Articles with the tag:
Close
Close
Try in the cloud
Try in the cloud
Connecting KDrive to ONLYOFFICE DocSpace
Connect the KDrive service to use the connected cloud storage as a third-party resource when creating backups or public rooms.
To store your DocSpace data backup in KDrive,
  1. Go to the 'Backup' section (Settings -> Backup -> Third-party resource).
  2. Select KDrive as the desired storage and click the 'Connect' button.
  3. Fill out the Login and Password fields.
  4. Click the Save button.
  5. Click 'Create copy'.
To store your public room data in KDrive,
  1. Go to the Rooms section on the left.
  2. Use the New room button in the upper left corner or the Plus icon Plus icon above the list of rooms.
  3. Select the Public room.
  4. Enter the room name, add tags, upload an image.
  5. Turn on the Third-party storage switcher.
  6. Select KDrive from the list and click Connect.
  7. In a new window, specify your login and password, and click Save.
  8. A new folder for storing this room’s data will be created in the connected storage. If necessary, uncheck this option and select the already existing folder in the connected storage.
  9. Click Create.
For more details about creating rooms, read this article.
You Might Also Like This:
Close
