Close Help Center Control Panel Portal Configuration. Getting Started Updating ONLYOFFICE Groups for Windows to the latest version Connecting ONLYOFFICE Docs to ONLYOFFICE Groups Administration Guides ONLYOFFICE Workspace Managing portals Reinforcing security Configuring modules and tools Customizing modules and tools Managing users Connecting external services ONLYOFFICE Control Panel Glossary Video FAQ General Technology Pricing Workspace Enterprise Edition Docs Enterprise Edition Docs Developer Edition ONLYOFFICE Groups Connectors Trial period Updating ONLYOFFICE Workspace to the latest version Control Panel v3.1 ONLYOFFICE Control Panel changelog Open in new window Version 3.1 Release date: 05/25/2022 General Added the Data Import page that allows to import data from Nextcloud, ownCloud and GoogleWorkspace to ONLYOFFICE Workspace. Moved Elasticsearch to a separate container. Fixed bugs. Version 3.0 Release date: 06/07/2021 Update License agreement dialog when installing docker components added. The inactive button with an action for uninstalled components (downloading and installing the available version) fixed. Search Indexing progress display added. LoginHistory and AuditTrail New empty screens added. Restore New checks when restoring data from a local or a 3rd party storage. SSO SSOAuth was removed from Control Panel. It's now available as a portal setting in Community Server. General improvements and bug fixes Bugs 47721, 49101, 49187, 49273, 49272, 49324, 46386, 49585 from the internal bugtracker fixed. 3rd party licenses and copyright updated. Version 2.9.1 Release date: 12/10/2020 Bug fixes Bug Fixes & Performance Improvements. Version 2.9 Release date: 10/14/2020 General Control Panel is available in the free Community version with all settings excepting the editors logo replacement; Added the vsyscall check to the installation scripts when installing Mail Server on Debian with kernel 4.18.0 and later; Redesign of the navigation menu: added Common and Portal settings sections, added icons to menu items; Added the advanced rebranding page in the Common Settings; Added the possibility to reindex the full-text search; Updated node.js, updated packages (transition to samlify for SSO); Added the Encryption at rest block in the Storage section; Added the Private Room section for the server version only; Added the upgrade page with a proposal to upgrade to Enterprise Edition; Added the activate page with a possibility to upload a license file; Added the HideAuthPage option to the SSO settings to hide the authorization page. When the HideAuthPage option is enabled, an automatic redirect from the authorization page to the SSO service will occur. LDAP Added the Sign in to domain option on the authorization page. Single Sign-on Transition to the new samlify library; Added the HideAuthPage option to the SSO settings to hide the authorization page. When the HideAuthPage option is enabled, an automatic redirect from the authorization page to the SSO service will occur. Version 2.7 Release date: 04/25/2019 LDAP Added more fields mapped for the users loaded via LDAP: user photo, birthday, contacts, primary phone number; Added the setting to autosync LDAP on schedule; Added the possibility to give administrator rights to the user group at the portal via LDAP; Updated the rules for LDAP users. Version 2.5.1 Release date: 04/07/2018 LDAP Fixed the Server internal error error when using the groups enclosed inside each other in the AD (bug #37414). Single Sign-on Fixed the issue when the user data between the Service Provider and the portal was transferred via HTTP only, even when HTTPS was enabled. Version 2.4.0 Release date: 01/13/2018 Single Sign-on Fixed the Invalid ssoConfig error which occurred when the link to the IdP contained the question mark '?', e.g.: IdP Single Sign-On Endpoint URL: https://accounts.google.com/o/saml2/idp?idpid=777777; Fixed the Invalid authentication