Logged into your DocSpace from another device, but then forgot to log out? You can manually close a specific active session.
The list of active connections is available only for your profile, and only connections of your profile can be logged out.
Closing a particular session
- Click the
icon next to your name in the lower left corner and select the Profile option or just click your name.
- On the My profile page, find the Active Sessions section. You will see the list of all your active connections which contains the following data: operating system, browser, date and time, IP address. In the SaaS version, the country and city are also displayed.
![Active connections list](/ru/images/help/tipstricks/DocSpace/activeconnections.png)
- Find the needed connection and click on the
icon located on the right.
- Click Log out to confirm the action.
![Closing a particular session](/ru/images/help/tipstricks/DocSpace/logout.png)
The selected connection will be stopped and excluded from the list.
Closing all active connections
- Click the
- Click the Log out from all active sessions option.
- The Log out from all active connections window will appear:
![Log out from all active connections](/ru/images/help/tipstricks/DocSpace/logout_activeconnections.png)
- For more security, you can check the Change password after logging out box.
- Click the Log out button.
All connection excepting the current one will be stopped and excluded from the list. If you checked the Change password after logging out option, you will be logged out from all connections and prompted to create a new password. After creating a new password, you will need to enter your credentials to log in to your DocSpace.
