Click the logo in the upper left corner of the Desktop Editors interface to return to the main program window, then switch to the Connect to cloud section to view the Connected clouds list. Right-click on a connected cloud office and use one of the available contextual menu options:
- Open - to switch to the corresponding cloud storage tab, if you are already logged in to this account, or to open the Connect to cloud office window, if you are not currently logged in (in such a case, you will need to enter your credentials),
- Logout - to exit from your account,
You can also click the
icon to the right of the account to exit from it.
- Remove from list - to disconnect the selected account and remove it from the list.
If you have several accounts or clouds, use the Add cloud button to connect one more account.
