibility to upload a license file;
- Transition to the new
samlify
library;
Version 2.7
Release date: 04/25/2019
Version 2.5.1
Release date: 04/07/2018
- Fixed the
Server internal error
error when using the groups enclosed inside each other in the AD (bug #37414).
Version 2.4.0
Release date: 01/13/2018
- Fixed the
Invalid ssoConfig
error which occurred when the link to the IdP contained the question mark '?', e.g.: IdP Single Sign-On Endpoint URL: https://accounts.google.com/o/saml2/idp?idpid=777777
- Fixed the
Invalid authentication token
error which prevented from adding a user to the portal using the AD FS, in case the +
or -
characters were present when sending the encrypted data.
Version 2.3.0
Release date: 12/15/2017
Audit Trail
heading was present at the login history page (bug #36026);
- Fixed the bug with the
LDAP Domain not found
error which occurred if the DN record had no DC records (the users with Sun/Oracle DS were affected); now if the LDAP domain could not be specified, the LDAP domain will acquire the unknown
value or the ldap.domain
value from the web.appsettings.config
configuration file;
Sizelimit Exceeded
error when trying to get more than 1000 users from the Active Directory;
- Added additional logging;
Mail Attribute
Version 2.2.0
Release date: 10/31/2017
- Added the
documentserver-prepare4shutdown.sh
script launch when updating the document-server for the correct edited document saving.
- Added the AD FS support;
Version 2.1.0
Release date: 07/03/2017
- Added the new
sso.auth
service;
Version 2.0.0
Release date: 05/25/2017
MVC
to Node.js
Version 1.6.0
Release date: 12/05/2016
- Added new translations;
- Bug fixes.
Introduction
La fonctionnalité Authentification unique (Single Sign-on) est disponible depuis le Panneau de configurationSi cette fonctionnalité est inclus dans votre forfait pour le bureau en ligne, la section Authentification unique (Single Sign-on) permet d'activer les services d'authentification tiers en utilisant les services SSO disponibles (Shibboleth, OneLogin, ou Active Directory Federation Services).Le protocole SAML fournit un accès rapide, facile et sécurisé pour les utilisateurs du portail.
En général, Authentification unique ou Single Sign-On (SSO) est la fonction qui permet aux utilisateurs de s'authentifier une seule fois et d'obtenir accès à plusieurs applications/services autorisés sans contrainte de renseigner à nouveau les informations d'identification. Par ex., quand un portail web comprend plusieurs sections indépendantes (forum, chat, blogue etc.), une fois connecté à un service, l'utilisateur est automatiquement connecté aux autres et n'a plus besoin de se connecter aux différentes applications une par une.
La technologie d'authentification unique repose sur l'opération conjointe de deux applications: le fournisseur d'identité et le fournisseur de service (ci-après dénommées IdP et SP).
L'authentification unique ONLYOFFICE est réalisé uniquement en tant que fournisseur de service. Plusieurs fournisseurs peuvent intervenir en tant que fournisseur d'identité, mais ONLYOFFICE a été testé seulement auprès des service suivants: Shibboleth, OneLogin et AD FS.
Les avantages d'authentification unique (SSO):
- Facilité d'usage. Les utilisateurs ont l'accès rapide et facile et n'ont donc plus besoin de retenir plusieurs mots de passe.
- Niveau de sécurité accru. ONLYOFFICE ne sauvegarde pas les mots de passe de ses utilisateurs et utilise plutôt le résultat de l'authentification de l'utilisateur qui est en charge du fournisseur d'identité.
- Gestion facile. Des jetons d'accès, ou tokens, permettent d'échanger des informations. Une fois modifiés dans le système du fournisseur d'identité, les données d'utilisateur seront automatiquement mis à jour sur le portail pendant l'authentification unique suivante. Si le profil d'utilisateur est manquant, ce-ci sera crée automatiquement lorsque l'utilisateur se connecte au portail pour la première fois en utilisant les informations d'identification SSO.
Pour l'authentification unique ONLYOFFICE utilise le standard SAML, le standard le plus sécurisé et répandu. SAML (Security Assertion Markup Language) est un standard basé sur le langage XML permettant d'échanger des informations d'identification/authentification entre le fournisseur d'identité et le fournisseur de service en utilisant des jetons d'accès qui comportent assertions.
Cet article donne une description général de l'activation d'authentification unique. Si vous avez besoin de paramètres spécifiques/exemples pour les certains fournisseurs d'identité, veuillez consulter les instructions de configuration du fournisseur de service ONLYOFFICE et Shibboleth, OneLogin, ou AD FS IdP.
