Articles with the tag:
Close
Close
Try in the cloud
Try in the cloud
Change application settings
To access the Document Editor advanced settings,
  2. tap the arrow next to the Application Settings Application Settings menu item.
Curently, this function is not available when editing a local document using the On Device section
Currently, the following advanced settings are available:
  • Unit of Measurement allows to specify what units are used in properties windows for measuring elements parameters such as width, height, spacing, margins etc. You can select the Centimeter, Point, or Inch option.
  • Spell Checking allows to enable or disable the spell checking function.
  • Nonprinting Characters allows to display or hide nonprinting characters in the document text.
  • Hidden Table Borders allows to display or hide hidden table borders. If you enable this option, the hidden table borders will be displayed as dotted lines in the document text.
  • Commenting display allows to display or hide Comments and/or Resolved Comments. If you enable these options, the comments will be highlighted in the document text.
  • Macros Settings allows to choose if you want to enable all macros with or without a notification or disable all macros.
You Might Also Like This:
Close