token error which prevented from adding a user to the portal using the AD FS, in case the + or - characters were present when sending the encrypted data. Version 2.3.0 Release date: 12/15/2017 General Added the changelog for Control Panel and link to it; Fixed the bug when JWT parameters were not sent when updating Document Server(bug #36270); Fixed the bug when Audit Trail heading was present at the login history page (bug #36026); The current machine is now checked for being linked with the domain name for multiple portals. LDAP Fixed the bug with the LDAP Domain not found error which occurred if the DN record had no DC records (the users with Sun/Oracle DS were affected); now if the LDAP domain could not be specified, the LDAP domain will acquire the unknown value or the ldap.domain value from the web.appsettings.config configuration file; Fixed the bug with the Sizelimit Exceeded error when trying to get more than 1000 users from the Active Directory; Increased the login speed with the Group Membership setting enabled; Added additional logging; Fixed the bug with LDAP operation hanging when using Mono v5.2.0 and older; Fixed the bug with the error when trying to login using the email address entered in the fields different from the Mail Attribute; Fixed the bug occurring in the enclosed groups, when the users were displayed not in all groups. Version 2.2.0 Release date: 10/31/2017 General Added the documentserver-prepare4shutdown.sh script launch when updating the document-server for the correct edited document saving. LDAP Dramatically changed LDAP integration, migrated to the single library for the work with LDAP (Novell.Directory.Ldap.NETStandard, Nuget, MIT); Login and email are now split into two separate fields; Added the support for big data; Increased the work speed via the LDAP protocol (the connection to the server and receiving the data is now made once per session, added the limits when only a certain number of results is necessary, fixed the slow login for bit data, removed the sorting out used to find the SID parameter); Fixed the user re-creation issue; Fixed the duplicate username issue; Fixed the already existing email issue; Replaced the LDAP user deletion with account deactivation (for further data migration and data safety); Instead of re-creating a user with an unknown SID but an existing email the data is updated; Added the attempt to save the correct UserName/Login in case a similar one is already taken on the portal. Single Sign-on Added the AD FS support; Replaced the Single Sign-on link at the authorization page with the customizable button, added the button customization to the SSO setting of the Control Panel. Version 2.1.0 Release date: 07/03/2017 HTTPS Added the support of letsencrypt service for the domain certificate generation. Single Sign-on Added the new sso.auth service; Added the new SSO settings page; Added the support for Shibboleth. Version 2.0.0 Release date: 05/25/2017 General The Control Panel migrated from MVC to Node.js. Version 1.6.0 Release date: 12/05/2016 LDAP Added LDAP synchronization for users and groups when saving the settings, after login and using the Sync button; Changed email formation for LDAP users; Fixed the problem of creation of users with invalid emails; Fixed the problem of duplicate users; Added icons and hints to the users in the list for the admin; Blocked for editing the user profile fields imported using LDAP; Added the real LDAP password saving to the database during login in case LDAP Auth is disabled, now the LDAP users will become common portal users when LDAP Auth is disabled; Added new API Settings method - Sync LDAP; Added new translations; Bug fixes. Version for Windows Made changes at the Update page for the Control Panel for Windows; Updates are performed using the downloaded installation packages for each module. The current installed component version numbers are obtained via API request to