Fermer
Fermer
Fermer
Essayer dans le cloud
AutoCorrect Features
The AutoCorrect features in ONLYOFFICE Document Editor are used to automatically format text when detected or insert special math symbols by recognizing particular character usage.
The available AutoCorrect options are listed in the corresponding dialog box. To access it, go to the File tab -> Advanced Settings -> Proofing -> AutoCorrect Options.
The AutoCorrect dialog box consists of four tabs: Math Autocorrect, Recognized Functions, AutoFormat As You Type, and Text AutoCorrect.
Math AutoCorrect
When working with equations, you can insert a lot of symbols, accents, and mathematical operation signs typing them on the keyboard instead of choosing a template from the gallery.
In the equation editor, place the insertion point within the necessary placeholder, type a math autocorrect code, then press Spacebar. The entered code will be converted into the corresponding symbol, and the space will be eliminated.
Note: The codes are case sensitive.
You can add, modify, restore, and remove autocorrect entries from the AutoCorrect list. Go to the File tab -> Advanced Settings -> Proofing -> AutoCorrect Options -> Math AutoCorrect.
Adding an entry to the AutoCorrect list
  • Enter the autocorrect code you want to use in the Replace box.
  • Enter the symbol to be assigned to the code you entered in the By box.
  • Click the Add button.
Modifying an entry on the AutoCorrect list
  • Select the entry to be modified.
  • You can change the information in both fields: the code in the Replace box or the symbol in the By box.
  • Click the Replace button.
Removing entries from the AutoCorrect list
  • Select an entry to remove from the list.
  • Click the Delete button.
To restore the previously deleted entries, select the entry to be restored from the list and click the Restore button.
Use the Reset to default button to restore default settings. Any autocorrect entry you added will be removed and the changed ones will be restored to their original values.
To disable Math AutoCorrect and to avoid automatic changes and replacements, uncheck the Replace text as you type box.
The table below contains all the currently supported codes available in the Document Editor. The full list of the supported codes can also be found on the File tab -> Advanced Settings -> Proofing -> AutoCorrect Options -> Math AutoCorrect.
The supported codes
Code Symbol Category
Symbols
Dots
Operators
Operators
Relational operators
\above
Above/Below scripts
\acute
Accents
\aleph
Hebrew letters
\alpha
Greek letters
\Alpha
Greek letters
\amalg
Binary operators
\angle
Geometry notation
\aoint
Integrals
\approx
\asmash
Arrows
\ast
Binary operators
\asymp
\atop
Operators
\bar
Over/Underbar
\Bar
Accents
\because
\begin
Delimiters
\below
Above/Below scripts
\bet
Hebrew letters
\beta
Greek letters
\Beta
Greek letters
\beth
Hebrew letters
\bigcap
Large operators
\bigcup
Large operators
\bigodot
Large operators
\bigoplus
Large operators
\bigotimes
Large operators
\bigsqcup
Large operators
\biguplus
Large operators
\bigvee
Large operators
\bigwedge
Large operators
\binomial
Equations
\bot
Logic notation
\bowtie
