Articles with the tag:
Close
Close
Try in the cloud
Try in the cloud
Help Center
Control Panel
Navigate faster using Full-Text Search feature
Version 3.5.2
Release date: 02/29/2024
General
  • Edited sources build.
Version 3.5
Release date: 03/14/2023
General
Version 3.1.1
Release date: 08/08/2022
General
Version 3.1
Release date: 05/25/2022
General
  • Fixed bugs.
Version 3.0
Release date: 06/07/2021
Update
Search
LoginHistory and AuditTrail
  • New empty screens added.
Restore
SSO
Version 2.9.1
Release date: 12/10/2020
Bug fixes
Version 2.9
Release date: 10/14/2020
General
LDAP
Single Sign-on
Version 2.7
Release date: 04/25/2019
LDAP
Version 2.5.1
Release date: 04/07/2018
LDAP
Single Sign-on
Version 2.4.0
Release date: 01/13/2018
Single Sign-on
Version 2.3.0
Release date: 12/15/2017
General
LDAP
  • Added additional logging;
Version 2.2.0
Release date: 10/31/2017
General
LDAP
Single Sign-on
  • Added the AD FS support;
Version 2.1.0
Release date: 07/03/2017
HTTPS
Single Sign-on
Version 2.0.0
Release date: 05/25/2017
General
Version 1.6.0
Release date: 12/05/2016
LDAP
  • Added new translations;
  • Bug fixes.
Version for Windows
Introduction
The Full-Text Search feature provided by the Control Panel allows you to search for the necessary string not only among the names of documents, emails etc. but also within their content.
ONLYOFFICE uses Elasticsearch, an open-source, broadly-distributable and readily-scalable search engine. Elsaticsearch is built on top of Lucene, a free and open-source search engine software library, and, therefore, it is excellent for fast full-text search. The documents stored in Elasticsearch are distributed across different containers known as shards, which are duplicated to provide redundant copies of the data in case of hardware failure.
Using Elasticsearch not only significantly reduces the time spent searching for a particular file or a text line but also enhances the search precision.
Enabling the Full-Text Search feature
To turn on full-text search within document contents,
  1. Sign in to your portal and click the Control Panel icon on the Start Page. Alternatively, you can go to the portal Settings and select the Control Panel link on the left-side panel.
  2. Switch to the Full-Text Search section.
  3. Check the Search in documents content checkbox and/or Search in mail messages content to enable the full-text search in the Document module, or in the Mail module respectively and click Save. The stored files will be indexed in the corresponding modules.
Since ElasticSerch indexes all stored files, enabling this feature requires at least an equal amount of free disk space as the overall disk space required for all documents, emails and other content.
Full-Text Search Full-Text Search
Reindex Full-Text Search
If the file you are looking for is not among the search results (e.g. in the Documents module), and you are sure that it exists, an indexing error might have occurred.
To rebuild indexes in a separately selected portal module,
  1. Switch to the Full-Text Search section in the Control Panel.
  2. Click the Reindex button on the right of the necessary module section.
To rebuild all indexes,
  2. Click the Reindex all button.
Reindex Reindex
Changing Elasticsearch consumed memory
In some cases, you might need to change the amount of Elasticsearch consumed memory.
To change the consumed memory,
  1. Open the configuration file:
    • For Windows systems - C:\ProgramData\Elastic\Elasticsearch\config\jvm.options
    • For Linux systems - /etc/elasticsearch/jvm.options
  2. Change the following parameters:
    1. -Xms1g
    2. -Xmx1g
    The number indicates the amount of used RAM in Gb.
  3. After changing the configuration file, restart the elasticsearch service.
Docker, Windows and Linux
You Might Also Like This:
Close