the Community Server. The new versions available for download are obtained via the request to the https://download.onlyoffice.com/install/windows/updates.txt file, where all the latest component version numbers and links for their download are stored in the JSON format. server version Installing ONLYOFFICE Groups on a local server Installing ONLYOFFICE Workspace Enterprise Edition for Windows on a local server Compiling ONLYOFFICE Groups for a local server Migrating from the Cloud version to server version Migrating ONLYOFFICE Groups from Windows to Linux Updating ONLYOFFICE Groups for Windows to the latest version Migrating from ONLYOFFICE Workspace to Enterprise Edition on Windows More articles Updating ONLYOFFICE Workspace Enterprise Edition to the latest version Connecting ONLYOFFICE Docs to ONLYOFFICE Groups Switching ONLYOFFICE Talk to TLS protocol on Windows version Integrating third-party services in the server version Adding ONLYOFFICE Mail to the ONLYOFFICE Workspace installation Updating ONLYOFFICE Workspace to the latest version Using the Control Panel backup/restore feature Protect data using encryption Connecting third-party storages Navigating via Full-Text Search feature Branding your online office Switching to HTTPS using Control Panel Altering LDAP settings Deploying multiple portals using the Multitenancy feature Using the Private Room to work on your documents securely Private Rooms in ONLYOFFICE Workspace for Secure Collaboration on Documents How to use Control Panel in ONLYOFFICE Workspace How to use the backup/restore feature ONLYOFFICE Single Sign-on overview Configuring ONLYOFFICE SP and Shibboleth IdP Configuring ONLYOFFICE SP and OneLogin IdP Configuring ONLYOFFICE SP and AD FS IdP Tracking login history Receiving audit trail data How to start working with your ONLYOFFICE Workspace Enterprise Edition? How to buy ONLYOFFICE Workspace Enterprise Edition subscription? Using ONLYOFFICE Docs behind the proxy Languages available for ONLYOFFICE Docs interface Languages available for ONLYOFFICE Groups interface Adding custom modules to ONLYOFFICE Groups Creating API for the ONLYOFFICE Groups custom modules Creating a WebDAV server on Ubuntu and connecting it to ONLYOFFICE Creating a WebDAV server on Windows and connecting it to ONLYOFFICE Installing ONLYOFFICE Workspace for Windows on a local server ONLYOFFICE Groups Windows version troubleshooting ONLYOFFICE Groups frequently asked questions Deploying ONLYOFFICE Docs on your server Installing ONLYOFFICE Docs Enterprise Edition for Windows on a local server Installing ONLYOFFICE Docs Developer Edition for Windows on a local server Connecting ONLYOFFICE Docs to ONLYOFFICE Groups Switching to HTTPS for the Windows version Adding new fonts, languages and spellcheckers to ONLYOFFICE Docs Removing unused fonts from ONLYOFFICE Docs Adding new themes to the ONLYOFFICE Docs Presentation Editor ONLYOFFICE Docs Windows version troubleshooting Switching ONLYOFFICE Docs Enterprise Edition to HTTPS protocol Updating ONLYOFFICE Docs Developer Edition for Windows to the latest version Updating ONLYOFFICE Docs Enterprise Edition for Windows to the latest version Updating ONLYOFFICE Docs Community Edition for Windows to the latest version Installing ONLYOFFICE Groups for Debian, Ubuntu, and derivatives Installing ONLYOFFICE Groups for Red Hat, CentOS, and derivatives Migrating ONLYOFFICE Groups from Windows to Linux Migrating ONLYOFFICE Groups from Docker to Linux Migrating ONLYOFFICE Groups from Linux to Docker Updating ONLYOFFICE Groups for Linux to the latest version Updating ONLYOFFICE Docs for Linux to the latest version Connecting ONLYOFFICE Docs to ONLYOFFICE Groups Switching ONLYOFFICE Groups to HTTPS protocol Switching to HTTPS when installing from RPM/DEB packages Switching ONLYOFFICE Talk to TLS protocol on Linux version ONLYOFFICE Groups Linux version troubleshooting Running ONLYOFFICE Docs Community Edition as