\box
Symbols
\boxdot
Binary operators
\boxminus
Binary operators
\boxplus
Binary operators
\bra
Delimiters
\break
Symbols
\breve
Accents
\bullet
Binary operators
\cap
Binary operators
\cbrt
Square roots and radicals
\cases
Symbols
\cdot
Binary operators
\cdots
Dots
\check
Accents
\chi
Greek letters
\Chi
Greek letters
\circ
Binary operators
\close
Delimiters
\clubsuit
Symbols
\coint
Integrals
\cong
\coprod
Math operators
\cup
Binary operators
\dalet
Hebrew letters
\daleth
Hebrew letters
\dashv
\dd
Double-struck letters
\Dd
\ddddot
Accents
\dddot
Accents
\ddot
Accents
\ddots
Dots
\defeq
\degc
Symbols
\degf
Symbols
\degree
Symbols
\delta
Greek letters
\Delta
Greek letters
\Deltaeq
Operators
\diamond
Binary operators
\diamondsuit
Symbols
\div
Binary operators
\dot
Accents
\doteq
\dots
Dots
\doublea
\doubleA
\doubleb
\doubleB
\doublec
\doubleC
\doubled
\doubleD
\doublee
\doubleE
\doublef
\doubleF
\doubleg
\doubleG
\doubleh
\doubleH
\doublei
\doubleI
\doublej
\doubleJ
\doublek
\doubleK
\doublel
\doubleL
\doublem
\doubleM
\doublen
\doubleN
\doubleo
\doubleO
\doublep
\doubleP
\doubleq
\doubleQ
\doubler
\doubleR
\doubles
\doubleS
\doublet
\doubleT
\doubleu
\doubleU
\doublev
\doubleV
\doublew
\doubleW
\doublex
\doubleX
\doubley
\doubleY
\doublez
\doubleZ
\downarrow
Arrows
\Downarrow
Arrows
\dsmash
Arrows
\ee
\ell
Symbols
\emptyset
Set notations
\emsp Space characters
\end
Delimiters
\ensp Space characters
\epsilon
Greek letters
\Epsilon
Greek letters
\eqarray
Symbols
\equiv
\eta
Greek letters
\Eta
Greek letters
\exists
Logic notations
\forall
Logic notations
\fraktura
Fraktur letters
\frakturA
Fraktur letters
\frakturb
Fraktur letters
\frakturB
Fraktur letters
\frakturc
Fraktur letters
\frakturC
Fraktur letters
\frakturd
Fraktur letters
\frakturD
Fraktur letters
\frakture
Fraktur letters
\frakturE
Fraktur letters
\frakturf
Fraktur letters
\frakturF
Fraktur letters
\frakturg
Fraktur letters
\frakturG
Fraktur letters
\frakturh
Fraktur letters
\frakturH
Fraktur letters
\frakturi
Fraktur letters
\frakturI
Fraktur letters
\frakturk
Fraktur letters
\frakturK
Fraktur letters
\frakturl
Fraktur letters
\frakturL
Fraktur letters
\frakturm
Fraktur letters
\frakturM
Fraktur letters
\frakturn
Fraktur letters
\frakturN
Fraktur letters
\frakturo
Fraktur letters
\frakturO
Fraktur letters
\frakturp
Fraktur letters
\frakturP
Fraktur letters
\frakturq
Fraktur letters
\frakturQ
Fraktur letters
\frakturr
Fraktur letters
\frakturR
Fraktur letters
\frakturs
Fraktur letters
\frakturS
Fraktur letters
\frakturt
Fraktur letters
\frakturT
Fraktur letters
\frakturu
Fraktur letters
\frakturU
Fraktur letters
\frakturv
Fraktur letters
\frakturV
Fraktur letters
\frakturw
Fraktur letters
\frakturW
Fraktur letters
\frakturx
Fraktur letters
\frakturX
Fraktur letters
\fraktury
Fraktur letters
\frakturY
Fraktur letters
\frakturz
Fraktur letters
\frakturZ
Fraktur letters
\frown
\funcapply Binary operators
\G
Greek letters
\gamma
Greek letters
\Gamma
Greek letters
\ge
\geq
\gets
Arrows
\gg
\gimel
Hebrew letters
\grave
Accents
\hairsp Space characters
\hat
Accents
\hbar
Symbols
\heartsuit
Symbols
\hookleftarrow
Arrows
\hookrightarrow
Arrows
\hphantom
Arrows
\hsmash