Activation d'authentification unique
Pour activer et configurer l'authentification unique sur votre portail, il faut procéder comme suit:
- Enregistrez votre fournisseur d'identité depuis le Panneau de configuration ONLYOFFICE -> Authentification unique. Tous les informations obligatoires vous pouvez retrouver sur votre compte chez fournisseur d'identité.
Si vous souhaitez utiliser l'authentification unique pour connecter ONLYOFFICE Desktop Editors à votre , désactivez Salles privées depuis le Panneau de configuration.
- Sur votre compte chez fournisseur d'identité, enregistrez ONLYOFFICE en tant que fournisseur de service fiable. Cette procédure varie en fonction du fournisseur d'identité sélectionné.
Chaque portail peut être intégré dans le système d'un seul fournisseur d'identité.
Enregistrer le fournisseur d'identité dans le système du fournisseur de service ONLYOFFICE
Pour enregistrer votre fournisseur d'identité depuis le fournisseur de service ONLYOFFICE, accédez à la section Paramètres du fournisseur de service ONLYOFFICE sur la page Authentification unique.
Le Fournisseur d'identité (IdP) crée, maintient et gère des informations d'identification utilisateur et est en charge d'authentification d'utilisateurs des fournisseurs de services associés. Tels services que OneLogin, ADFS etc. sont les fournisseur d'identité. Le Fournisseur de service (SP) fournit les services web et délègue au fournisseur d'identité la responsabilité de l'authentification. Dans ce cas, ONLYOFFICE est le fournisseur de service.
Vous pouvez utiliser l'authentification unique via le protocole SAML pour échanger des informations d'identification/authentification entre le fournisseur d'identité et le fournisseur de service:
- SAML (Security Assertion Markup Language) est un standard basé sur le langage XML permettant d'échanger des informations d'identification/authentification entre le fournisseur d'identité et le fournisseur de service en utilisant des jetons d'accès qui comportent assertions.
Le niveau de sécurité accru est assuré grâce au fait que le bureau en ligne ne sauvegarde pas les mots de passe d'utilisateurs et utilise plutôt le résultat de l'authentification de l'utilisateur qui est en charge du fournisseur d'identité. Des jetons d'accès, ou tokens, permettent d'échanger des informations. Une fois modifiés dans le système du fournisseur d'identité, les données d'utilisateur seront automatiquement mis à jour sur le portail pendant l'authentification unique suivante (veuillez noter que la synchronisation de données est unidirectionnelle: de fournisseur d'identité à fournisseur de service).
Une fois le fournisseur d'identité et le bureau en lignes dûment configurés, l'authentification unique sera réalisée dans le système du fournisseur d'identité. Le fournisseur d'identité émet au bureau en ligne un jeton d'accès (SAMP). Une fois le jeton validé (en utilisant les signatures numériques et la durée de vie de jeton), le bureau en ligne permet l'accès aux utilisateurs du portail.
Pour activer et configurer l'authentification unique sur votre portail, procédez comme suit:
Vérifiez la configuration du Fournisseur d'identité avant se mettre à paramétrer le Fournisseur de service.
- Sur votre portail ONLYOFFICE, passez au Panneau de configuration et accédez à la page Authentification unique depuis la section PARAMÈTRES DU PORTAIL sur la barre latérale gauche. Passez à la page Paramètres. Pour ce faire, cliquez sur l'icône
dans le coin supérieur gauche.
- Dans la section Intégration de la barre latérale gauche, cliquez sur Authentification unique.
- Activez l'option Activer l'authentification unique. Activez l'optionActiver l'authentification unique au-dessous du titre section Authentification unique.
- Remplissez les champs obligatoires depuis la section Les paramètres du fournisseur de service ONLYOFFICE. Il est possible de fournir les informations obligatoires de différentes façons:
- Saisissez l'adresse URL vers le fichier de métadonnées. S'il est possible d'accéder aux métadonnées du fournisseur d'identité de l'extérieur, insérez le lien dans le champ L'URL vers le fichier XML de métadonnées et cliquez sur la flèche Télécharger les données pour charger les données. Une fois les données chargés, tous les champs obligatoires du formulaire seront remplis automatiquement.
- Charger un fichier de métadonnées. Si votre fournisseur d'identité met à la disposition un fichier de métadonnées, utiliser le bouton Sélectionner fichier pour rechercher le fichier sur votre disque local. Une fois le fichier chargé, tous les champs obligatoires du formulaire seront remplis automatiquement.
