Статьи с тэгом :
Закрыть
История изменений
Закрыть
Попробовать в облаке
Справочный центр
ONLYOFFICE Docs Enterprise Edition
Работа с плагинами при использовании CSP
ONLYOFFICE Docs v7.3 История изменений ONLYOFFICE Docs
Version 7.3.3
Release date: 03/15/2023
Version 7.3.2
Release date: 02/14/2023
Version 7.3.0
Release date: 01/31/2023
Version 7.2.2
Release date: 12/20/2022
Version 7.2.1
Release date: 10/21/2022
Version 7.2.0
Release date: 09/22/2022
Version 7.1.1
Release date: 06/02/2022
Version 7.1.0
Release date: 05/12/2022
Version 7.0.1
Release date: 02/22/2022
Version 7.0.0
Release date: 01/18/2022
Version 6.4.2
Release date: 10/14/2021
Version 6.4.1
Release date: 09/28/2021
Version 6.4.0
Release date: 08/26/2021
Version 6.3.2
Release date: 08/10/2021
Version 6.3.1
Release date: 06/08/2021
Version 6.3.0
Release date: 05/20/2021
Version 6.2.2
Release date: 04/19/2021
Version 6.2.1
Release date: 03/31/2021
Version 6.2.0
Release date: 03/01/2021
Version 6.1.1
Release date: 01/28/2021
Version 6.1.0
Release date: 12/02/2020
Version 6.0.2
Release date: 11/12/2020
Version 6.0.1
Release date: 10/28/2020
Version 6.0.0
Release date: 10/14/2020
Version 5.6.5
Release date: 09/21/2020
Version 5.6.4
Release date: 09/08/2020
Version 5.6.3
Release date: 08/17/2020
Version 5.6.2
Release date: 08/07/2020
Version 5.6.1
Release date: 08/05/2020
Version 5.6.0
Release date: 07/29/2020
Version 5.5.3
Release date: 05/22/2020
Version 5.5.1
Release date: 04/09/2020
Version 5.5.0
Release date: 03/05/2020
Version 5.4.2
Release date: 11/27/2019
Version 5.4.1
Release date: 10/02/2019
Version 5.4.0
Release date: 09/03/2019
Version 5.3.4
Release date: 07/16/2019
Version 5.3.2
Release date: 06/24/2019
Version 5.3.1
Release date: 06/06/2019
Version 5.3.0
Release date: 05/28/2019
Version 5.2.8
Release date: 02/05/2019
Version 5.2.7
Release date: 01/16/2019
Version 5.2.6
Release date: 12/25/2018
Version 5.2.4
Release date: 12/12/2018
Version 5.2.3
Release date: 10/31/2018
Version 5.2.2
Release date: 10/05/2018
Version 5.2.0
Release date: 09/28/2018
Version 5.1.5
Release date: 07/18/2018
Version 5.1.4
Release date: 05/24/2018
Version 5.1.3
Release date: 04/27/2018
Version 5.1.2
Release date: 04/11/2018
Version 5.1.1
Release date: 04/05/2018
Version 5.1.0
Release date: 03/28/2018
Version 5.0.7
Release date: 01/16/2018
Version 5.0.6
Release date: 12/11/2017
Version 5.0.5
Release date: 11/28/2017
Version 5.0.4
Release date: 11/14/2017
Version 5.0.3
Release date: 11/02/2017
Version 5.0.2 только SaaS-версия
Release date: 10/13/2017
Version 5.0.1 только SaaS-версия
Release date: 10/05/2017
Version 5.0.0 только SaaS-версия
Release date: 09/23/2017
Version 4.4.4
Release date: 09/13/2017
Windows-only release
See changelog on GitHub
Version 4.4.3
Release date: 08/14/2017
Version 4.4.2
Release date: 07/24/2017
Version 4.4.1
Release date: 07/05/2017
Version 4.3.6
Release date: 06/14/2017
Version 4.3.5
Release date: 06/05/2017
Version 4.3.4
Release date: 05/16/2017
Version 4.3.3
Release date: 04/28/2017
Version 4.3.2
Release date: 04/17/2017
Version 4.3.1
Release date: 04/06/2017
Version 4.3.0
Release date: 04/03/2017
Version 4.2.11
Release date: 03/13/2017
Version 4.2.10
Release date: 02/20/2017
Version 4.2.9
Release date: 02/14/2017
Version 4.2.8
Release date: 02/06/2017
Version 4.2.7
Release date: 02/01/2017
Version 4.2.5
Release date: 01/16/2017
Version 4.2.4
Release date: 01/09/2017
Version 4.2.3
Release date: 12/23/2016
Version 4.2.2
Release date: 12/21/2016
Version 4.2.1
Release date: 12/06/2016
Version 4.2.0
Release date: 12/01/2016
Version 4.1.8
Release date: 11/03/2016
Version 4.1.7
Release date: 11/01/2016
Version 4.1.6
Release date: 10/26/2016
Version 4.1.5
Release date: 10/13/2016
Version 4.1.4
Release date: 10/07/2016
Version 4.1.3
Release date: 09/28/2016
Version 4.1.2
Release date: 09/22/2016
Version 4.0.3
Release date: 08/04/2016
Version 4.0.2
Release date: 08/03/2016
Введение
Content Security Policy (CSP, политика безопасности содержимого) - это стандарт безопасности, предназначенный для предотвращения ряда угроз, например, XSS-атак (Cross-Site Scripting, межсайтовый скриптинг) и т.д. Когда CSP включена, она позволяет загружать содержимое только из разрешенных источников. В частности, запрещает выполнение запросов к сторонним доменам, которые не были явно разрешены.
