Articles with the tag:
Close
Close
Try in the cloud
Try in the cloud
Create or delete sheets
By default a newly created spreadsheet has a single sheet. To add a new one, tap the Add sheet Plus icon located to the left of the sheet navigation panel below the current worksheet.
To delete an unnecessary sheet, tap the current sheet tab once to access the pop-up menu with the Delete option, then tap it.
Pop-up menu local
You Might Also Like This:
Close
