Articles with the tag:
Close
Close
Try in the cloud
Try in the cloud
Set slide parameters
When editing a presentation, the editor can switch between two types of orientations: portrait and landscape.
To change the interface orientation, enable the Auto-rotate option on your smartphone and position it in a proper way.
When the Auto-rotate option is disabled, the interface returns to portrait orientation.
You Might Also Like This:
Close