- Configurer les paramètres manuellement. Si aucun fichier de métadonnées n'est disponible, configurez les paramètres manuellement. Veuillez contacter l'administrateur du fournisseur d'identité pour obtenir tous les données nécessaires.
Les paramètres disponibles:
- ID d'entité du fournisseur d'identités (champ obligatoire) - l'identifiant ou l'adresse URL du fournisseur d'identité que le fournisseur de service va utiliser pour identifier fournisseur d'identité sans équivoque.
https://example.com/idp/shibboleth
où, example.com est le nom de domaine de votre service d'authentification unique
- URL du point de terminaison d'authentification unique IdP (champ obligatoire) - l'URL qui est utilisé pour l'authentification unique sur le côté du fournisseur d'identité. C'est l'adresse de terminaison du fournisseur d'identité à laquelle le fournisseur de service envoie les requêtes d'authentification.
Sélectionnez le type de Liaison en cochant le bouton radio approprié. Liaison détermine le méthode de requête d'authentification et de réponse entre le fournisseur d'identité et le fournisseur de service via le protocole de transport utilisé: HTTP POST ou HTTP Rediriger.
- URL du point de terminaison de déconnexion unique IdP - l'URL qui est utilisé pour une déconnexion unique sur le côté du fournisseur de service. C'est l'adresse de terminaison du fournisseur d'identité à laquelle le fournisseur de service envoie les requêtes/réponses de déconnexion.
Sélectionnez le type de Liaison en cochant le bouton radio approprié. Liaison détermine le méthode de requête de déconnexion et de réponse entre le fournisseur d'identité et le fournisseur de service via le protocole de transport utilisé: HTTP POST ou HTTP Rediriger.
- Format de NameID - le paramètre NameID permet au fournisseur de service d'identifier l'utilisateur. Sélectionnez le format approprié de la liste des formats prédéfinis.
Il est possible de personnaliser de bouton de connexion au portail avec le service d'authentification unique sur la page d'authentification ONLYOFFICE. Pour personnaliser le bouton, remplissez le champ Légende personnalisée du bouton de connexion depuis la section Les paramètres du fournisseur de service ONLYOFFICE.
Vous pouvez également ajouter les certificats publics du fournisseur d'identités et du fournisseur de service.
Certificats publics du fournisseur d'identités
Certificats publics du fournisseur d'identités cette section permet d'ajouter les certificats publics du fournisseur d'identité qui sont utilisés par le fournisseur de service pour la vérification des requêtes et des réponses envoyées par le fournisseur d'identité.
Une fois les métadonnées du fournisseur d'identité téléchargés, ces certificats seront ajoutés automatiquement au Panneau de configurationde votre portail . Sinon, vous pouvez retrouver les certificats sur votre compte chez fournisseur d'identité. Pour ajouter un certificat manuellement, cliquez sur le bouton Ajouter un certificat. La fenêtre Nouveau certificat s'affiche. Saisissez le certificat dans le champ Certificat public et cliquez sur OK.
Activez les options appropriées pour paramétrer les certificats.
Définissez les signatures de requêtes/réponses que le fournisseur d'identité envoie au fournisseur de service à vérifier.
- Vérifier la signature des réponses d'authentificationVérifier la signature des réponses d'authentification - pour vérifier les signatures des réponses d'authentification SAML envoyées au fournisseur de service.
- Vérifier la signature des demandes de déconnexionVérifier la signature des demandes de déconnexion - pour vérifier les signatures des demandes de déconnexion SAML envoyées au fournisseur de service.
- Vérifier les réponses de la signature de déconnexionVérifier les réponses de la signature de déconnexion - pour vérifier les signatures des réponses de déconnexion SAML envoyées au fournisseur de service.
Sélectionnez l'algorithme approprié de la liste Algorithme de la vérification de signature par défautAlgorithme de la vérification de signature par défaut : rsa-sha1
, rsa-sha256
or rsa-sha512
Les paramètres par défait sont appliqués uniquement si les métadonnées du fournisseur d'identité n'ont pas du mention sur l'algorithme utilisé.
Vous pouvez modifier ou supprimer les certificats ajoutés en utilisant les options appropriées.
Certificats publics du fournisseur de service
Certificats publics du fournisseur de service cette section permet d'ajouter les certificats publics qui sont utilisés pour signer et chiffrer les requêtes et les réponses du fournisseur de service.
