Close Help Center Documents Documents. Getting Started People. Getting Started Managing company documentation Importing files from other sources Managing versions and revisions Administration Guides ONLYOFFICE Workspace Managing portals Reinforcing security Configuring modules and tools Customizing modules and tools Managing users Connecting external services ONLYOFFICE Control Panel Glossary Video FAQ General Technology Pricing Workspace Enterprise Edition Docs Enterprise Edition Docs Developer Edition ONLYOFFICE Groups Connectors Trial period How to edit documents from OneDrive in ONLYOFFICE Documents Using context menus Document collaboration made easy in the online office Documents. Getting Started Documents module troubleshooting Co-editing documents online Creating CSV files Embedding a document into a blog Managing company documentation More articles Integrating other resources with the Documents module Manage your documents with the online office Integrating third-party services in the server version Integrating third-party services in the cloud version Managing versions and revisions Sending for electronic signature Learning about folder permissions hierarchy Sharing files and folders How to edit documents from Dropbox in ONLYOFFICE How to edit documents from Google Drive in ONLYOFFICE How to edit documents from Nextcloud in ONLYOFFICE How to edit documents from ownCloud in ONLYOFFICE How to edit documents from Box in ONLYOFFICE How to edit documents from OneDrive in ONLYOFFICE Managing versions and revisions Sharing documents Personal Personal Managing versions and revisions Sharing documents Languages availabe in ONLYOFFICE Personal How to edit documents from Dropbox in ONLYOFFICE How to edit documents from Google Drive in ONLYOFFICE How to edit documents from Nextcloud in ONLYOFFICE How to edit documents from ownCloud in ONLYOFFICE How to edit documents from Box in ONLYOFFICE How to edit documents from OneDrive in ONLYOFFICE ONLYOFFICE Personal troubleshooting Document collaboration made easy in the online office Real-time co-editing in ONLYOFFICE integrate OneDrive account Integrating other resources with the Documents module How to edit documents from OneDrive in ONLYOFFICE Integrating third-party services in the server version Open or create new files and folders Open or create new files and folders Open or create new files and folders Open or create new files and folders You have a OneDrive account and want to edit your documents using ONLYOFFICE? Follow this step-by-step guide to find out how to edit documents stored in your OneDrive from the Documents portal module. This option is available for ONLYOFFICE Workspace/ONLYOFFICE Workspace Enterprise Edition users only. Cloud users can skip this section and proceed with Connect your OneDrive to ONLYOFFICE step. Creating authorization keys You will have to setup authorization keys for OneDrive. Follow these steps: Go to Microsoft Azure. Sign in to your account. Сlick the New registration button at the App registrations page. Enter your application Name. Enter "https://service.onlyoffice.com/oauth2.aspx" in the Redirect URL field. Click the Register button at the bottom of the page; Copy or write down the Application (client) ID displayed at the Overview page. Switch to the Certificates & secrets section on the left. Click the New client secret button. Enter the description and click Add. Copy or write down the Client secret displayed in the Value field. Connecting the OneDrive service First of all go to the Settings section. To do that click the icon in the right upper corner. Switch to the Integration tab. Open the Third-Party Services page. Click the sliding button right of the OneDrive logo. Enter your keys and click the Enable button. Connect your OneDrive to ONLYOFFICE In the left sidebar of the Documents, just below the text Connect, click on the OneDrive icon. Login to your Microsoft account. Allow ONLYOFFICE to connect to your OneDrive by clicking the button. Your OneDrive documents will be shown in ONLYOFFICE documents as a folder. Change the folder‘s name, if necessary. If you want the OneDrive documents to be visible for anyone, click the Make shared checkbox and put into the Common Documents folder. If not checked, your OneDrive account will only be visible to you. This step is not available while working in ONLYOFFICE Personal. Click Save. Edit your OneDrive documents Locate the OneDrive folder and open it. Browse to the file you want to edit and click it. If necessary, a dialog will tell you that the document will be converted to the OpenOffice XML format for faster viewing and editing. You can choose to keep the original file as well, by checking the Save the file copy in the original format as well box. Click Convert. Click Open when the message appears that your document is successfully converted. Now you can edit your document (if editable). After editing, you can simply close the document and the changes will be saved. Try now for free Try and make your decision No need to install anythingto see all the features in action You Might Also Like This: Close
