Chiudi Centro assistenza Documenti Documenti Persone Come organizzare e gestire la documentazione della società? Importa file da fonti diverse Versioni e revisioni in Documenti di online office User guides ONLYOFFICE Workspace General questions ONLYOFFICE Groups ONLYOFFICE Docs ONLYOFFICE Mail ONLYOFFICE Talk ONLYOFFICE Personal ONLYOFFICE Groups Documents Module People Module Community Module CRM Module Projects Module Mail Module Calendar Module Feed Tool ONLYOFFICE Docs Document Editor Spreadsheet Editor Presentation Editor User Guides about Editors ONLYOFFICE Mobile Apps ONLYOFFICE Documents for iOS ONLYOFFICE Documents for Android ONLYOFFICE Projects for iOS ONLYOFFICE Projects for Android ONLYOFFICE Web Editors Glossario Video FAQ Generale Tecnologia Prezzi Workspace Enterprise Edition Docs Enterprise Edition Docs Developer Edition ONLYOFFICE Groups Connectors How to edit documents from Dropbox in ONLYOFFICE Documenti di online office Menu contestuale in Documenti di online office Document collaboration made easy in the online office Documenti Documenti Come modificare il documento collaborativamente online? Come creare un file CSV? Come inserire un documento nel tuo blog? Come organizzare e gestire la documentazione della società? More articles Integra altre risorse in Documenti di online office Gestisci i tuoi documenti con online office Chiavi di autorizzazione Integrating third-party services in the cloud version Versioni e revisioni in Documenti di online office Sending for electronic signature Learning about folder permissions hierarchy Sharing files and folders How to edit documents from Dropbox in ONLYOFFICE How to edit documents from Google Drive in ONLYOFFICE How to edit documents from Nextcloud in ONLYOFFICE How to edit documents from ownCloud in ONLYOFFICE How to edit documents from Box in ONLYOFFICE How to edit documents from OneDrive in ONLYOFFICE Managing versions and revisions Sharing documents Personal Personal Managing versions and revisions Sharing documents Languages availabe in ONLYOFFICE Personal How to edit documents from Dropbox in ONLYOFFICE How to edit documents from Google Drive in ONLYOFFICE How to edit documents from Nextcloud in ONLYOFFICE How to edit documents from ownCloud in ONLYOFFICE How to edit documents from Box in ONLYOFFICE How to edit documents from OneDrive in ONLYOFFICE ONLYOFFICE Personal troubleshooting Document collaboration made easy in the online office Real-time co-editing in ONLYOFFICE integrare account Dropbox Integra altre risorse in Documenti di online office How to edit documents from Dropbox in ONLYOFFICE Chiavi di autorizzazione Open or create new files and folders Open or create new files and folders Open or create new files and folders Open or create new files and folders You have a Dropbox account and want to edit your documents using ONLYOFFICE? Follow this step-by-step guide to find out how to edit documents stored in your Dropbox from the Documents portal module. This option is available for ONLYOFFICE Workspace/ONLYOFFICE Workspace Enterprise Edition users only. Cloud users can skip this section and proceed with Connect your Dropbox account to ONLYOFFICE step. Creating authorization keys You will have to setup authorization keys for Dropbox. Follow these steps: Go to the Dropbox Developers website. Click the Create apps button. Sign in to your account. Next check the Dropbox API radio button. Select the following type of access: Full Dropbox - Access to all files and folders in a user's Dropbox. Name your application. When creating the first app, you'll also need to check the I agree to Dropbox API Terms and Conditions box. Click the Create app button. On your application Settings tab, enter https://service.onlyoffice.com/oauth2.aspx in the Redirect URIs field and click the Add button. Copy or write down App key and App secret which appear on the Settings page. Connecting the Dropbox service First of all go to the Settings section. To do that click the icon in the right upper corner. Switch to the Integration tab. Open the Third-Party Services page. Click the sliding button right of the Dropbox logo. Enter your keys and click the Enable button. Connect your Dropbox account to ONLYOFFICE In the left sidebar of the Documents, just below the text Connect, click on the Dropbox icon. Login to your Dropbox account. Allow ONLYOFFICE to connect to your Dropbox account by clicking the button. Your Dropbox documents will be shown in ONLYOFFICE documents as a folder. Change the folder‘s name, if necessary. If you want the Dropbox documents to be visible for anyone, click on the Make shared checkbox and put into the Common Documents folder box. If not checked, your Dropbox-account will only be visible to you. This step is not available while working in ONLYOFFICE Personal. Click Save. Edit your Dropbox documents Locate the Dropbox folder and open it. Browse to the file you want to edit and click it. If necessary, a dialog will tell you that the document will be converted to the OpenOffice XML format for faster viewing and editing. You can choose to keep the original file as well, by checking the Save the file copy in the original format as well box. Click Convert. Click Open when the message appears that your document is successfully converted.. Now you can edit your document (if editable). After editing, you can simply close the document and the changes will be saved. Download Host on your own server Available for Docker, Windows and Linux Ti potrebbe essere d'aiuto anche... Chiudi