Podman on Fedora Running ONLYOFFICE Docs Enterprise Edition as Podman on Fedora Running ONLYOFFICE Docs Developer Edition as Podman on Fedora Compiling ONLYOFFICE Docs for a local server Installing ONLYOFFICE Docs for Debian, Ubuntu, and derivatives Installing ONLYOFFICE Docs Enterprise Edition for Debian, Ubuntu, and derivatives Installing ONLYOFFICE Docs Developer Edition for Debian, Ubuntu, and derivatives Installing ONLYOFFICE Docs for CentOS and derivatives Installing ONLYOFFICE Docs Enterprise Edition for CentOS and derivatives Installing ONLYOFFICE Docs Developer Edition for CentOS and derivatives Installing ONLYOFFICE Docs for Linux snap package Connecting ONLYOFFICE Docs to ONLYOFFICE Groups Adding fonts to ONLYOFFICE Docs Switching ONLYOFFICE Docs to HTTPS protocol Adding a new interface language to ONLYOFFICE Docs Adding new themes to the ONLYOFFICE Docs Presentation Editor ONLYOFFICE Docs Linux version troubleshooting Updating ONLYOFFICE Docs Developer Edition for Docker to the latest version Updating ONLYOFFICE Docs Enterprise Edition for Docker to the latest version Updating ONLYOFFICE Docs Community Edition for Docker to the latest version Installing ONLYOFFICE Groups for Docker on a local server Installing ONLYOFFICE Workspace using Docker Compose Migrating ONLYOFFICE Groups from Docker to Linux Migrating ONLYOFFICE Groups from Linux to Docker Installing all ONLYOFFICE Workspace components integrated Updating ONLYOFFICE Groups for Docker to the latest version Migrating from ONLYOFFICE Workspace to Enterprise Edition using Docker script Using additional ports with ONLYOFFICE Groups Connecting a MySQL database to ONLYOFFICE Groups Running ONLYOFFICE Groups using HTTPS protocol Running ONLYOFFICE Groups behind NAT Removing ONLYOFFICE Groups for Docker from your computer ONLYOFFICE Groups Docker version troubleshooting Installing ONLYOFFICE Docs on a local server Installing ONLYOFFICE Docs Enterprise Edition for Docker on a local server Installing ONLYOFFICE Docs Developer Edition for Docker on a local server Installing ONLYOFFICE Docs Community Edition using the provided script Installing ONLYOFFICE Docs Enterprise Edition using the provided script Installing ONLYOFFICE Docs Developer Edition using the provided script Running ONLYOFFICE Docs using Docker Compose Installing all ONLYOFFICE Workspace components integrated Adding a new interface language to ONLYOFFICE Docs Removing ONLYOFFICE Docs for Docker from your computer ONLYOFFICE Docs Docker version troubleshooting Installing ONLYOFFICE Mail for Docker on a local server Installing all ONLYOFFICE Workspace components integrated Updating ONLYOFFICE Mail integrated with ONLYOFFICE Groups Connecting ONLYOFFICE Mail to ONLYOFFICE Groups on Windows Connecting ONLYOFFICE Mail to ONLYOFFICE Groups via Portal Settings Connecting ONLYOFFICE Mail to ONLYOFFICE Groups on Linux Changing domain used with ONLYOFFICE Mail Running an external script after starting ONLYOFFICE Mail Docker container Creating mailboxes in ONLYOFFICE Mail using a script Changing passwords for mailboxes in ONLYOFFICE Mail using a script Synchronizing new mailboxes with old ones using the script Removing ONLYOFFICE Mail for Docker from your computer ONLYOFFICE Mail Docker version troubleshooting Enabling vsyscall on Debian Migrating MS Exchange data to ONLYOFFICE Working with plugins when using CSP Working with plugins when using CSP Uninstall default plugin from the server editors Adding new plugins to server editors local server Adding ONLYOFFICE Mail to the ONLYOFFICE Workspace installation Updating ONLYOFFICE Workspace to the latest version Using the Control Panel backup/restore feature Protect data using encryption Connecting third-party storages Navigating via Full-Text Search feature Branding your online office Switching to HTTPS using Control Panel Altering LDAP settings More articles Deploying multiple portals using the Multitenancy feature