Si votre fournisseur d'identité exige que des données d'entrée soient signés et/ou chiffrés, créez ou ajoutez les certificats appropriés depuis cette section.
Cliquez sur le bouton Ajouter un certificat. La fenêtre Nouveau certificat s'affiche. Vous pouvez générer un nouveau certificat auto-signé ou ajouté un certificat existant dans le champ Certificat public et la clé privée dans le champ Clé privée. Dans la liste déroulante Utiliser pour, sélectionnez l'une des options disponibles: signature
, chiffrer
, signature et chiffrement
. Une fois que vous avez terminé, cliquez sur OK.
Les paramètres supplémentaires qui sont définis pendant le téléchargement/la génération du certificat dépendent du but choisi de la liste Utiliser pour. Les options ci-dessous sont utilisées pour définir les requêtes/réponses qui sont envoyées par le fournisseur de service au fournisseur d'identité à signer:
- Signer la demande de connexionSigner la demande de connexion - le fournisseur de service doit signer la requête d'authentification SAML envoyée au fournisseur d'identité.
- Signer la demande de déconnexion - le fournisseur de service doit signer la demande de déconnexion SAML envoyée au fournisseur d'identité.
- Signer les réponses de fermeture de session - le fournisseur de service doit signer les réponses de fermeture de session SAML envoyées au fournisseur d'identité.
Si vous avez sélectionné les options chiffrer
ou signature et chiffrement
dans la liste Utiliser pour, l'option Déchiffrer les assertions est activée. La Clé privée appropriée est utilisée pour le déchiffrement.
Sélectionnez les algorithmes appropriés dans la liste:
- Algorithme de signature:
rsa-sha1
, rsa-sha256
or rsa-sha512
- Algorithme de déchiffrement par défautAlgorithme de déchiffrement par défaut:
aes128-cbc
, aes256-cbc
or tripledes-cbc
Mappage d'attributs
Mappage d'attributs - cette section permet de synchroniser les données du module ONLYOFFICE Personnes avec les attributs renvoyés par le fournisseur d'identité. Lorsque l'utilisateur se connecte au fournisseur de service ONLYOFFICE en utilisant les informations d'identification SSO, le fournisseur de service ONLYOFFICE reçoit des attributs et remplit les champs Nom complet et Adresse email selon des renseignements fournis par le fournisseur d'identité. Si le profil utilisateur est manquant sur le module Personnes, ce-ci sera crée automatiquement. Une fois modifiés dans le système du fournisseur d'identité, les données d'utilisateur seront automatiquement mis à jour dans le système du fournisseur de service.
Les attributs disponibles sont les suivantes:
- Prénom (champ obligatoire) - l'attribut de la fiche d'utilisateur correspondant au prénom d'utilisateur.
- Nom (champ obligatoire) - l'attribut de la fiche d'utilisateur correspondant au nom d'utilisateur.
- Email (champ obligatoire) - l'attribut de la fiche d'utilisateur correspondant à l'adresse e-mail d'utilisateur.
- Emplacement (champ obligatoire) - l'attribut de la fiche d'utilisateur correspondant à l'emplacement d'utilisateur.
- Titre - l'attribut de la fiche d'utilisateur correspondant au titre d'utilisateur.
- Téléphone - l'attribut de la fiche d'utilisateur correspondant au numéro de téléphone d'utilisateur.
Paramètres avancés
L'option Masquer une page d'authentification permet de masquer la page d'authentification par défaut et rediriger vers le service d'authentification unique.
ImportantSi vous souhaitez restaurer la page d'authentification (pour pouvoir accéder à votre portal quand le serveur de votre fournisseur d'identité tombe en panne), vous pouvez ajouter la clé /Auth.aspx?skipssoredirect=true
après le nom de domaine de votre portail dans la barre d'adresse du navigateur.
Une fois paramétré depuis le Panneau de configurationdu portail, cliquez sur Enregistrer. La section Les métadonnées du fournisseur de service ONLYOFFICE s'affiche.
Enregistrer ONLYOFFICE en tant que fournisseur de service fiable.
Maintenant, il faut ajouter ONLYOFFICE en tant que fournisseur de service fiable depuis votre compte chez fournisseur d'identifiant en fournissant les métadonnées du fournisseur de service ONLYOFFICE à votre fournisseur d'identifiant.
