Articles with the tag:
Close
Close
Try in the cloud
Try in the cloud
Select cell background color
To apply a background color to a certain cell/cell range or change the current one,
  1. select a cell, a range of cells or the whole worksheet,
  2. open the Cell settings panel by
    • tapping the Edit icon local option in the pop-up menu and choosing the Cell menu item,
  3. tap the Fill color option to open the color palette panel,
    Cell Background settings local
  4. select the necessary color on the Theme colors or Standard colors palette or create your own Custom color,
  5. to add a new Custom color, follow these steps:
    1. tap the Custom color icon in the Custom colors section.
    2. using the color palette, choose the necessary color and select its hue level,
      Custom color
    3. tap the OK button to apply the color to the selected text.
      The added color will also be placed in the Custom colors section, where the recently used custom colors are located.
  6. return to the previous screen by tapping the Back arrow on the left and сlose the cell settings panel by tapping the Close settings panel icon on the right.
To clear the background color of a certain cell, use the Without filling Without filling option.
You Might Also Like This:
Close
