Close Help Center Documents Documents. Getting Started People. Getting Started Managing company documentation Managing versions and revisions Administration Guides ONLYOFFICE Workspace Managing portals Reinforcing security Configuring modules and tools Customizing modules and tools Managing users Connecting external services ONLYOFFICE Control Panel ONLYOFFICE DocSpace Glossary Video FAQ General Technology Pricing Workspace Enterprise Edition Docs Enterprise Edition Docs Developer Edition ONLYOFFICE Groups Connectors Trial period How to edit documents from Nextcloud in ONLYOFFICE Documents Using context menus Document collaboration made easy in the online office Documents. Getting Started Documents module troubleshooting Co-editing documents online Creating CSV files Managing company documentation More articles Integrating other resources with the Documents module Manage your documents with the online office Integrating third-party services in the server version Integrating third-party services in the cloud version Managing versions and revisions Sending for electronic signature Learning about folder permissions hierarchy Sharing files and folders Editing documents from Dropbox in ONLYOFFICE Editing documents from Google Drive in ONLYOFFICE Editing documents from Nextcloud in ONLYOFFICE Editing documents from ownCloud in ONLYOFFICE Editing documents from Box in ONLYOFFICE Editing documents from OneDrive in ONLYOFFICE Managing versions and revisions Sharing documents integrate Nextcloud account Integrating other resources with the Documents module Editing documents from Nextcloud in ONLYOFFICE Configuring reverse proxy for Nextcloud and ONLYOFFICE editors Integrating ONLYOFFICE with Nextcloud Open or create new files and folders Open or create new files and folders Open or create new files and folders Open or create new files and folders More articles How to integrate ONLYOFFICE with Nextcloud using the app from the official store How to integrate ONLYOFFICE with Nextcloud Configuring ONLYOFFICE connector for Nextcloud You have a Nextcloud account and want to edit your documents using ONLYOFFICE? Follow this step-by-step guide to find out how to edit documents stored in your Nextcloud from the Documents portal module. Connect your Nextcloud account to ONLYOFFICE In the left sidebar of the Documents, just below the text Connect, click on the Nextcloud icon. Specify the connection URL, your user name and password and click Save to connect your NextCloud account. For example, the URL that allows to access your Nextcloud files via WebDAV looks like this: https://yourdomain.com/remote.php/dav/files/. This URL address can be found in the following way: sign in to your Nextcloud account, go to Files, click the Files settings icon in the lower left corner and copy the entire URL from the WebDAV field. Then switch to the ONLYOFFICE Documents module and paste the entire copied URL address, including the protocol, into the Connection URL field. Your NextCloud documents will be shown in ONLYOFFICE documents as a folder. Change the folder‘s name if necessary. If you want the NextCloud documents to be visible for anyone, click on the Make shared checkbox and put into the Common Documents folder. If not checked, your NextCloud account will only be visible to you. This step is not available while working in ONLYOFFICE Personal. Click Save. Edit your Nextcloud documents Locate the Nextcloud folder and open it. Browse to the file you want to edit and click it. If necessary, a dialog will tell you that the document will be converted to the OpenOffice XML format for faster viewing and editing. You can choose to keep the original file as well, by checking the Save the file copy in the original format as well box. Click Convert. Click Open when the message appears that your document is successfully converted. Now you can edit your document (if editable). After editing, you can simply close the document and the changes will be saved. Try now for free Try and make your decision No need to install anythingto see all the features in action You Might Also Like This: Close
