Articles with the tag:
Close
Close
Try in the cloud
Try in the cloud
Add hyperlinks
  1. tap the Insert object icon at the top toolbar to open the new object insertion panel,
  2. switch to the Other tab Other tab,
  3. select the Link local Link option,
  4. after that the Link settings screen will appear where you can specify the hyperlink parameters:
    • Link - enter a URL in the format http://www.example.com.
    • Display - enter a text that will get clickable and lead to the web address specified in the upper field.
      If you've selected a text passage before tapping the Insert object icon, the Display field will be filled with the selected text fragment.
    Hyperlink Settings window
  5. tap the checkmark in the upper right corner.
To follow the added link, tap the Open Link option in the pop-up menu.
  1. tap the Edit Link option in the pop-up menu and perform the actions you need:
    • edit your data and tap the checkmark in the upper right corner to save the changes.
    • use the REMOVE LINK button to delete the added hyperlink.
You Might Also Like This:
Close
