Articles with the tag:
Close
Close
Try in the cloud
Try in the cloud
Select background color for a paragraph
Background color is applied to the whole paragraph and completely fills all the paragraph space from the left page margin to the right page margin.
To apply a background color to a certain paragraph or change the current one,
  1. put the cursor within the paragraph you need, or select several paragraphs or the whole text,
  2. open the text and paragraph settings panel by
  3. switch to the Paragraph tab,
  4. tap the Background option to open the color palette panel (swipe it up to see more colors),
  5. select the necessary color on the Theme colors or Standard colors palette or create your own Custom color,
    Paragraph Background settings local
    To add a new Custom color, follow these steps:
    1. tap the Custom color icon in the Custom colors section.
    2. using the color palette, choose the necessary color and select its hue level,
      Custom color
    3. tap the OK button to apply the color to the selected text.
      The added color will also be placed in the Custom colors section, where the recently used custom colors are located.
  6. return to the previous screen by tapping the Back arrow on the left and close the paragraph settings panel by tapping the Back arrow on the right.
You Might Also Like This:
Close
