Панель управления
v3.5
История изменений Панели управления ONLYOFFICE
Version 3.5.2
Release date: 02/29/2024
- Added the ability to restrict access rights to the application files for the Others group.
- Fixed issue with redirect to the portal main page when opening Control Panel after a day on Ubuntu 22.10.
- Fixed retrieving data error when opening the backup page.
- Fixed issue when backup with Mail is not performed after disabling and enabling encryption (added text about stopping services and the instruction to the Help Center).
- Fixed issue when features are not saved to the new tariff when setting a quota for the portal.
- Edited sources build.
Version 3.5
Release date: 03/14/2023
- Changed API methods for migration, implemented progressQueue.
- Changed settings for connecting third-party storages. Added tooltips for fields. Added the 'Server Side Encryption Method' block for Amazon AWS S3.
- Added logos for dark theme in the Branding section. Logos for the About page are now separate fields in the Advanced tab.
- Added the ability to set the portal memory quota.
Version 3.1.1
Release date: 08/08/2022
- Fixed issue with file indexing.
- Fixed elasticsearch container errors when updating ONLYOFFICE Groups.
- Fixed issue with brand logos after updating in the Docker installation.
- Fixed texts and layout for the Migration feature.
Version 3.1
Release date: 05/25/2022
- Fixed bugs.
Version 3.0
Release date: 06/07/2021
Version 2.9.1
Release date: 12/10/2020
Version 2.9
Release date: 10/14/2020
- Updated
node.js
, updated packages (transition to samlify
for SSO);
- Added the
upgrade
page with a proposal to upgrade to Enterprise Edition;
- Added the
activate
page with a possibility to upload a license file;
- Transition to the new
samlify
library;
Version 2.7
Release date: 04/25/2019
Version 2.5.1
Release date: 04/07/2018
- Fixed the
Server internal error
error when using the groups enclosed inside each other in the AD (bug #37414).
Version 2.4.0
Release date: 01/13/2018
- Fixed the
Invalid ssoConfig
error which occurred when the link to the IdP contained the question mark '?', e.g.: IdP Single Sign-On Endpoint URL: https://accounts.google.com/o/saml2/idp?idpid=777777
- Fixed the
Invalid authentication token
error which prevented from adding a user to the portal using the AD FS, in case the +
or -
characters were present when sending the encrypted data.
Version 2.3.0
Release date: 12/15/2017
Audit Trail
heading was present at the login history page (bug #36026);
- Fixed the bug with the
LDAP Domain not found
error which occurred if the DN record had no DC records (the users with Sun/Oracle DS were affected); now if the LDAP domain could not be specified, the LDAP domain will acquire the unknown
value or the ldap.domain
value from the web.appsettings.config
configuration file;
Sizelimit Exceeded
error when trying to get more than 1000 users from the Active Directory;
- Added additional logging;
Mail Attribute
Version 2.2.0
Release date: 10/31/2017
- Added the
documentserver-prepare4shutdown.sh
script launch when updating the document-server for the correct edited document saving.
- Added the AD FS support;
Version 2.1.0
Release date: 07/03/2017
- Added the new
sso.auth
service;
Version 2.0.0
Release date: 05/25/2017
MVC
to Node.js
Version 1.6.0
Release date: 12/05/2016
- Added new translations;
- Bug fixes.
Введение
Технология единого входа (англ. Single Sign-On или SSO) - технология, которая позволяет пользователям осуществлять вход в систему только один раз, а затем получать доступ ко множеству приложений/сервисов без повторной аутентификации.
Если на веб-портале существует несколько обширных независимых разделов (форум, чат, блог и т. д.) то, пройдя процедуру аутентификации в одном из сервисов, пользователь автоматически получает доступ ко всем остальным, что избавляет его от многократного ввода данных своей учётной записи.
SSO - это всегда совместная работа двух приложений: поставщика учетных записей (англ. Identity Provider, далее по тексту сокращенно "IdP") и поставщика сервиса (англ. Service Provider, далее по тексту сокращенно "SP"). ONLYOFFICE SSO реализует только SP. В качестве IdP может выступать множество различных провайдеров, но в этой статье мы рассмотрим реализацию OneLogin.
