Fermer Centre d'aide Control Panel Configuration du portail Updating ONLYOFFICE Groups for Windows to the latest version Connecter ONLYOFFICE Docs à ONLYOFFICE Groups Guides d'administration ONLYOFFICE Workspace Gestion des portails Renforcement de la sécurité Configuration des modules et des outils Personnalisation des modules et des outils Gestion des utilisateurs Connexion à des services externes Panneau de configuration ONLYOFFICE Glossaire Video F.A.Q. Général Technologie Tarification Workspace Enterprise Edition Docs Enterprise Edition Docs Developer Edition ONLYOFFICE Groups Connectors Mettre à jour ONLYOFFICE Workspace vers la dernière version Control Panel v3.5 ONLYOFFICE Control Panel changelog Open in new window Version 3.5 Release date: 03/14/2023 General Changed API methods for migration, implemented progressQueue. Changed settings for connecting third-party storages. Added tooltips for fields. Added the 'Server Side Encryption Method' block for Amazon AWS S3. Added logos for dark theme in the Branding section. Logos for the About page are now separate fields in the Advanced tab. Added the ability to set the portal memory quota. Version 3.1 Release date: 05/25/2022 General Added the Data Import page that allows to import data from Nextcloud, ownCloud and GoogleWorkspace to ONLYOFFICE Workspace. Moved Elasticsearch to a separate container. Fixed bugs. Version 3.0 Release date: 06/07/2021 Update License agreement dialog when installing docker components added. The inactive button with an action for uninstalled components (downloading and installing the available version) fixed. Search Indexing progress display added. LoginHistory and AuditTrail New empty screens added. Restore New checks when restoring data from a local or a 3rd party storage. SSO SSOAuth was removed from Control Panel. It's now available as a portal setting in Community Server. General improvements and bug fixes Bugs 47721, 49101, 49187, 49273, 49272, 49324, 46386, 49585 from the internal bugtracker fixed. 3rd party licenses and copyright updated. Version 2.9.1 Release date: 12/10/2020 Bug fixes Bug Fixes & Performance Improvements. Version 2.9 Release date: 10/14/2020 General Control Panel is available in the free Community version with all settings excepting the editors logo replacement; Added the vsyscall check to the installation scripts when installing Mail Server on Debian with kernel 4.18.0 and later; Redesign of the navigation menu: added Common and Portal settings sections, added icons to menu items; Added the advanced rebranding page in the Common Settings; Added the possibility to reindex the full-text search; Updated node.js, updated packages (transition to samlify for SSO); Added the Encryption at rest block in the Storage section; Added the Private Room section for the server version only; Added the upgrade page with a proposal to upgrade to Enterprise Edition; Added the activate page with a possibility to upload a license file; Added the HideAuthPage option to the SSO settings to hide the authorization page. When the HideAuthPage option is enabled, an automatic redirect from the authorization page to the SSO service will occur. LDAP Added the Sign in to domain option on the authorization page. Single Sign-on Transition to the new samlify library; Added the HideAuthPage option to the SSO settings to hide the authorization page. When the HideAuthPage option is enabled, an automatic redirect from the authorization page to the SSO service will occur. Version 2.7 Release date: 04/25/2019 LDAP Added more fields mapped for the users loaded via LDAP: user photo, birthday, contacts, primary phone number; Added the setting to autosync LDAP on schedule; Added the possibility to give administrator rights to the user group at the portal via LDAP; Updated the rules for LDAP users. Version 2.5.1 Release date: 