The My documents folder opens.
The simplest way to structure the company documentation is to organize it by groups creating a common directory for each company department.
Switch to the Common section clicking the corresponding link at the left-side panel. Click the Create button in the upper left corner and select the Folder option from the drop-down list. Enter a name for your folder, for example, a department title, and click the Create
icon.
The folder with the specified name will be created in the Common section. The same way you can create as many folders as you wish.