Pour obtenir les informations nécessaires, veuillez consultez la section Les métadonnées du fournisseur de service ONLYOFFICE sur la page Authentification unique. Vérifiez si les données du fournisseur de service sont rendues publiques. Pour ce faire, cliquez sur le bouton Télécharger le fichier XML des métadonnées du fournisseur de service. Le contenu du fichier s'affiche dans un onglet de navigateur. Sauvegardez les données en tant qu'un fichier XML afin de le télécharger à votre fournisseur d'identifiant.
Vous pouvez également copier les paramètres appropriés manuellement en cliquant Copier dans le presse-papiers dans les champs appropriés.
- ID d'entité du fournisseur de service (lien vers le fichier XML des métadonnées) - l'adresse URL du fichier XML du fournisseur de service afin que le fournisseur d'identité puisse identifier sans équivoque le fournisseur de service. Par défaut, l'adresse de fichier est comme suit: http://example.com/sso/metadata où example.com est le nom de domaine ONLYOFFICE ou l'adresse IP publique.
- URL du service d'assertion ACS du fournisseur de service (support du POST et redirection de liaison) - l'adresse URL de réception et traitement des assertions envoyées par le fournisseur d'identité. L'adresse par défaut est: http://example.com/sso/acs où example.com est le nom de domaine ONLYOFFICE ou l'adresse IP publique.
- URL d'une déconnexion unique du fournisseur de service (support de POST et de liaison de redirection) - l'URL qui est utilisé pour une déconnexion unique sur le côté du fournisseur d'identité. C'est l'adresse de terminaison du fournisseur de service à laquelle le fournisseur d'identité envoie les requêtes/réponses de déconnexion. L'adresse par défaut est: http://example.com/sso/slo/callbackoù example.com est le nom de domaine ONLYOFFICE ou l'adresse IP publique.
Les paramètres et le contenu du fichier XML varient en fonction de la configuration du portail, par ex. lorsque vous passez au protocole HTTPS ou définissez le nom de domaine, les paramètres seront aussi modifiés, alors il faudra configurer à nouveau votre fournisseur d'identité.
Se connecter au fournisseur de service ONLYOFFICE
Une fois l'authentification unique activé et paramétré, la connexion se fait comme suit:
- L'utilisateur demande accès à ONLYOFFICE en cliquant sur le bouton Authentification unique (le texte sur le bouton peut différer si vous avez personnalisé le bouton pendant la configuration du fournisseur de service ONLYOFFICE) sur la page d'authentification ONLYOFFICE (authentification unique initié par le fournisseur de service).
- Si le fournisseur d'identité et le fournisseur de service sont paramétrés correctement, ONLYOFFICE envoie la requête d'authentification au fournisseur d'identité et redirige l'utilisateur vers la page du fournisseur d'identité où il faut saisir ses informations d'identification.
- Si l'utilisateur n'est pas encore connecté au fournisseur d'identité, il faut saisir ses informations d'identification chez fournisseur d'identité.
- Le fournisseur d'identité crée la requête d'authentification comportant les données d'utilisateur et l'envoie à ONLYOFFICE.
- ONLYOFFICE reçoit la réponse d'authentification du fournisseur d'identité et la valide.
- Une fois la réponse validé, ONLYOFFICE autorise l'utilisateur à se connecter (l'utilisateur manquant est créé automatiquement, ou les données sont mis à jour si le fournisseur d'identité a apporté des modifications).
Il est aussi possible de se connecter sur la page d'authentification du fournisseur d'identité (authentification unique initié par le fournisseur d'identité), saisir les information d'authentification et ensuite accéder à ONLYOFFICE sans avoir besoin de renseigner à nouveau l'identifiant et le mot de passe.
Se déconnecter du fournisseur de service ONLYOFFICE
Il y a deux façons de se déconnecter:
- Depuis le portail ONLYOFFICE en utilisant le menu Déconnexion (dans ce cas la requête de déconnexion est envoyé par le fournisseur d'identité). L'utilisateur sera déconnecté automatiquement du fournisseur d'identité lorsqu'il est déconnecté de toutes les applications déjà accédées via l'authentification unique.
- Depuis la page de déconnexion du fournisseur d'identité.
Modifier les profils utilisateur créés via l'authentification unique
Les profils des utilisateurs qui sont créés via l'authentification unique seront indiqués à l'aide d'icône SSO pour l'administrateur du portail.
La possibilité de modifier tels profils dans le module Personnes est limitée. Les champs qui étaient rempli en utilisant l'authentification unique sont désactivés et on ne peut pas les modifier depuis le module Personnes. On peut modifier les données d'utilisateur uniquement sur le côté du fournisseur d'identité.