04/07/2018 LDAP Fixed the Server internal error error when using the groups enclosed inside each other in the AD (bug #37414). Single Sign-on Fixed the issue when the user data between the Service Provider and the portal was transferred via HTTP only, even when HTTPS was enabled. Version 2.4.0 Release date: 01/13/2018 Single Sign-on Fixed the Invalid ssoConfig error which occurred when the link to the IdP contained the question mark '?', e.g.: IdP Single Sign-On Endpoint URL: https://accounts.google.com/o/saml2/idp?idpid=777777; Fixed the Invalid authentication token error which prevented from adding a user to the portal using the AD FS, in case the + or - characters were present when sending the encrypted data. Version 2.3.0 Release date: 12/15/2017 General Added the changelog for Control Panel and link to it; Fixed the bug when JWT parameters were not sent when updating Document Server(bug #36270); Fixed the bug when Audit Trail heading was present at the login history page (bug #36026); The current machine is now checked for being linked with the domain name for multiple portals. LDAP Fixed the bug with the LDAP Domain not found error which occurred if the DN record had no DC records (the users with Sun/Oracle DS were affected); now if the LDAP domain could not be specified, the LDAP domain will acquire the unknown value or the ldap.domain value from the web.appsettings.config configuration file; Fixed the bug with the Sizelimit Exceeded error when trying to get more than 1000 users from the Active Directory; Increased the login speed with the Group Membership setting enabled; Added additional logging; Fixed the bug with LDAP operation hanging when using Mono v5.2.0 and older; Fixed the bug with the error when trying to login using the email address entered in the fields different from the Mail Attribute; Fixed the bug occurring in the enclosed groups, when the users were displayed not in all groups. Version 2.2.0 Release date: 10/31/2017 General Added the documentserver-prepare4shutdown.sh script launch when updating the document-server for the correct edited document saving. LDAP Dramatically changed LDAP integration, migrated to the single library for the work with LDAP (Novell.Directory.Ldap.NETStandard, Nuget, MIT); Login and email are now split into two separate fields; Added the support for big data; Increased the work speed via the LDAP protocol (the connection to the server and receiving the data is now made once per session, added the limits when only a certain number of results is necessary, fixed the slow login for bit data, removed the sorting out used to find the SID parameter); Fixed the user re-creation issue; Fixed the duplicate username issue; Fixed the already existing email issue; Replaced the LDAP user deletion with account deactivation (for further data migration and data safety); Instead of re-creating a user with an unknown SID but an existing email the data is updated; Added the attempt to save the correct UserName/Login in case a similar one is already taken on the portal. Single Sign-on Added the AD FS support; Replaced the Single Sign-on link at the authorization page with the customizable button, added the button customization to the SSO setting of the Control Panel. Version 2.1.0 Release date: 07/03/2017 HTTPS Added the support of letsencrypt service for the domain certificate generation. Single Sign-on Added the new sso.auth service; Added the new SSO settings page; Added the support for Shibboleth. Version 2.0.0 Release date: 05/25/2017 General The Control Panel migrated from MVC to Node.js. Version 1.6.0 Release date: 12/05/2016 LDAP Added LDAP synchronization for users and groups when saving the settings, after login and using the Sync button; Changed email formation for LDAP users; Fixed the problem of creation of users with invalid emails; Fixed the