Если вы хотите использовать SSO при подключении Десктопных редакторов ONLYOFFICE к ONLYOFFICE Workspace, отключите Приватные комнаты в Панели управления.
Подготовка ONLYOFFICE Workspace для настройки SSO
- Установите версию ONLYOFFICE Workspace v. 11.0.0 для Docker или любую более позднюю версию с поддержкой SSO.
- Привяжите доменное имя, например, myportal-address.com.
- На портале перейдите в Панель управления -> HTTPS, создайте и примените сертификат letsencrypt для шифрования трафика (для включения HTTPS на портале).
Создание IdP в OneLogin
- Зарегистрируйтесь в OneLogin, если ещё не зарегистрировались.
- Войдите в OneLogin под учетной записью администратора.
- Перейдите в раздел Administration.
- Кликните по меню Applications. Нажмите кнопку Add App.
- В строке для поиска Find Application введите следующий текст: SAML Custom Connector (Advanced):
- Выберите найденный вариант.
- В новом открывшемся окне напишите любое имя в поле Display Name, например "IDP OneLogin Onlyoffice v11 Test", чтобы отличать это приложение от других, смените иконки на собственные и нажмите кнопку Save.
- Перейдите в подменю Configuration и заполните поля в соответствии с приведенной ниже таблицей:
Вместо myportal-address.com укажите собственное доменное имя или публичный IP-адрес, на котором располагается ONLYOFFICE SP.
- Нажмите кнопку Save и перейдите в подменю Parameters.
- Используйте кнопку +, чтобы создать 5 параметров (
givenName
, sn
, mail
, title
, mobile
). Для каждого из них отметьте опцию Include in SAML assertion и укажите значение из списка Value, подходящее для выдачи из каталога полей LDAP-каталога:
- Когда все нужные поля для атрибутов в утверждениях SAML будут заполнены в IdP, получится примерно такой же результат, как на следующем изображении. Нажмите кнопку Save.
- Перейдите в подменю SSO. В списке сертификатов нужно выбрать действующий, нажав на ссылку Change, если у вас несколько сертификатов. В поле SAML Signature Algorithm оставьте опцию SHA-1 и нажмите кнопку Save:
- Скопируйте ссылку из поля Issuer URL (например, https://app.onelogin.com/saml/metadata/4d87973f-629d-4a52-812e-bde45eff92b8) и перейдите на портал ONLYOFFICE под учетной записью администратора. Откройте страницу Панель управления -> SSO.
- Убедитесь, что вы зашли в качестве администратора в Панель управления ONLYOFFICE, и щелкните вкладку SSO в разделе НАСТРОЙКИ ПОРТАЛА на левой боковой панели.
Вы можете зарегистрировать только одного корпоративного поставщика учетных записей для вашей организации на портале ONLYOFFICE.
- Включите SSO, используя переключатель Включить аутентификацию с помощью технологии единого входа. Ссылку, скопированную из поля Issuer URL в OneLogin, вставьте в поле URL-адрес XML-файла метаданных IdP.
Нажмите кнопку со стрелкой вверх, чтобы загрузить метаданные IdP. Форма Настройки поставщика сервиса ONLYOFFICE будет автоматически заполнена данными из OneLogin IdP.
- В поле Пользовательская надпись для кнопки входа вы можете ввести любой текст вместо стандартного "Single Sign-on". Этот текст будет отображаться на кнопке для входа с помощью сервиса Single Sign-on на странице аутентификации портала ONLYOFFICE.
- Теперь необходимо создать сертификат в разделе Сертификаты поставщика сервиса. Для этого нажмите на кнопку Добавить сертификат в соответствующем разделе.
- В открывшемся модальном окне нажмите на ссылку Сгенерировать новый самоподписанный сертификат, в списке Использовать для выберите signing and encrypt. Перед тем как сохранить, скопируйте текст Открытого сертификата в буфер обмена (он понадобится для OneLogin), после чего нажмите кнопку OK.