Using the Private Room to work on your documents securely Private Rooms in ONLYOFFICE Workspace for Secure Collaboration on Documents ONLYOFFICE Single Sign-on overview Configuring ONLYOFFICE SP and Shibboleth IdP Configuring ONLYOFFICE SP and OneLogin IdP Configuring ONLYOFFICE SP and AD FS IdP Tracking login history Receiving audit trail data How to use Control Panel in ONLYOFFICE Workspace How to use the backup/restore feature How to start working with your ONLYOFFICE Workspace Enterprise Edition? How to buy ONLYOFFICE Workspace Enterprise Edition subscription? Using ONLYOFFICE Docs behind the proxy Updating ONLYOFFICE Workspace Enterprise Edition to the latest version Installing ONLYOFFICE Workspace for Windows on a local server Installing ONLYOFFICE Groups on a local server Installing ONLYOFFICE Workspace Enterprise Edition for Windows on a local server Compiling ONLYOFFICE Groups for a local server Migrating from the Cloud version to server version Migrating ONLYOFFICE Groups from Windows to Linux Updating ONLYOFFICE Groups for Windows to the latest version Migrating from ONLYOFFICE Workspace to Enterprise Edition on Windows Connecting ONLYOFFICE Docs to ONLYOFFICE Groups Switching to HTTPS for the Windows version Switching ONLYOFFICE Talk to TLS protocol on Windows version Integrating third-party services in the server version ONLYOFFICE Groups Windows version troubleshooting ONLYOFFICE Groups frequently asked questions Deploying ONLYOFFICE Docs on your server Installing ONLYOFFICE Docs Enterprise Edition for Windows on a local server Installing ONLYOFFICE Docs Developer Edition for Windows on a local server Connecting ONLYOFFICE Docs to ONLYOFFICE Groups Adding new fonts, languages and spellcheckers to ONLYOFFICE Docs Removing unused fonts from ONLYOFFICE Docs Adding new themes to the ONLYOFFICE Docs Presentation Editor ONLYOFFICE Docs Windows version troubleshooting Switching ONLYOFFICE Docs Enterprise Edition to HTTPS protocol Updating ONLYOFFICE Docs Developer Edition for Windows to the latest version Updating ONLYOFFICE Docs Enterprise Edition for Windows to the latest version Updating ONLYOFFICE Docs Community Edition for Windows to the latest version Installing ONLYOFFICE Workspace Enterprise Edition from RPM/DEB packages using the provided script Installing ONLYOFFICE Workspace from RPM/DEB packages using the provided script Installing ONLYOFFICE Groups for Debian, Ubuntu, and derivatives Installing ONLYOFFICE Groups for Red Hat, CentOS, and derivatives Migrating ONLYOFFICE Groups from Windows to Linux Migrating ONLYOFFICE Groups from Docker to Linux Migrating ONLYOFFICE Groups from Linux to Docker Updating ONLYOFFICE Groups for Linux to the latest version Updating ONLYOFFICE Docs for Linux to the latest version Connecting ONLYOFFICE Docs to ONLYOFFICE Groups Switching ONLYOFFICE Groups to HTTPS protocol Switching to HTTPS when installing from RPM/DEB packages Switching ONLYOFFICE Talk to TLS protocol on Linux version ONLYOFFICE Groups Linux version troubleshooting Running ONLYOFFICE Docs Community Edition as Podman on Fedora Running ONLYOFFICE Docs Enterprise Edition as Podman on Fedora Running ONLYOFFICE Docs Developer Edition as Podman on Fedora Compiling ONLYOFFICE Docs for a local server Installing ONLYOFFICE Docs for Debian, Ubuntu, and derivatives Installing ONLYOFFICE Docs Enterprise Edition for Debian, Ubuntu, and derivatives Installing ONLYOFFICE Docs Developer Edition for Debian, Ubuntu, and derivatives Installing ONLYOFFICE Docs for CentOS and derivatives Installing ONLYOFFICE Docs Enterprise Edition for CentOS and derivatives Installing ONLYOFFICE Docs Developer Edition for CentOS and derivatives Installing ONLYOFFICE Docs for Linux snap package Connecting ONLYOFFICE Docs to ONLYOFFICE Groups Adding fonts to ONLYOFFICE Docs Switching ONLYOFFICE Docs to HTTPS protocol Adding a new interface language to ONLYOFFICE Docs Adding new themes to the