problem of duplicate users; Added icons and hints to the users in the list for the admin; Blocked for editing the user profile fields imported using LDAP; Added the real LDAP password saving to the database during login in case LDAP Auth is disabled, now the LDAP users will become common portal users when LDAP Auth is disabled; Added new API Settings method - Sync LDAP; Added new translations; Bug fixes. Version for Windows Made changes at the Update page for the Control Panel for Windows; Updates are performed using the downloaded installation packages for each module. The current installed component version numbers are obtained via API request to the Community Server. The new versions available for download are obtained via the request to the https://download.onlyoffice.com/install/windows/updates.txt file, where all the latest component version numbers and links for their download are stored in the JSON format. version serveur Comment déployer la suite bureautique en ligne sur votre serveur ? Installer ONLYOFFICE Workspace Enterprise Edition sous Windows sur un serveur local Compiler ONLYOFFICE Groupes et un serveur local Migrer de version Cloud vers la version serveur Migrer ONLYOFFICE Groupes sous Windows vers Linux Updating ONLYOFFICE Groups for Windows to the latest version Migrating from ONLYOFFICE Workspace to Enterprise Edition on Windows More articles Comment mettre à niveau ONLYOFFICE Workspace Enterprise Edition vers la dernière version? Connecter ONLYOFFICE Docs à ONLYOFFICE Groups Switching ONLYOFFICE Talk to TLS protocol on Windows version Intégrer des services tiers au version serveur Ajouter ONLYOFFICE Mail au paquet d'installation ONLYOFFICE Workspace Mettre à jour ONLYOFFICE Workspace vers la dernière version Utilisation de la fonctionnalité de sauvegarde/restauration à partir de Panneau de configuration Protéger des données à l'aide du chiffrement Connecter des services de stockage externes Naviguer plus vite avec la recherche en plein texte Branding votre office en ligne Passer en HTTPS à l'aide du Panneau de configuration Réglage des paramètres LDAP Déployer plusieurs portails en utilisant l'architecture mutualisée Utiliser la Salle Privée pour travailler sur vos documents en sécurité Private Rooms in ONLYOFFICE Workspace for Secure Collaboration on Documents How to use Control Panel in ONLYOFFICE Workspace How to use the backup/restore feature Aperçu d'authentification unique ONLYOFFICE Configurer le fournisseur de service ONLYOFFICE et le fournisseur d'identité Shibboleth Configurer le fournisseur de service ONLYOFFICE et le fournisseur d'identité OneLogin Configurer le fournisseur de service ONLYOFFICE et le fournisseur d'identité AD FS Suivre l'histoire de connexion Réception des données de la piste d'audit Comment commencer à travailler avec ONLYOFFICE Workspace Enterprise Edition? Comment acheter un plan ONLYOFFICE Workspace Enterprise Edition Server? Utilisation de ONLYOFFICE Docs via un serveur proxy Configurer le JWT pour ONLYOFFICE Docs Languages available for ONLYOFFICE Docs interface Languages available for ONLYOFFICE Groups interface Ajouter des modules personnalisés à ONLYOFFICE Groupes Créer API des modules personnalisés ONLYOFFICE Groupes Créer un serveur WebDAV sur Ubuntu et connecter ONLYOFFICE Créer un serveur WebDAV sur Windows et connecter ONLYOFFICE Installer ONLYOFFICE Workspace sous Windows sur un serveur local ONLYOFFICE Groups Windows Version Troubleshooting F.A.Q. ONLYOFFICE Groups Installer ONLYOFFICE Docs Community Edition sous Windows sur un serveur local Installer ONLYOFFICE Docs Enterprise Edition sous Windows sur un serveur local Installer ONLYOFFICE Docs Developer Edition sous Windows sur un serveur local Connecter ONLYOFFICE Docs à ONLYOFFICE Groups Comment passer votre bureau en HTTPS sous Windows? Ajouter nouveaux polices, langues