ONLYOFFICE DocSpace admins can create users within DocSpace itself (selecting the user type), as well as invite users to rooms for collaboration and assign permission levels to them.
When inviting users to DocSpace, the available actions differ depending on the user type:
Section\User type |
Owner |
DocSpace admin |
Room admin |
Power user |
User |
My documents |
Creating, uploading, moving, copying, renaming, downloading, deleting files and folders |
Rooms |
Viewing all rooms |
Viewing own rooms |
Viewing rooms the user is invited to |
Creating and editing rooms |
Pinning rooms to top |
Viewing room info (members, history, details) |
Inviting users to own room, assigning and changing permission levels of the room members, removing users from the room |
Archiving own rooms |
Editing someone else's rooms: inviting users, assigning and changing permission levels of the room members, removing users from the room |
Archiving someone else's room |
Archive |
Viewing all rooms |
Viewing own rooms |
Inviting users to a room, assigning and changing permission levels of members |
Restoring or removing someone else's rooms |
Restoring or removing own rooms |
Trash |
Accounts |
Inviting "DocSpace admin" |
Inviting "Room admin" |
Inviting "Power user" |
Inviting "User" |
Promoting to "DocSpace admin" |
Promoting to "Room admin" |
Promoting to "Power user" |
Demoting "DocSpace admin" to "Room admin" |
Disabling "DocSpace admin" |
Disabling "Room admin" |
Disabling "Power user" |
Disabling "User" |
Editing or removing users |
Room manager settings |
DocSpace settings |
Removing DocSpace |
All other settings |
To add users within DocSpace,
- Go to the Accounts section on the left.
- Use the Actions button in the upper left corner or the Plus icon above the list of users.
- Choose the Invite menu item.
- Select the user type: DocSpace admin, Room admin, Power user, User.
- Invite users via the link:
- Turn on the Invite via link switcher – the link will be copied to the clipboard.
- If you want to change the user type, select the necessary one from the list and use the icon to copy the modified invitation link to the clipboard. You can send the copied link in any convenient way.
This link is valid for 7 days only.
- Alternatively, you can use the Add manually section to add email addresses manually one by one:
- Enter a valid email address and click ‘Add’ below or press Enter. In the same way, add several email addresses if necessary.
- Change the invitation language if necessary.
- Change the user type if necessary.
- When ready, click the Send invitation button. Invitations will be sent to the specified email addresses.
When a user receives the invitation, they should follow the link, specify their email (if they were invited using Invite via link option), first and last name, and set a password (the password CANNOT be less than 8 and more than 30 characters long).
After that the user can:
- access DocSpace,
- view the Rooms and Archive spaces (they are empty if the user was not invited to a room),
- edit their own profile.
Once the user is invited to a room, they can participate in collaboration. Admins can manage the existing users in DocSpace.
Create groups
To create a group,
- click the Actions button in the left upper corner within the Accounts section
- select the Create group option from the dropdown list
- enter the group Name
- assign the Head of group by clicking the Select link and selecting one of the existing users, then click Add
- add group Members by clicking the Add members link and selecting the existing users, then click Add
- click the Create button