Arrows
\hvec
Accents
\identitymatrix
Matrices
\ii
\iiint
Integrals
\iint
Integrals
\iiiint
Integrals
\Im
Symbols
\imath
Symbols
\in
\inc
Symbols
\infty
Symbols
\int
Integrals
\integral
Integrals
\iota
Greek letters
\Iota
Greek letters
\itimes Math operators
\j
Symbols
\jj
\jmath
Symbols
\kappa
Greek letters
\Kappa
Greek letters
\ket
Delimiters
\lambda
Greek letters
\Lambda
Greek letters
\langle
Delimiters
\lbbrack
Delimiters
\lbrace
Delimiters
\lbrack
Delimiters
\lceil
Delimiters
\ldiv
Fraction slashes
\ldivide
Fraction slashes
\ldots
Dots
\le
\left
Delimiters
\leftarrow
Arrows
\Leftarrow
Arrows
\leftharpoondown
Arrows
\leftharpoonup
Arrows
\leftrightarrow
Arrows
\Leftrightarrow
Arrows
\leq
\lfloor
Delimiters
\lhvec
Accents
\limit
Limits
\ll
\lmoust Symbol Delimiters
\Longleftarrow
Arrows
\Longleftrightarrow
Arrows
\Longrightarrow
Arrows
\lrhar
Arrows
\lvec
Accents
\mapsto
Arrows
\matrix
Matrices
\medsp Space characters
\mid
\middle
Symbols
\models
\mp
Binary operators
\mu
Greek letters
\Mu
Greek letters
\nabla
Symbols
\naryand
Operators
\nbsp Space characters
\ne
\nearrow
Arrows
\neq
\ni
\norm
Delimiters
\notcontain
\notelement
\notin
\nu
Greek letters
\Nu
Greek letters
\nwarrow
Arrows
\o
Greek letters
\O
Greek letters
\odot
Binary operators
\of
Operators
\oiiint
Integrals
\oiint
Integrals
\oint
Integrals
\omega
Greek letters
\Omega
Greek letters
\ominus
Binary operators
\open
Delimiters
\oplus
Binary operators
\otimes
Binary operators
\over
Delimiters
\overbar
Accents
\overbrace
Accents
\overbracket
Accents
\overline
Accents
\overparen
Accents
\overshell
Accents
\parallel
Geometry notation
\partial
Symbols
\pmatrix
Matrices
\perp
Geometry notation
\phantom
Symbols
\phi
Greek letters
\Phi
Greek letters
\pi
Greek letters
\Pi
Greek letters
\pm
Binary operators
\pppprime
Primes
\ppprime
Primes
\pprime
Primes
\prec
\preceq
\prime
Primes
\prod
Math operators
\propto
\psi
Greek letters
\Psi
Greek letters
\qdrt
\quadratic
\rangle
Delimiters
\Rangle
Delimiters
\ratio
\rbrace
Delimiters
\rbrack
Delimiters
\Rbrack
Delimiters
\rceil
Delimiters
\rddots
Dots
\Re
Symbols
\rect
Symbols
\rfloor
Delimiters
\rho
Greek letters
\Rho
Greek letters
\rhvec
Accents
\right
Delimiters
\rightarrow
Arrows
\Rightarrow
Arrows
\rightharpoondown
Arrows
\rightharpoonup
Arrows
\rmoust
Delimiters
\root
Symbols
\scripta
Scripts
\scriptA
Scripts
\scriptb
Scripts
\scriptB
Scripts
\scriptc
Scripts
\scriptC
Scripts
\scriptd
Scripts
\scriptD
Scripts
\scripte
Scripts
\scriptE
Scripts
\scriptf
Scripts
\scriptF
Scripts
\scriptg
Scripts
\scriptG
Scripts
\scripth
Scripts
\scriptH
Scripts
\scripti
Scripts
\scriptI
Scripts
\scriptk
Scripts
\scriptK
Scripts
\scriptl
Scripts
\scriptL
Scripts
\scriptm
Scripts
\scriptM
Scripts
\scriptn
Scripts
\scriptN
Scripts
\scripto
Scripts
\scriptO
Scripts
\scriptp
Scripts
\scriptP
Scripts
\scriptq
Scripts
\scriptQ
Scripts
\scriptr
Scripts
\scriptR
Scripts
\scripts
Scripts
\scriptS
Scripts
\scriptt
Scripts
\scriptT
Scripts
\scriptu
Scripts
\scriptU
Scripts
\scriptv
Scripts
\scriptV
Scripts
\scriptw
Scripts
\scriptW
Scripts
\scriptx
Scripts
\scriptX
Scripts
\scripty
Scripts
\scriptY
Scripts
\scriptz
Scripts
\scriptZ
Scripts
\sdiv