Если вы используете ONLYOFFICE Docs (Enterprise Edition или Developer Edition), интегрированный с вашим веб-решением, и если при этом на вашем веб-сервере включена политика CSP для обеспечения повышенной безопасности, то стандартные настройки CSP могут вызвать некоторые проблемы. В онлайн-редакторах ONLYOFFICE есть ряд плагинов, некоторые из которых используют сторонние ресурсы и выполняют запросы к сторонним доменам, например, плагин YouTube. Так как CSP запрещает выполнение запросов к сторонним доменам, это препятствует правильной работе плагинов, например, блокирует загрузку видео с YouTube.
Добавление сторонних доменов в список разрешенных ресурсов
Чтобы обеспечить правильную работу плагинов, необходимо разрешить запросы на определенные домены (полный список доменов приводится ниже). Для этого надо изменить HTTP-заголовок, включающий политику CSP. В зависимости от решения, которое вы используете, он может находиться в разных файлах. В данной инструкции описываются базовые принципы, а не конкретные случаи. Заголовок должен выглядеть следующим образом:
Header set Content-Security-Policy "default-src 'self'; script-src 'self'; connect-src 'self';  img-src 'self'; style-src 'self';"
Эта строка содержит директивы, которые указывают разрешенные источники для разных типов содержимого: скриптов, таблиц стилей, шрифтов, изображений, элементов <audio> или <video> HTML5 и т.д.
Директива default-src применяется в тех случаях, если директива для определенного типа ресурса не задана.
‘self’ означает, что содержимое можно загружать только с текущего домена.
Необходимо изменить директиву default-src, добавив значения доверенных доменов:
default-src 'self' *.trusted1.com *.trusted2.com
Это позволит выполнять запросы на указанные доверенные домены *.trusted1.com и *.trusted2.com, включая поддомены, и загружать с них содержимое.
Список сторонних доменов
Следующие плагины выполняют запросы на сторонние домены:
Плагин Домен
clipart https://openclipart.org
speech https://code.responsivevoice.org
youtube https://www.youtube.com
thesaurus https://words.bighugelabs.com
translate https://translate.yandex.net
ocr https://cdn.rawgit.com
По умолчанию в состав онлайн-редакторов ONLYOFFICE включены следующие плагины из перечисленных: ocr, speech, thesaurus, translate, youtube.
Плагин clipart не включен в состав онлайн-редакторов, но доступен на https://github.com/ONLYOFFICE/sdkjs-plugins и может быть добавлен самостоятельно.
Для того чтобы включить все вышеперечисленные домены в список разрешенных источников, HTTP-заголовок должен выглядеть следующим образом:
Header set Content-Security-Policy "default-src 'self' *openclipart.org *code.responsivevoice.org *www.youtube.com *words.bighugelabs.com *translate.yandex.net *cdn.rawgit.com; script-src 'self'; connect-src 'self'; img-src 'self'; style-src 'self';"
в случае самостоятельной донастройки ONLYOFFICE Enterprise Edition с использованием CSP и при подключении плагинов wordpress и easybib потребуется также указать домены *wordpress.com и *easybib.com.
Docker, Windows и Linux
Закрыть