ONLYOFFICE Docs Presentation Editor ONLYOFFICE Docs Linux version troubleshooting Configuring network settings on Ubuntu Installing ONLYOFFICE Workspace Enterprise Edition using the provided script Installing ONLYOFFICE Workspace Enterprise Edition with additional script parameters Installing ONLYOFFICE Workspace using the provided script Installing ONLYOFFICE Workspace with additional script parameters Installing ONLYOFFICE Groups for Docker on a local server Installing ONLYOFFICE Workspace using Docker Compose Migrating ONLYOFFICE Groups from Docker to Linux Migrating ONLYOFFICE Groups from Linux to Docker Installing all ONLYOFFICE Workspace components integrated Updating ONLYOFFICE Groups for Docker to the latest version Migrating from ONLYOFFICE Workspace to Enterprise Edition using Docker script Using additional ports with ONLYOFFICE Groups Connecting a MySQL database to ONLYOFFICE Groups Running ONLYOFFICE Groups using HTTPS protocol Running ONLYOFFICE Groups behind NAT Removing ONLYOFFICE Groups for Docker from your computer ONLYOFFICE Groups Docker version troubleshooting Installing ONLYOFFICE Docs on a local server Installing ONLYOFFICE Docs Enterprise Edition for Docker on a local server Installing ONLYOFFICE Docs Developer Edition for Docker on a local server Installing ONLYOFFICE Docs Community Edition using the provided script Installing ONLYOFFICE Docs Enterprise Edition using the provided script Installing ONLYOFFICE Docs Developer Edition using the provided script Running ONLYOFFICE Docs using Docker Compose Installing all ONLYOFFICE Workspace components integrated Adding a new interface language to ONLYOFFICE Docs Removing ONLYOFFICE Docs for Docker from your computer ONLYOFFICE Docs Docker version troubleshooting Updating ONLYOFFICE Docs Developer Edition for Docker to the latest version Updating ONLYOFFICE Docs Enterprise Edition for Docker to the latest version Updating ONLYOFFICE Docs Community Edition for Docker to the latest version Installing ONLYOFFICE Mail for Docker on a local server Installing all ONLYOFFICE Workspace components integrated Updating ONLYOFFICE Mail integrated with ONLYOFFICE Groups Connecting ONLYOFFICE Mail to ONLYOFFICE Groups on Windows Connecting ONLYOFFICE Mail to ONLYOFFICE Groups via Portal Settings Connecting ONLYOFFICE Mail to ONLYOFFICE Groups on Linux Changing domain used with ONLYOFFICE Mail Running an external script after starting ONLYOFFICE Mail Docker container Creating mailboxes in ONLYOFFICE Mail using a script Changing passwords for mailboxes in ONLYOFFICE Mail using a script Synchronizing new mailboxes with old ones using the script Removing ONLYOFFICE Mail for Docker from your computer ONLYOFFICE Mail Docker version troubleshooting Enabling vsyscall on Debian Migrating MS Exchange data to ONLYOFFICE Working with plugins when using CSP Working with plugins when using CSP Uninstall default plugin from the server editors Adding new plugins to server editors Integrating ONLYOFFICE with Nextcloud Integrating ONLYOFFICE with ownCloud Integrating ONLYOFFICE with Confluence Integrating ONLYOFFICE with Humhub Integrating ONLYOFFICE with Alfresco Integrating ONLYOFFICE with Liferay Integrating ONLYOFFICE with SharePoint Integrating ONLYOFFICE with Plone Integrating ONLYOFFICE with Chamilo Integrating ONLYOFFICE with Jira Integrating ONLYOFFICE with Nuxeo Integrating ONLYOFFICE with Redmine Integrating ONLYOFFICE with Strapi Integrating ONLYOFFICE with Moodle Integrating ONLYOFFICE with WordPress Control Panel Adding ONLYOFFICE Mail to the ONLYOFFICE Workspace installation Updating ONLYOFFICE Workspace to the latest version Using the Control Panel backup/restore feature Protect data using encryption Connecting third-party storages Navigating via Full-Text Search feature Branding your online office Switching to HTTPS using Control Panel Altering LDAP settings More articles Deploying multiple portals using the Multitenancy