Fraction slashes
\sdivide
Fraction slashes
\searrow
Arrows
\setminus
Binary operators
\sigma
Greek letters
\Sigma
Greek letters
\sim
\simeq
\smash
Arrows
\smile
\spadesuit
Symbols
\sqcap
Binary operators
\sqcup
Binary operators
\sqrt
\sqsubseteq
Set notation
\sqsuperseteq
Set notation
\star
Binary operators
\subset
Set notation
\subseteq
Set notation
\succ
\succeq
\sum
Math operators
\superset
Set notation
\superseteq
Set notation
\swarrow
Arrows
\tau
Greek letters
\Tau
Greek letters
\therefore
\theta
Greek letters
\Theta
Greek letters
\thicksp Space characters
\thinsp Space characters
\tilde
Accents
\times
Binary operators
\to
Arrows
\top
Logic notation
\tvec
Arrows
\ubar
Accents
\Ubar
Accents
\underbar
Accents
\underbrace
Accents
\underbracket
Accents
\underline
Accents
\underparen
Accents
\uparrow
Arrows
\Uparrow
Arrows
\updownarrow
Arrows
\Updownarrow
Arrows
\uplus
Binary operators
\upsilon
Greek letters
\Upsilon
Greek letters
\varepsilon
Greek letters
\varphi
Greek letters
\varpi
Greek letters
\varrho
Greek letters
\varsigma
Greek letters
\vartheta
Greek letters
\vbar
Delimiters
\vdash
\vdots
Dots
\vec
Accents
\vee
Binary operators
\vert
Delimiters
\Vert
Delimiters
\Vmatrix
Matrices
\vphantom
Arrows
\vthicksp Space characters
\wedge
Binary operators
\wp
Symbols
\wr
Binary operators
\xi
Greek letters
\Xi
Greek letters
\zeta
Greek letters
\Zeta
Greek letters
\zwnj Space characters
\zwsp Space characters
Binary operators
Binary operators
Arrows
In this tab, you will find the list of math expressions that will be recognized by the Equation editor as functions and therefore will not be automatically italicized. For the list of recognized functions go to the File tab -> Advanced Settings -> Proofing -> AutoCorrect Options -> Recognized Functions.
To add an entry to the list of recognized functions, enter the function in the blank field and click the Add button.
To remove an entry from the list of recognized functions, select the function to be removed and click the Delete button.
Use the Reset to default button to restore default settings. Any function you added will be removed and the removed ones will be restored.
By default, the editor formats the text while you are typing according to the auto-formatting presets: replaces quotation marks, converts hyphens to dashes, converts text recognized as internet or network path into a hyperlink, starts a bullet list or a numbered list when a list is detected.
The Add period with double-space option allows to add a period when you double tap the spacebar. Enable or disable it as appropriate. By default, this option is disabled for Linux and Windows, and is enabled for macOS.
To enable or disable the auto-formatting presets, go to the File tab -> Advanced Settings -> Proofing -> AutoCorrect Options -> AutoFormat As You Type.
Text AutoCorrect
You can set the editor to capitalize the first word of each sentence automatically. The option is enabled by default. To disable this option, go to the File tab -> Advanced Settings -> Proofing -> AutoCorrect Options -> Text AutoCorrect and uncheck the Capitalize first letter of sentences option.
AutoCorrect
Revenir à la page précédente
