Статьи с тэгом :
Закрыть
История изменений
Закрыть
Попробовать в облаке
Connecting MySQL database with SSL/TLS to ONLYOFFICE Docs
If you want to use secure SSL/TLS connections with MySQL when connecting to ONLYOFFICE Docs, follow these steps:
  1. If MySQL is installed with SSL enabled, it provides self-signed certificates in /var/lib/mysql/ including the certificate authority ca.pem certificate, server certificates and client certificates: ca-key.pem, ca.pem, client-cert.pem, client-key.pem, private_key.pem, public_key.pem, server-cert.pem, server-key.pem.
    To connect via SSL, only ca.pem is required, but for additional protection and establishing trust, it is recommended to use client-cert.pem and client-key.pem. They must be converted to a string, for example, in the following way:
    awk 'NF {sub(/\r/, ""); printf "%s\\n",$0;}' ca.pem
    awk 'NF {sub(/\r/, ""); printf "%s\\n",$0;}' client-cert.pem
    awk 'NF {sub(/\r/, ""); printf "%s\\n",$0;}' client-key.pem
  2. Add the certificate to the document server local.json config:
      "services": {
        "CoAuthoring": {
          "sql": {
            "type": "mysql",
            "dbHost": "onlyoffice.local",
            "dbPort": "3306",
            "dbName": "onlyoffice",
            "dbUser": "onlyoffice",
            "dbPass": "onlyoffice",
            "mysqlExtraOptions": {
              "ssl": {
                "ca": "-----BEGIN CERTIFICATE-----\n...ca.pem...\n-----END CERTIFICATE-----\n\n",
                "cert": "-----BEGIN CERTIFICATE-----\n...client-cert.pem...-----END CERTIFICATE-----\n\n",
                "key": "-----BEGIN RSA PRIVATE KEY-----\n...client-key.pem...\n-----END RSAD RSA PRIVATE KEY-----\n\n"
  3. Restart services:
    systemctl restart ds-converter ds-docservice ds-example ds-metrics
Docker, Windows и Linux
Закрыть
