Articles with the tag:
Close
Close
Try in the cloud
Try in the cloud
Print your presentation
Print the presentation
To print the current presentation opened in the Cloud section,
  2. tap the Print Print menu item.
A PDF file will be generated on the basis of this presentation. It can be printed out.
To print the current local presentation opened in the On Device section,
  2. tap the Print Print menu item to enter the priview mode,
  3. at the top of the screen choose either an available Printer or tap on the Save as PDF option to generate a PDF file on the basis of this presentation,
  4. in the drop-down menu Arrow specify the following parameters:
    • number of copies - enter the required number of copies of the presentation;
    • number of pages - choose either a range of pages, filling the textfield in the following way: (e.g. 1-5, 8, 11-13), or tap on each checkbox below to mark the slides you want to print;
    • page size - select one of the suggested paper formats;
    • color - choose either black and white print or color print (only for supporting printers);
    • two-sided printing - this option allows to print on both sides of a sheet of paper (only for supporting printers);
    • page orientation - choose from landscape and portrait options,
  5. tap the Print button to initialize printing.
You Might Also Like This:
Close