feature Using the Private Room to work on your documents securely Private Rooms in ONLYOFFICE Workspace for Secure Collaboration on Documents ONLYOFFICE Single Sign-on overview Configuring ONLYOFFICE SP and Shibboleth IdP Configuring ONLYOFFICE SP and OneLogin IdP Configuring ONLYOFFICE SP and AD FS IdP Tracking login history Receiving audit trail data How to start working with your ONLYOFFICE Workspace Enterprise Edition? How to use Control Panel in ONLYOFFICE Workspace How to use the backup/restore feature upgrade server Updating ONLYOFFICE Groups for Windows to the latest version Updating ONLYOFFICE Groups for Linux to the latest version Updating ONLYOFFICE Docs for Linux to the latest version Updating ONLYOFFICE Groups for Docker to the latest version Updating ONLYOFFICE Mail integrated with ONLYOFFICE Groups Updating ONLYOFFICE Workspace to the latest version Migrating from ONLYOFFICE Workspace to Enterprise Edition on Windows Updating ONLYOFFICE Workspace Enterprise Edition to the latest version More articles Migrating from ONLYOFFICE Workspace to Enterprise Edition using Docker script Updating ONLYOFFICE Docs Developer Edition for Docker to the latest version Updating ONLYOFFICE Docs Developer Edition for Windows to the latest version Updating ONLYOFFICE Docs Enterprise Edition for Docker to the latest version Updating ONLYOFFICE Docs Enterprise Edition for Windows to the latest version Updating ONLYOFFICE Docs Community Edition for Docker to the latest version Updating ONLYOFFICE Docs Community Edition for Windows to the latest version Control Panel provides you the possibility to access the most recent versions of each online office component and easily update them. To access Control Panel, sign in to your portal and click the 'Control Panel' link on the Start Page. Alternatively, you can go to the portal 'Settings' and click the 'Control Panel' link on the left-side panel. Before you start the update process, it is recommended to create your portal data backup to prevent the probability of data loss. Bare Bones Instructions In the Control Panel, open the Update page in the COMMON SETTINGS section on the left sidebar. On this page, you can see the list of all the ONLYOFFICE Workspace components with the indication of their statuses (Installed), as well as Current and the latest Available versions. Once a new version of a certain module becomes available for downloading and installing, the DOWNLOAD button next to it will appear. In case updates are available for several components, including Control Panel, it is important to update Control Panel first of all. Click the DOWNLOAD button. When the downloading process is over, the UPDATE button will appear. If you are using the version for Windows, the installation file will be downloaded and stored to your Downloads folder used by default. To update your ONLYOFFICE Workspace Windows version, you will need to launch the installer for each component manually. Click the UPDATE button. The warning window will open. Click the OK button to start the new version installation process or CANCEL to be able to create a backup first. After you click the OK button, your Control Panel and portal will be restarted and become unavailable during this process. It can take up to 5 minutes. Once the installation is complete, the updated component Current and Available versions will be the same on the Update page. You can scroll up, click the GO TO PORTAL button and explore new features of the updated module. If you have previously switched your ONLYOFFICE Workspace Windows version to HTTPS, then you will need to manually bind your security certificate to your portal in the IIS Manager after updating the portal. The instructions on how to do that can be found in the Switching Community Server version 8.5 and later to HTTPS manually section. Download Host on your own server Available for Docker, Windows and Linux You Might Also Like This: Close