et correcteurs orthographiques à ONLYOFFICE Docs Supprimer des polices inutilisées de ONLYOFFICE Docs Ajouter de nouveaux thèmes à ONLYOFFICE Docs Presentation Editor ONLYOFFICE Docs Windows version troubleshooting Faire passer ONLYOFFICE Docs Enterprise Edition vers le protocole HTTPS Mettre à jour ONLYOFFICE Docs sous Developer Edition Windows vers la dernière version Mettre à jour ONLYOFFICE Docs sous Enterprise Edition Windows vers la dernière version Mettre à jour ONLYOFFICE Docs sous Community Edition Windows vers la dernière version Installer ONLYOFFICE Groupes sur Debian, Ubuntu et dérivés Installer ONLYOFFICE Groupes sur Red Hat, CentOS et dérivés Migrer ONLYOFFICE Groupes sous Windows vers Linux Migrer ONLYOFFICE Groupes sous Docker vers Linux Migrer ONLYOFFICE Groupes sous Linux vers Docker Updating ONLYOFFICE Groups for Linux to the latest version Mettre à jour ONLYOFFICE Docs Community Edition sous Linux vers la dernière version Connecter ONLYOFFICE Docs à ONLYOFFICE Groups Faire passer ONLYOFFICE Groupes en HTTPS Comment passer en HTTPS lors de l'installation depuis des paquets RPM/DEB? Switching ONLYOFFICE Talk to TLS protocol on Linux version ONLYOFFICE Groups Linux version troubleshooting Lancer ONLYOFFICE Docs Community Edition avec Podman sur Fedora Lancer ONLYOFFICE Docs Enterprise Edition avec Podman sur Fedora Lancer ONLYOFFICE Docs Developer Edition avec Podman sur Fedora Compiler ONLYOFFICE Docs sur un serveur local Installer ONLYOFFICE Docs Community Edition sur Debian, Ubuntu et ses dérivés Installer ONLYOFFICE Docs Enterprise Edition sur Debian, Ubuntu et ses dérivés Installer ONLYOFFICE Docs Developer Edition sur Debian, Ubuntu et ses dérivés Installer ONLYOFFICE Docs Community Edition sous CentOS et ses dérivés Installer ONLYOFFICE Docs Enterprise Edition sous CentOS et ses dérivés Installer ONLYOFFICE Docs Developer Edition sous CentOS et ses dérivés Installer ONLYOFFICE Docs Community Edition sur Linux à partir de Snap Connecter ONLYOFFICE Docs à ONLYOFFICE Groups Ajouter des polices à ONLYOFFICE Docs Faire passer ONLYOFFICE Docs en HTTPS Ajouter une nouvelle langue d'interface à ONLYOFFICE Docs Ajouter de nouveaux thèmes à ONLYOFFICE Docs Presentation Editor ONLYOFFICE Docs Linux version troubleshooting Mettre à jour ONLYOFFICE Docs Developer Edition sous Docker vers la dernière version Mettre à jour ONLYOFFICE Docs Enterprise Edition sous Docker vers la dernière version Mettre à jour ONLYOFFICE Docs Community Edition sous Docker vers la dernière version Installer ONLYOFFICE Groupes pour Docker sur un serveur local Installer ONLYOFFICE Workspace à l'aide de Docker Compose Migrer ONLYOFFICE Groupes sous Docker vers Linux Migrer ONLYOFFICE Groupes sous Linux vers Docker Installer tous les composants ONLYOFFICE Workspace Comment mettre à niveau votre ONLYOFFICE Groupes sur Docker vers la dernière version? Migrating from ONLYOFFICE Workspace to Enterprise Edition using Docker script Utiliser des ports supplémentaires avec ONLYOFFICE Groups Connecter la base de donnée MySQL à ONLYOFFICE Groupes Lancer ONLYOFFICE Groupes à l'aide de HTTPS Configurer le serveur derrière un NAT Supprimer ONLYOFFICE Groupes sous Docker de votre ordinateur ONLYOFFICE Groups Docker version troubleshooting Installer ONLYOFFICE Docs pour Docker sur un serveur local Installer ONLYOFFICE Docs Enterprise Edition pour Docker sur un serveur local Installer ONLYOFFICE Docs Developer Edition pour Docker sur un serveur local Utilisez le script pour installer Community Edition ONLYOFFICE Docs Utilisez le script pour installer Enterprise Edition ONLYOFFICE Docs Utilisez le script pour installer Developer Edition ONLYOFFICE Docs Lancer ONLYOFFICE Docs à l'aide de Docker Compose Installer tous les composants ONLYOFFICE Workspace Ajouter une nouvelle langue d'interface à ONLYOFFICE Docs Supprimer