- Должно получиться так:
- Форму с заголовком Сопоставление атрибутов настраивать не нужно, так как мы указали эти же параметры при создании OneLogin IdP. Используются следующие значения:
First Name |
givenName |
Last Name |
sn |
Email |
mail |
Location |
l |
Title |
title |
Phone |
mobile |
В разделе Дополнительные параметры можно включить настройку Скрыть страницу аутентификации, чтобы cкрыть страницу аутентификации по умолчанию и автоматически перенаправлять на сервис SSO.
ВажноЕсли вам необходимо восстановить страницу аутентификации по умолчанию (чтобы иметь доступ к порталу, если ваш сервер IDP выйдет из строя), можно добавить ключ /Auth.aspx?skipssoredirect=true
после доменного имени портала в адресной строке браузера.
- Нажмите кнопку Сохранить. Должен открыться раздел Метаданные поставщика сервиса ONLYOFFICE. Проверьте, что настройки доступны публично, кликнув по кнопке СКАЧАТЬ XML-ФАЙЛ МЕТАДАННЫХ ПОСТАВЩИКА СЕРВИСА. Должно отобразиться содержимое XML-файла.
- Вернитесь в OneLogin для настройки шифрования, откройте ваше приложение и перейдите в настройку Configuration. Листайте в самый низ, там должно появиться новое поле SAML Encryption для ввода ключа шифрования. В это поле нужно вставить скопированный текст Открытого сертификата из 4 пункта данной инструкции и нажать Save:
Создание пользователей в OneLogin и предоставление им доступа к ONLYOFFICE
Чтобы создать пользователей в OneLogin и предоставить им доступ к ONLYOFFICE SP, выполните следующие действия:
- перейдите на страницу All Users в OneLogin под учетной записью администратора,
- создайте нового пользователя или отредактируйте уже существующего,
- перейдите в подменю Applications и нажмите кнопку +,
- выберите наше новое созданное приложение из списка и нажмите CONTINUE,
- в новом открывшемся окне добавьте недостающие данные и нажмите кнопку SAVE
- теперь пользователь может работать в ONLYOFFICE SP.
Проверка работы ONLYOFFICE SP и OneLogin IdP
Вход в ONLYOFFICE на стороне SP
- Перейдите на страницу аутентификации ONLYOFFICE (например, https://myportal-address.com/Auth.aspx).
- Нажмите на кнопку Single sign-on (название кнопки может отличаться, если вы указали свой вариант при настройке ONLYOFFICE SP). Если этой кнопки нет, то SSO не включен.
- Если всё настроено верно в SP и IdP, мы будем перенаправлены на форму логина в OneLogin IdP:
- Введите логин и пароль пользователя, которому дан доступ к ONLYOFFICE SP, и нажмите кнопку LOG IN.
- Если учетные данные указаны правильно, мы будем перенаправлены на главную страницу портала (если такого пользователя нет на портале, он будет создан автоматически, а если данные были изменены в IdP, они будут обновлены).
Выход из ONLYOFFICE SP
- Выход SSO-пользователя с портала ONLYOFFICE можно осуществить, используя пункт меню Выйти. Пользователь также должен автоматически выйти из OneLogin IdP, если он вышел из всех других приложений, к которым ему дали доступ в OneLogin и куда он произвёл вход до этого.
- При удачном выходе вы будете перенаправлены на страницу аутентификации портала.
- Если снова нажать на кнопку Single Sign-on, вы будете снова перенаправлены на страницу логина в OneLogin (значит logout с портала прошёл успешно):
Профили пользователей, добавленных с помощью SSO-аутентификации
Возможность редактирования профилей пользователей, созданных с помощью SSO-аутентификации, ограничена. Поля профиля пользователя, полученные из IdP, заблокированы для редактирования (а именно: Имя
, Фамилия
, Email
, Позиция
и Местоположение
). Эти поля можно отредактировать только из вашей учетной записи в IdP.
На следующем изображении показано меню "Действия" для пользователя SSO:
На следующем изображении показан профиль пользователя SSO, открытый на редактирование:
Пользователи, созданные с помощью SSO-аутентификации, отмечены в списке пользователей значком SSO для администраторов портала:
