Articles with the tag:
Close
Close
Try in the cloud
Try in the cloud
Connecting Zoom to ONLYOFFICE DocSpace
Connect the Zoom service to log in to your space quickly.
Creating authorization keys
In the cloud version, the authorization keys parameters for Zoom are set up automatically.
In the server version, you will have to setup authorization keys for Zoom. Follow these steps:
  1. Go to Zoom App Marketplace.
  2. Sign in to your account.
  3. Click Develop and choose Build App.
  4. In the OAuth section, click Create.
  5. Specify your App Name.
  6. Click Create.
  7. In the Redirect URL for OAuth field, enter https://service.onlyoffice.com/oauth2.aspx. Add the same URL in the OAuth Allow List section and click Continue.
  8. In the Scopes section, click Add Scopes and choose any suitable item from Zoom Events.
  9. After completing the app setup, go to App Credentials to find your Client ID and Client Secret.
  1. In the server version, click the Options icon menu in the lower left corner and select the Settings option.
  3. In the Third-party services section, click the sliding button to the right of the Zoom logo.
  4. Enter your keys and click the Connect button.
To sign in via Zoom,
  1. Go to your 'Profile' page clicking the link with your name in the lower left corner of the page.
  2. On your 'Profile' page, find the 'Сonnect your social networks' caption, choose the Zoom service and click the 'Connect' button.
  3. In the opened window, grant the access to ONLYOFFICE application and enter the account credentials, if it's necessary.
You Might Also Like This:
Close
