Once a room in ONLYOFFICE DocSpace is created, admins should invite users to this room to start collaboration.
When inviting users to a room, admins assign a permission level to a user. A permission level defines which actions with files the user can perform within this room:
Public room |
Form filling room |
Collaboration room |
Custom room |
Viewer |
Commentator |
Reviewer |
Form filler |
Editor |
Power user |
Room admin |
To invite a user to a room,
- Open the necessary room where you want to invite users.
- Click the
icon next to the room name.
- Select the
Invite users option from the menu.
- Invite users via the link:
- Turn on the Invite via link switcher – the link will be copied to the clipboard.
- If you want to change the permission level, select the necessary one from the list. Viewer is selected by default. The available permission levels depend on the room type: Room admin, Power user, Editor, Form filler, Reviewer, Commentator, Viewer. Access rights to all documents stored in the room are defined by the permission level. Users can have different permission levels depending on the rooms they are invited to (one and the same user can be a Viewer in the first room and an Editor in the second one).
- Use the
icon to copy the modified invitation link to the clipboard. You can send the copied link in any convenient way.
This link is valid for 7 days only.
- Alternatively, you can use the Add manually section to add email addresses manually one by one:
- Click the Choose from list option to select the existing DocSpace users. Check them in the list and click the Add members button.
- To invite new users by email, enter a valid email address and click ‘Add’ below or press Enter. In the same way, add several email addresses if necessary.
- Change the permission level if necessary. Viewer is selected by default. The available permission levels depend on the room type: Room admin, Power user, Editor, Form filler, Reviewer, Commentator, Viewer. Access rights to all documents stored in the room are defined by the permission level. Users can have different permission levels depending on the rooms they are invited to (one and the same user can be a Viewer in the first room and an Editor in the second one).
- When ready, click the Send invitation button. Invitations will be sent to the specified email addresses.
It’s also possible to invite members to the room from the Info -> Members screen. Click the
icon next to the Users in room caption to add new members.
When a user accepts the invitation to the room, they can view the room in the Rooms space and can participate in collaboration with access rights according to the permission level. Admins can manage users within the room as described below.
Resending invitations to rooms
- Within the room, open the Info -> Members screen.
- Click the
icon next to the Pending invitations caption.
Changing permission levels in rooms
- Click the current permission level next to the necessary user.
- Select a different permission level from the list.
Removing users from rooms
- Click the current permission level.
- Select the Remove option.
