Статьи с тэгом :
Закрыть
История изменений
Закрыть
Попробовать в облаке
Inviting new users
ONLYOFFICE DocSpace admins can create users within DocSpace itself (selecting the user type), as well as invite users to rooms for collaboration and assign permission levels to them.
In the Contacts section, only internal users (employees) can be created. External users (guests) can be added from within rooms only.
When inviting users to DocSpace, the available actions differ depending on the user type:
Section\User type Owner DocSpace admin Room admin User Guest
Documents
Creating, uploading, moving, copying, renaming, downloading, deleting files and folders
Rooms
Viewing all rooms
Viewing own rooms
Viewing rooms the user is invited to
Creating and editing rooms
Pinning rooms to top
Viewing room info (members, history, details)
Inviting external users (guests) to a room
Inviting internal users to a room
Assigning permission levels of own room members
Changing permission levels of own room members
Removing users from own room
Archiving own rooms
Creating a copy of own room
Creating a copy of someone else's room
Editing someone else's rooms: inviting users, assigning and changing permission levels of the room members, removing users from the room
Archiving someone else's room
Viewing links of someone else's public room
Changing the owner of someone else's room
Archive
Viewing all archived rooms
Viewing own archived rooms
Viewing archived rooms the user is invited to
Editing archived rooms
Pinning archived rooms to top
Viewing archived room info (members, history, details)
Inviting users to an archived room, assigning and changing permission levels of members
Restoring, copying, or removing someone else's archived rooms
Restoring, copying, or removing own archived rooms
Trash
Contacts
Inviting "DocSpace admin"
Inviting "Room admin"
Inviting "User"
Inviting "Guest"
Promoting to "DocSpace admin"
Promoting to "Room admin"
Promoting to "User"
Demoting "DocSpace admin" to "Room admin" or "User"
Demoting "Room admin" to "User"
Demoting "User" to "Guest"
Disabling "DocSpace admin"
Disabling "Room admin"
Disabling "User"
Disabling "Guest"
Editing or removing users
Viewing own guest list
Viewing someone else's guest list
Groups
Creating and editing groups
Viewing groups
File management settings
DocSpace settings
Removing DocSpace
All other settings
To add users within DocSpace,
  1. Go to the Contacts section on the left. Use the Employees tab.
  2. Use the Actions button in the upper left corner or the Plus icon Plus icon above the list of users.
  3. Choose the Invite menu item.
  4. Select the user type: DocSpace admin, Room admin, User.
  5. Invite users via the link:
    1. Turn on the Invite via link switcher – the link will be copied to the clipboard.
    2. If you want to change the user type, select the necessary one from the list and use the Copy link icon icon to copy the modified invitation link to the clipboard. You can send the copied link in any convenient way.
      This link is valid for 7 days only.
      Invitation link Invitation link
  6. Alternatively, you can use the Add manually section to add email addresses manually one by one:
    1. Enter a valid email address and click ‘Add’ below or press Enter. In the same way, add several email addresses if necessary.
    2. Change the invitation language if necessary.
    3. Change the user type if necessary.
    4. When ready, click the Send invitation button. Invitations will be sent to the specified email addresses.
      Individual invitation Individual invitation
When a user receives the invitation, they should follow the link, specify their email (if they were invited using Invite via link option), first and last name, and set a password (the password CANNOT be less than 8 and more than 30 characters long). It's also possible to change the language using the combo box in the upper right corner.
Invitation Invitation
After that the user can:
  • access DocSpace,
  • view the Rooms and Archive spaces (they are empty if the user was not invited to a room),
  • edit their own profile.
Once the user is invited to a room, they can participate in collaboration. Admins can manage the existing users in DocSpace.
Create groups
To create a group,
  1. Click the Actions button in the left upper corner within the Contacts section.
  2. Select the Create group option from the dropdown list.
  3. Enter the group Name.
  4. Assign the Head of group by clicking the Select link and selecting one of the existing users, then click Add.
  5. Add group Members by clicking the Add members link and selecting the existing users, then click Add.
  6. Click the Create button.
Adding Groups Adding Groups
Docker, Windows и Linux
Закрыть
