Статьи с тэгом :
Закрыть
История изменений
Закрыть
Попробовать в облаке
Installing ONLYOFFICE DocSpace Developer using the provided script
Introduction
ONLYOFFICE DocSpace is a document hub where you can connect users and documents in one place to boost collaboration.
Functionality
  • Creating rooms for collaboration with flexible access permissions: viewing, reviewing, filling forms, editing.
  • Creating and editing documents, spreadsheets, presentations, forms, PDFs, and ebooks. Viewing multimedia files.
  • Inviting users for collaboration: real-time co-editing, commenting, and communication via chat or video calls within online editors.
  • Storing and managing personal documents within a dedicated space.
  • Managing rooms: adding files, inviting members and assigning permission levels, viewing detailed info and recent activities, archiving rooms.
  • Configuring integration features: connecting external services and storages. Currently, third-party storages can be used for performing backup only.
  • Using customization and branding features.
  • Setting up security features: backup and restore, two-factor authentication, IP security, audit trail and more.
ONLYOFFICE DocSpace Developer can be installed using an automatic installation script for Linux operating systems with Docker installed. The script will set up Docker container with all the components necessary for ONLYOFFICE DocSpace Developer correct work and is easy to run, manage and update.
This guide will show you how to install ONLYOFFICE DocSpace Developer to your machine using the provided Docker script. Alternatively, you can run this script and select an option to install ONLYOFFICE DocSpace Developer from RPM/DEB packages.
System requirements
  • Процессор
    минимум 4 ядра (рекомендуется 6 ядер)
  • Оперативная память
    не менее 8 Гб (рекомендуется 12 Гб)
  • Свободное место на жестком диске
    не менее 40 Гб
  • Дополнительные требования
    не менее 6 Гб для файла подкачки
  • Операционная система
    amd64 дистрибутив Linux с версией ядра 3.10 или выше
Getting ONLYOFFICE DocSpace script
Download ONLYOFFICE DocSpace Developer Docker script file:
wget http://download.onlyoffice.com/docspace/docspace-install.sh
wget http://download.onlyoffice.com/docspace/docspace-enterprise-install.sh
wget http://download.onlyoffice.com/docspace/docspace-developer-install.sh
Once the download is finished, you can start the installation process.
Please note that all installation actions must be performed with root rights.
Installing ONLYOFFICE DocSpace from DEB/RPM packages
To install ONLYOFFICE DocSpace Developer using DEB/RPM packages, run the following command:
bash docspace-install.sh package
bash docspace-enterprise-install.sh package
bash docspace-developer-install.sh package
Once the installation is finished, open a browser and enter the local network computer IP address to the browser address bar. The DocSpace setup page will open.
Now you need to specify your email, password (by default, the password must be at least 8 but no more than 30 characters long), upload the license file, upload the license file, accept the License agreement terms. You can also select the necessary language and time zone using the corresponding drop-down lists. When all the parameters are set, click the Continue button.
When installing using DEB/RPM packages, you can set the default port via debconf:
echo "docspace docspace/port string 80" | debconf-set-selections
Installing ONLYOFFICE DocSpace using script for Docker
To install ONLYOFFICE DocSpace Developer using Docker, run the following command:
bash docspace-install.sh docker
bash docspace-enterprise-install.sh docker
bash docspace-developer-install.sh docker
Displaying available script RPM/DEB parameters
To display the list of all available script RPM/DEB parameters, use the following command:
bash docspace-install.sh package -h
bash docspace-enterprise-install.sh package -h
bash docspace-developer-install.sh package -h
To learn more on how to use all the available script RPM/DEB parameters, please refer to this article.
Displaying available script Docker parameters
To display the list of all available script Docker parameters, use the following command:
bash docspace-install.sh docker -h
bash docspace-enterprise-install.sh docker -h
bash docspace-developer-install.sh docker -h
To learn more on how to use all the available script Docker parameters, please refer to this article.
Docker, Windows и Linux
Закрыть
