Статьи с тэгом :
Закрыть
История изменений
Закрыть
Попробовать в облаке
Connecting Facebook to ONLYOFFICE DocSpace
Connect the Facebook service to log in to your space quickly.
Creating authorization keys
In the cloud version, the authorization keys parameters for Facebook are set up automatically.
In the server version, you will have to setup authorization keys for Facebook. Follow these steps:
  1. Go to Facebook Developers Portal;
  2. Sign in to your account;
  3. Click the My Apps link in the upper right corner and click the Create App button;
  4. Select the Consumer app type and click the Next button;
  5. Enter your application name in the Display name field and verify your App contact email specified by default;
  6. Click the Create app button;
  7. You will be redirected to the + Add Product page. Move the mouse cursor over the Facebook Login section and click the Set up button;
  8. Provide both a valid Privacy Policy URL and data deletion information in the Settings -> Basic section;
  9. The Facebook Login product will appear in the Products section of left-side menu. Click the Settings link below the Facebook Login product. Find the Client OAuth Settings section;
  10. Introduce https://service.onlyoffice.com/oauth2.aspx in the Valid OAuth redirect URIs field;
  11. Click the Save changes button in the lower right corner;
  12. Switch your App Mode from Developer to Live using the switcher on the top panel.
    Alternatively, you can add users who will use Facebook Login to Testers for this app:
    1. Go to the Roles section in the left-side menu.
    2. In the Testers sections, add all users one by one specifying their Facebook IDs.
    3. All users must be verified as developers on Facebook and accept the requests.
  13. On the left-side panel, open the Settings -> Basic section;
  14. Copy or write down your App ID and App Secret.
  1. In the server version, click the Options icon menu in the lower left corner and select the Settings option.
  3. In the Third-party services section, click the sliding button to the right of the Facebook logo.
  4. Enter your keys and click the Connect button.
To sign in via Facebook,
  1. Go to your 'Profile' page clicking the link with your name in the lower left corner of the page.
  2. On your 'Profile' page, find the 'Сonnect your social networks' caption, choose the Facebook service and click the 'Connect' button.
  3. In the opened window, grant the access to ONLYOFFICE application and enter the account credentials, if it's necessary.
Закрыть
