Статьи с тэгом :
Закрыть
История изменений
Закрыть
Попробовать в облаке
Switching your ONLYOFFICE DocSpace Developer to HTTPS when installing from RPM/DEB packages
Introduction
When you install ONLYOFFICE DocSpace Developer from RPM/DEB packages, you can use the letsencrypt.org service and script to easily create a CA-signed certificate and switch the portal to HTTPS with a single command.
The article below will explain this can be done.
Creating and installing CA-signed certificate
Run the following script:
bash /usr/bin/docspace-ssl-setup EMAIL DOMAIN
Where:
  • EMAIL is the email used for registration and recovery contact. Use comma to register multiple emails, for example: u1@example.com,u2@example.com.
  • DOMAIN is the address of the domain where your ONLYOFFICE DocSpace Developer portal is installed.
The script will automatically create and install the letsencrypt.org CA-signed certificate to your server and restart the NGINX service for the changes to take effect.
Now your portal should be available via the https:// address.
Using own certificates
You can use your own certificates via the -f parameter:
bash /usr/bin/docspace-ssl-setup -f yourdomain.com CERTIFICATE PRIVATEKEY
Where:
  • CERTIFICATE is the path to the certificate file for the domain.
  • PRIVATEKEY is the path to the private key file for the certificate.
Docker, Windows и Linux
Закрыть
