Статьи с тэгом :
Закрыть
История изменений
Закрыть
Попробовать в облаке
Справочный центр
Панель управления
Managing memory quota
Панель управления v3.5 История изменений Панели управления ONLYOFFICE
Version 3.5.2
Release date: 02/29/2024
General
  • Edited sources build.
Version 3.5
Release date: 03/14/2023
General
Version 3.1.1
Release date: 08/08/2022
General
Version 3.1
Release date: 05/25/2022
General
  • Fixed bugs.
Version 3.0
Release date: 06/07/2021
Update
Search
LoginHistory and AuditTrail
  • New empty screens added.
Restore
SSO
Version 2.9.1
Release date: 12/10/2020
Bug fixes
Version 2.9
Release date: 10/14/2020
General
LDAP
Single Sign-on
Version 2.7
Release date: 04/25/2019
LDAP
Version 2.5.1
Release date: 04/07/2018
LDAP
Single Sign-on
Version 2.4.0
Release date: 01/13/2018
Single Sign-on
Version 2.3.0
Release date: 12/15/2017
General
LDAP
  • Added additional logging;
Version 2.2.0
Release date: 10/31/2017
General
LDAP
Single Sign-on
  • Added the AD FS support;
Version 2.1.0
Release date: 07/03/2017
HTTPS
Single Sign-on
Version 2.0.0
Release date: 05/25/2017
General
Version 1.6.0
Release date: 12/05/2016
LDAP
  • Added new translations;
  • Bug fixes.
Version for Windows
Introduction
The Portal memory quota feature provided by the Control Panel allows you to set the memory limitation on your portal.
Manage memory quota
  1. Sign in to your portal and click the Control Panel icon on the Start Page. Alternatively, you can go to the portal Settings and select the Control Panel link on the left-side panel.
  2. Switch to the Storage section in the Control Panel.
  3. Scroll the page to find the Portal memory quota section.
    Manage memory quota Manage memory quota
  4. Click the EDIT button next to the portal name. If you enabled the Multitenancy feature, the list contains several portals.
  5. Choose the Edit quota option from the dropdown list.
  6. Set the necessary value in the input field and choose the unit of measure from the dropdown list (bytes, KB, MB, GB, TB). By default, the quota is set to 10 TB.
  7. Click SAVE.
If the memory quota you set is less than the memory used on the portal, you'll get an error. The amount of space used on the portal is displayed in the Used memory section.
To disable the quota, click the EDIT button next to the portal name and use the No quota option.
Docker, Windows и Linux
Закрыть