ONLYOFFICE Docs sous Docker de votre ordinateur ONLYOFFICE Docs Docker version troubleshooting Installer ONLYOFFICE Mail sous Docker sur un serveur local Installer tous les composants ONLYOFFICE Workspace Mettre à jour ONLYOFFICE Mail intégré dans ONLYOFFICE Groupes Connecter ONLYOFFICE Mail à ONLYOFFICE Groupes sur Windows Connecter ONLYOFFICE Mail à ONLYOFFICE Groupes dans les paramètres du portail Connecter ONLYOFFICE Mail à ONLYOFFICE Groupes sur Linux Modifier le domaine associé à ONLYOFFICE Mail Exécuter un script externe après le démarrage du conteneur Docker ONLYOFFICE Mail Créer des boîtes mail dans ONLYOFFICE Mail en utilisant le script Modifier les mots de passe des boîtes mail ONLYOFFICE Mail en utilisant le script Synchroniser l'ancienne et la nouvelle boîte mail en utilisant le script Supprimer ONLYOFFICE Mail sous Docker de votre ordinateur ONLYOFFICE Mail Docker version troubleshooting Enabling vsyscall on Debian Migrer des données depuis MS Exchange vers ONLYOFFICE Travail avec les modules complémentaires lors de l'utilisation de CSP Travail avec les modules complémentaires lors de l'utilisation de CSP Désinstaller les modules complémentaires par défaut des éditeurs de serveur Ajouter de nouveaux modules complémentaires aux éditeurs de serveur serveur local Ajouter ONLYOFFICE Mail au paquet d'installation ONLYOFFICE Workspace Mettre à jour ONLYOFFICE Workspace vers la dernière version Utilisation de la fonctionnalité de sauvegarde/restauration à partir de Panneau de configuration Protéger des données à l'aide du chiffrement Connecter des services de stockage externes Naviguer plus vite avec la recherche en plein texte Branding votre office en ligne More articles Passer en HTTPS à l'aide du Panneau de configuration Réglage des paramètres LDAP Déployer plusieurs portails en utilisant l'architecture mutualisée Utiliser la Salle Privée pour travailler sur vos documents en sécurité Private Rooms in ONLYOFFICE Workspace for Secure Collaboration on Documents Aperçu d'authentification unique ONLYOFFICE Configurer le fournisseur de service ONLYOFFICE et le fournisseur d'identité Shibboleth Configurer le fournisseur de service ONLYOFFICE et le fournisseur d'identité OneLogin Configurer le fournisseur de service ONLYOFFICE et le fournisseur d'identité AD FS Suivre l'histoire de connexion Réception des données de la piste d'audit How to use Control Panel in ONLYOFFICE Workspace How to use the backup/restore feature Comment commencer à travailler avec ONLYOFFICE Workspace Enterprise Edition? Comment acheter un plan ONLYOFFICE Workspace Enterprise Edition Server? Utilisation de ONLYOFFICE Docs via un serveur proxy Configurer le JWT pour ONLYOFFICE Docs Comment mettre à niveau ONLYOFFICE Workspace Enterprise Edition vers la dernière version? Installer ONLYOFFICE Workspace sous Windows sur un serveur local Comment déployer la suite bureautique en ligne sur votre serveur ? Installer ONLYOFFICE Workspace Enterprise Edition sous Windows sur un serveur local Compiler ONLYOFFICE Groupes et un serveur local Migrer de version Cloud vers la version serveur Migrer ONLYOFFICE Groupes sous Windows vers Linux Updating ONLYOFFICE Groups for Windows to the latest version Migrating from ONLYOFFICE Workspace to Enterprise Edition on Windows Connecter ONLYOFFICE Docs à ONLYOFFICE Groups Comment passer votre bureau en HTTPS sous Windows? Switching ONLYOFFICE Talk to TLS protocol on Windows version Intégrer des services tiers au version serveur ONLYOFFICE Groups Windows Version Troubleshooting F.A.Q. ONLYOFFICE Groups Installer ONLYOFFICE Docs Community Edition sous Windows sur un serveur local Installer ONLYOFFICE Docs Enterprise Edition sous Windows sur un serveur local Installer ONLYOFFICE Docs Developer Edition sous Windows sur un serveur local Connecter ONLYOFFICE Docs à ONLYOFFICE Groups Ajouter nouveaux polices, langues et correcteurs orthographiques à ONLYOFFICE Docs Supprimer des polices inutilisées de ONLYOFFICE Docs Ajouter de nouveaux thèmes à ONLYOFFICE Docs Presentation Editor ONLYOFFICE Docs Windows version troubleshooting Faire passer ONLYOFFICE Docs Enterprise Edition vers le protocole HTTPS Mettre à jour ONLYOFFICE Docs sous Developer Edition Windows vers la dernière version Mettre à jour ONLYOFFICE Docs sous Enterprise Edition Windows vers la dernière version Mettre à jour ONLYOFFICE Docs sous Community Edition Windows vers la dernière version Installer ONLYOFFICE Workspace Enterprise Edition à partir du paquet RPM/DEB en utilisant le script fourni Installer ONLYOFFICE Workspace à partir du paquet RPM/DEB en utilisant le script fourni Installer ONLYOFFICE Groupes sur Debian, Ubuntu et dérivés Installer ONLYOFFICE Groupes sur Red Hat, CentOS et dérivés Migrer ONLYOFFICE Groupes sous Windows vers Linux Migrer ONLYOFFICE Groupes sous Docker vers Linux Migrer ONLYOFFICE Groupes sous Linux vers Docker Updating ONLYOFFICE Groups for Linux to the latest version Mettre à jour ONLYOFFICE Docs Community Edition sous Linux vers la dernière version Connecter ONLYOFFICE Docs à ONLYOFFICE Groups Faire passer ONLYOFFICE Groupes en HTTPS Comment passer en HTTPS lors de l'installation depuis des paquets RPM/DEB? Switching ONLYOFFICE Talk to TLS protocol on Linux version ONLYOFFICE Groups Linux version troubleshooting Lancer ONLYOFFICE Docs Community Edition avec Podman sur Fedora Lancer ONLYOFFICE Docs Enterprise Edition avec Podman sur Fedora Lancer ONLYOFFICE Docs Developer Edition avec Podman sur Fedora Compiler ONLYOFFICE Docs sur un serveur local Installer ONLYOFFICE Docs Community Edition sur Debian, Ubuntu et ses dérivés Installer ONLYOFFICE Docs Enterprise Edition sur Debian, Ubuntu et ses dérivés Installer ONLYOFFICE Docs Developer Edition sur Debian, Ubuntu et ses dérivés Installer ONLYOFFICE Docs Community Edition sous CentOS et ses dérivés Installer ONLYOFFICE Docs Enterprise Edition sous CentOS et ses dérivés Installer ONLYOFFICE Docs Developer Edition sous CentOS et ses dérivés Installer ONLYOFFICE Docs Community Edition sur Linux à partir de Snap Connecter ONLYOFFICE Docs à ONLYOFFICE Groups Ajouter des polices à ONLYOFFICE Docs Faire passer ONLYOFFICE Docs en HTTPS Ajouter une nouvelle langue d'interface à ONLYOFFICE Docs Ajouter de nouveaux thèmes à ONLYOFFICE Docs Presentation Editor ONLYOFFICE Docs Linux version troubleshooting Configuration des paramètres réseau sous Ubuntu Installation d'ONLYOFFICE Workspace Enterprise Edition en utilisant le script fourni Installer ONLYOFFICE Workspace Enterprise Edition en utilisant des paramètres du script supplémentaires Installation d'ONLYOFFICE Workspace en utilisant le script fourni Installer ONLYOFFICE Workspace en utilisant des paramètres du script supplémentaires Installer ONLYOFFICE Groupes pour Docker sur un serveur local Installer ONLYOFFICE Workspace à l'aide de Docker Compose Migrer ONLYOFFICE Groupes sous Docker vers Linux Migrer ONLYOFFICE Groupes sous Linux vers Docker Installer tous les composants ONLYOFFICE Workspace Comment mettre à niveau votre ONLYOFFICE Groupes sur Docker vers la dernière version? Migrating from ONLYOFFICE Workspace to Enterprise Edition using Docker script Utiliser des ports supplémentaires avec ONLYOFFICE Groups Connecter la base de donnée MySQL à ONLYOFFICE Groupes Lancer ONLYOFFICE Groupes à l'aide de HTTPS Configurer le serveur derrière un NAT Supprimer ONLYOFFICE Groupes sous Docker de votre ordinateur ONLYOFFICE Groups Docker version troubleshooting Installer ONLYOFFICE Docs pour Docker sur un serveur local Installer ONLYOFFICE Docs Enterprise Edition pour Docker sur un serveur local Installer ONLYOFFICE Docs Developer Edition pour Docker sur un serveur local Utilisez le script pour installer Community Edition ONLYOFFICE Docs Utilisez le script pour installer Enterprise Edition ONLYOFFICE Docs Utilisez le script pour installer Developer Edition ONLYOFFICE Docs Lancer ONLYOFFICE Docs à l'aide de Docker Compose Installer tous les composants ONLYOFFICE Workspace Ajouter une nouvelle langue d'interface à ONLYOFFICE Docs Supprimer ONLYOFFICE Docs sous Docker de votre ordinateur ONLYOFFICE Docs Docker version troubleshooting Mettre à jour ONLYOFFICE Docs Developer Edition sous Docker vers la dernière version Mettre à jour ONLYOFFICE Docs Enterprise Edition sous Docker vers la dernière version Mettre à jour ONLYOFFICE Docs Community Edition sous Docker vers la dernière version Installer ONLYOFFICE Mail sous Docker sur un serveur local Installer tous les composants ONLYOFFICE Workspace Mettre à jour ONLYOFFICE Mail intégré dans ONLYOFFICE Groupes Connecter ONLYOFFICE Mail à ONLYOFFICE Groupes sur Windows Connecter ONLYOFFICE Mail à ONLYOFFICE Groupes dans les paramètres du portail Connecter ONLYOFFICE Mail à ONLYOFFICE Groupes sur Linux Modifier le domaine associé à ONLYOFFICE Mail Exécuter un script externe après le démarrage du conteneur Docker ONLYOFFICE Mail Créer des boîtes mail dans ONLYOFFICE Mail en utilisant le script Modifier les mots de passe des boîtes mail ONLYOFFICE Mail en utilisant le script Synchroniser l'ancienne et la nouvelle boîte mail en utilisant le script Supprimer ONLYOFFICE Mail sous Docker de votre ordinateur ONLYOFFICE Mail Docker version troubleshooting Enabling vsyscall on Debian Migrer des données depuis MS Exchange vers ONLYOFFICE Travail avec les modules complémentaires lors de l'utilisation de CSP Travail avec les modules complémentaires lors de l'utilisation de CSP Désinstaller les modules complémentaires par défaut des éditeurs de serveur Ajouter de nouveaux modules complémentaires aux éditeurs de serveur Integrating ONLYOFFICE with Nextcloud Integrating ONLYOFFICE with ownCloud Integrating ONLYOFFICE with Confluence Integrating ONLYOFFICE with Humhub Integrating ONLYOFFICE with Alfresco Integrating ONLYOFFICE with Liferay Integrating ONLYOFFICE with Mattermost Integrating ONLYOFFICE with SharePoint Integrating ONLYOFFICE with Plone Integrating ONLYOFFICE with Chamilo Integrating ONLYOFFICE with Jira Integrating ONLYOFFICE with Nuxeo Integrating ONLYOFFICE with Redmine Integrating ONLYOFFICE with Strapi Integrating ONLYOFFICE with Moodle Integrating ONLYOFFICE with WordPress Control Panel Ajouter ONLYOFFICE Mail au paquet d'installation ONLYOFFICE Workspace Mettre à jour ONLYOFFICE Workspace vers la dernière version Utilisation de la fonctionnalité de sauvegarde/restauration à partir de Panneau de configuration Protéger des données à l'aide du chiffrement Connecter des services de stockage externes Naviguer plus vite avec la recherche en plein texte Branding votre office en ligne Passer en HTTPS à l'aide du Panneau de configuration Réglage des paramètres LDAP More articles Déployer plusieurs portails en utilisant l'architecture mutualisée Utiliser la Salle Privée pour travailler sur vos documents en sécurité Private Rooms in ONLYOFFICE Workspace for Secure Collaboration on Documents Aperçu d'authentification unique ONLYOFFICE Configurer le fournisseur de service ONLYOFFICE et le fournisseur d'identité Shibboleth Configurer le fournisseur de service ONLYOFFICE et le fournisseur d'identité OneLogin Configurer le fournisseur de service ONLYOFFICE et le fournisseur d'identité AD FS Suivre l'histoire de connexion Réception des données de la piste d'audit Comment commencer à travailler avec ONLYOFFICE Workspace Enterprise Edition? How to use Control Panel in ONLYOFFICE Workspace How to use the backup/restore feature upgrade server Updating ONLYOFFICE Groups for Windows to the latest version Updating ONLYOFFICE Groups for Linux to the latest version Mettre à jour ONLYOFFICE Docs Community Edition sous Linux vers la dernière version Comment mettre à niveau votre ONLYOFFICE Groupes sur Docker vers la dernière version? Mettre à jour ONLYOFFICE Mail intégré dans ONLYOFFICE Groupes Mettre à jour ONLYOFFICE Workspace vers la dernière version Migrating from ONLYOFFICE Workspace to Enterprise Edition on Windows Comment mettre à niveau ONLYOFFICE Workspace Enterprise Edition vers la dernière version? More articles Migrating from ONLYOFFICE Workspace to Enterprise Edition using Docker script Mettre à jour ONLYOFFICE Docs Developer Edition sous Docker vers la dernière version Mettre à jour ONLYOFFICE Docs sous Developer Edition Windows vers la dernière version Mettre à jour ONLYOFFICE Docs Enterprise Edition sous Docker vers la dernière version Mettre à jour ONLYOFFICE Docs sous Enterprise Edition Windows vers la dernière version Mettre à jour ONLYOFFICE Docs Community Edition sous Docker vers la dernière version Mettre à jour ONLYOFFICE Docs sous Community Edition Windows vers la dernière version Panneau de configuration vous donne accès aux dernières versions de tous composants des éditeurs en ligne permettant de les mettre à jour plus facilement. Pour accéder au Panneau de configuration, connectez-vous à votre portail et cliquez sur l'icône Panneau de configuration sur la Page d'accueil. Vous pouvez également accéder aux Paramètres du portail et cliquer sur le lien Panneau de configuration' sur le panneau de gauche. Avant de lancer la mise à jour, nous vous recommandons de sauvegarder votre portail pour éviter toute perte de données. Instructions à suivre Dans le Panneau de configuration, ouvrez la page Mise à jour depuis la section PARAMÈTRES COMMUNS de la barre latérale gauche. Sur cette page, la liste de tous les composants ONLYOFFICE Workspaceavec indication de leur statut (Installé) et de la Version actuelle et la version la plus récente Disponible. Une fois le téléchargement et l'installation de la nouvelle version d'un module devient disponible, le bouton TÉLÉCHARGER va apparaître à côté. Lorsque les mises à jour de plusieurs composants y compris du Panneau de configuration sont disponibles, il faut tout d'abord mettre à jour le Panneau de configuration. Cliquez sur le bouton TÉLÉCHARGER. Une fois le téléchargement terminé, le bouton MISE À JOUR apparaîtra. Si vous utilisez une version sous Windows, le fichier d'installation sera téléchargé et stocké dans le dossier pour les téléchargements que vous utilisez par défaut. Pour mettre à jour votre version ONLYOFFICE Workspace sous Windows, il faut manuellement lancer le programme d'installation pour chaque composant. Cliquez sur le bouton MISE À JOUR. Un message d'avertissement va apparaître. Cliquez sur OK pour lancer l'installation de la nouvelle version ou ANNULER pour créer une sauvegarde tout d'abord. Ensuite, cliquez sur OK, votre Panneau de configuration et votre portail seront redémarrés et rendus indisponibles pendant le démarrage. Cela peut prendre jusqu'à 5 minutes. Une fois l'installation terminée, la Version actuelle et la version la plus récente Disponible du composant que vous avez mis à jour seront identiques sur la page Mise à jour. Faites défiler la page vers le haut, cliquez sur le bouton ALLER AU PORTAL pour découvrir de nouveaux fonctionnalités du module actualisé. Si vous avez déjà passé votre version ONLYOFFICE Workspace sous Windows en HTTPS, alors il vous faut manuellement lier votre certificat de sécurité à votre portail depuis le Gestionnaire des services Internet (IIS) après la mise à jour du portail. Toutes instructions sont disponibles dans la section Faire passer manuellement ONLYOFFICE Community Server 8.5 et versions ultérieures vers HTTPS. Download Host on your own server Available for Docker, Windows and Linux Cela peut vous aider aussi : Fermer
